Everything posted by popik1970
Problema Rupere Lant Distributie Motoare N47 2.0D
Problema rezolvata, schimbat intinzatorul.Cel vechi rupt si pierdea ulei pe langa pistonas, intinzatorul nou mai lung cu 10-13 mm.
Case 2: N47 engine, N47DKO, N47S, N47T production interval 05.01.2009 - 01.03.2011 In case of customer complaint replace the following parts: -11 8,506,652 31 Supply Chain bottom. - 13 52 7 797 906 sprocket high pressure pump. - 11 31 8 510 014 Supply Chain superior. -11 7,797,899 31 Timing Chain Guide above. -13 7,797,904 52 Timing Chain Guide below. Note: There is no need to release the binding thread of the intermediate toothed wheel balancer shafts. Note: As of March 2011 there are new guidelines. These guidelines do not bring reinforcing ribs. In this way the inner surface of the guides is smooth throughout its length and the timing chain runs easily on them. They have not changed the references. Motor N47D20C, probleme or ba? La mine engleza este :death:
exemplu: https://www.bavauto.ro/11417797896 https://www.epiesa.ro/lant-antrenare-bmw-seria-3-e90-318-d/25466/subcat-100885/
Salut, de ~ 2 saptamani am inceput sa am un zgomot la prima pornire(dupa o pauza de 7-9 ore), zgomotul este foarte scurt 3-5", ca si cum am niste pietre in galeata Voi merge sa o asculte un mecanic si as vrea sa cumpar distributia, intrebare: 1. kit pe ina= 1700 2. kit swag = 1450 3 OE = 1300 in aceste preturi intra : 3 lanturi,3 pinioane, 4 patine, 2 intinzatoare,semering arbore si loctite 5970 pentru etansare. Ce recomandati ca fabricant? Multumesc!
ISTA 4.11.22 / SDP 4.11.20
Am facut setarile in ediabas ini, testergui/releas cele 2 dll, configurare vci in ista si cu toate astea nu vrea.
Salut, revin cu aceeasi problema : identific masina dupa VIN dar nu ma pot conecta la masina.Am incercat cu cablu K-KAN si ENET, degeaba :hyper: Fac cinste grasa, de 5 luni ma chinui :frantics: P.S. E90 LCI, ISTA 4.06
BRICHETA AUTO!
ok,ms!
BRICHETA AUTO!
Salut! Madutzu25 ne poti spune la ce siguranta ai gasit +permanent si daca exista riscul sa se descarce bateria alimentand o camera de trafic? Multumesc!
ISTA 4.09.13 Standalone / SDP 4.09.12 / ISTA-P 3.63.2.001
Salut, Am o mica, mare problema :frantics:, am reusit sa instalez ista/d(+sdp) si nu-mi vede control unit tree , control unit list.Daca incerc sa deschid ceva( ce nu este pe fond gri) imi spune ca trebui sa instalez ista/p.Chiar nu stiu ce sa mai butonez..... :bashwall: Daca este vreun coleg de forum care ma poate ajuta :cheers: Multumesc anticipat, O zi placuta tuturor!
ISTA 4.08.13 Standalone / SDP 4.08.11 / ISTA-P 3.63..0400
aceeasi problema a fost si la mine, remediu: 1 net framework 4.7 2 vc_redist 2017
ISTA v4.05.23
Salut! va rog sa ma ajutati si pe mine cu instalare ista, nu reusesc si pace..... Pana acum nu reuseam sa-l fac sa se deschida, acum imi da eroare. Multumesc!
ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
Salut, Ma poate ajuta cineva cu instalare ista pe un laptop cu windows 10? Pe w7 l.am instalat si pe w 10 nu reusesc :frantics: Multumesc!
Probleme pornire si frm
Problema rezolvata. Multumiri SKW 🍻
Am probat un modul frm si functioneaza, nu stiu ce sa fac, sa cumpar altu sau sa.l rescriu pe al meu?
Buna seara, Azi dimineata am mers la micuta mea si nu a vrut sa ma mai primeasca :hyper: *nu se mai deschide din telecomanda; *nu aveam curent (0 lumini, 0 radio, nimic nu se aprindea:( ); *2 chei = nu le citea; *nu puteam deschide portbagajul( apropo,cum il deschid mecanic/manual!?); *dupa ~45' si.a revenit partial, imi citeste cheile,porneste,functioneaza toata aparatura mai putin luminile si oglinzile; *am pus testerul= dus modul frm; *se poate repara, sau altu; Astept opinii,sfaturi, recomandari. Multumesc!
Legare camera trafic
+ l-am gasit este marcat cu sageata,am incuiat masina si dupa 20-30' aveam lampa aprinsa. nu am reusit sa termin de montat camera,nu am avut nici timpul necesar si nici nu am reusit sa desfac plafoniera sa vad cum ma leg. cand voi finaliza revin
George, am vazut linkul,imi place acea cutiuta care mascheaza camera, interesanta si nu costa f. mult. Ms!
Multumesc cristianro pt informatie,nu stiam de plafoniera(credeam ca este comandata de modulul confort). 1 am acumulator la camera,autonomie 5' din pacate 2 motivul de a ma lega in tablou,tocmai firele care atarna prin masina 3 am setarile facute pt parcare 4 madutzu,eu nu am tensiune pe brichete cand scot cheia Multumesc tuturor! :cheers:
Buna ziua,doresc sa aflu daca este ok din pct de vedere al sigurantei impotriva incendiului si astept si alte opinii. Doresc sa leg o camera de trafic direct in tabloul de sigurante(nu am + permanent pe brichete si la MHS Militari mi s-a spus ca nu pot fi modificate din soft). In img atasata am indicat locul de unde voi lua + si - ma voi lega la sasiul tabloului sau voi cauta un - in sigurante. Multumesc si o zi placuta va doresc!
