shtefu1
Everything posted by shtefu1
  1. am vz ca adancimea de montare e 6,25 cm... acuma nu stiu exact cat am eu acolo, o sa incerc sa desfat unul sa ma uit... dar intrebarea mea era daca pot sa le leg pe amandoua la aceasta statie. in total au 240 si statia e de 250, teoretic ar trebui sa mearga dar nu stiu cum se procedeaza.
  2. am navigatie prof si am luat semnal de la boxele de pe spate. se aude bine sub-ul dar nu prea imi mai place mie ideea sa am portbagajul ocupat. ma intereseaza f mult daca merge combinatia aleasa de mine. magnat rx 22 si 2 x pioneer TS-SW841D sub scaune. la e60 sunt 2 woofere sub scaune dar sunt foarte proaste calitativ si in acelasi loc vreau sa le pun pe astea.
  3. am un e60 525d, am montat apmliful magnat rx22 si un sub magnat de 250 rms in portbagaj si nu prea imi place cum se aude. m-am gandit sa scot sub-ul acela si sa pun 2 woofere sub scaunele din fata in locul celor vechi si sa le amplific cu magnat-ul rx22. 1.se poate?,tine statia 2 woofere ca astea ? 2.daca da,cum pot sa le leg? http://www.be-loud.ro/produse/Amplificatoa...AGNAT/RX/RX_22/ http://www.be-loud.ro/produse/Subwoofere_a...neer/TS-SW841D/
  4. am incercat asa si nu merge: 1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car. 2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon. 3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu). 4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window. 5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on. 6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear. 7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above). Hints & Tips Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears. If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again). Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again). Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost". It took me a while to get the hang of it and I'm sure it'll take me a while to get my head around it again next time. am pornire la buton si probabil de asta... poate sa ma ajute cineva? e vorba de e60 525d 2006.
  5. am verificat si basculele, is ok.
  6. e vorba de un 525d 2006, e60. am o bataie pe fata, cand e volanul virat si dau peste o groapa, sau o linie de tranvai se aude foarte tare, se simte socul in volan. parca vibreaza ceva la roata, dar nu stiu ce naiba poate sa fie, am schimbat pe garantie caseta de directie, coloana de directie, un brat stanga fata si bucsele de pe bara stabilizatoare. baietii de la servis mi-au zis ca nu stiu ce poate sa aiba, am fost de 7 ori cu masina la ei, amortizoarele sunt bune, masina are 50k km, cinva mi-a zis ca e posibil sa fie flansele de la amortizoare duse. voi ce credet?
  7. vreau sa schimb placutele de frana in alta parte decat la bmw, deoarece mi se pare aiurea sa platesc 10 mil pe placute fata cand pot schimba si fata si spate in vreo 5-6 mil. se pierde garantia sau nu?
  8. shtefu1 replied to shtefu1's topic in Seria 5
    :twoup: , e interesanta faza, daca ploua afara nici nu mai stau pe ganduri si pun repede cheia sub barbie :twoup:) . si da, am pus folie pe geamuri, dar o am pusa cam de o luna si abia acum a inceput sa faca figuri.deci trebuie sa trag o fuga la ab.
  9. shtefu1 replied to shtefu1's topic in Seria 5
    eu merg regulat cu masina, cam 2-300 km pe zi... nu stiu daca asta e problema. si cheia de rezerva face exact la fel...o sa ma duc la o reprezentanta sa vad ce e cu ea ma gandeam ca a mai patit cineva si se rezolva mai usor, masina e in garantie. oricum ms.
  10. shtefu1 posted a topic in Seria 5
    am un 525d, 2006, cu cheie tip breloc, daca asa se cheama, am buton start/stop. faza e ca nu mai merge sa deschid masina dn butoane decat de la jumatate de metru distanta, inainte mergea si de la 10-15 metri, poate chiar mai bine. ce poate sa fie, asa face si cu cheia de rezerva care nu a fost folosita niciodata, deci are bateria noua. vreau sa incerc si o schimbare a bateriei, dar nu stiu cum sa o desfac. ce pot sa fac?
  11. facelift a aparut in martie 2007, nu se merita zic eu, mai bine cauti ceva dupa martie.
  12. si se potriveste orice amplif, sau sunt numai anumite modele care o sa le primeasca electronica de pe e60?
  13. wooferele nu sunt montate inca, si amplif masinii nu le duce sigur, vroiam sa stiu daca e bine sa pun alt amplificator separat doar pentru cele 2 woofere sau sa il schimb de tot pe cel al masinii cu unul mai mare care sa includa si wooferele alea.
  14. shtefu1 replied to BCI's topic in Seria 5
    si eu sunt interesat de asa ceva, ma refer pt proiectoare ca la faza lunga nu prea ma intereseaza. am vz undeva 110 euro pentru proiectoare, montajul nu stiu cat e, dar tot odata pe alt site am vz ceva in jurul la 10-12 mil. asa ca nu ma pot pronunta pentru un pret exact. chiar ma intereseaza, pentru un e60.
  15. cum recomandati? e vorba de un e60 din 2006 auditie standard, 8 boxe. cum sa fac cu amplificatorul pentru wooferele de sun scaune? sa il schimb pe cel al masinii sau sa pun unul numai pt wooferele alea 2?
  16. shtefu1 replied to micky's topic in Seria 5
    formula 1, galben
  17. shtefu1 replied to shtefu1's topic in Seria 5
    am inteles...si oare le pot schimba eu sau e mai complicat?...
  18. shtefu1 replied to shtefu1's topic in Seria 5
    ms mult. oare gasesc ceva cu lumina alba sa se potriveasca?
  19. shtefu1 posted a topic in Seria 5
    ce fel de becuri am in proiectoare? am un e60 din 2006, cu proiectoare normale si vreau sa pun becuri de alea cu lumina alba tip xenon de la philips, ca am auzit ca is mai bune. puteti sa i-mi spunei ce fel de becuri sunt? sau sai-mi recomandati ceva. ms.
  20. shtefu1 replied to micky's topic in Seria 5
    se gaseste si in metro si in alte magazine...si e o solutie f buna, la 300 de mii nu mi se pare mult.eu o folosesc cam de 4 ani....si is foarte multumit de ea. e buna pentru orice fel de suprafata din masina,mai putin pe insertiile de lemn.
  21. shtefu1 replied to micky's topic in Seria 5
    eu folosesc un spray cu un fel de spuma activa, il folosesc pentru plasticuri,cauciuc si piele. e super bun, pentru bord merge perfect, e de la Formula 1, un tub galben, se gaseste in OMV si PetromV. merita incercat, eu is foarte multumit de ea.
  22. in legatura cu suspensia m-am informat si eu si cam asa e, pe la 90k, deci ma incadrez perfect in parametri, dar caseta e cam ciudat la 40k, da in fine ce sa zic, ms pt post, m-ai linistit. :blink: uhhh.
  23. asa e, si mie mi se pare cam mult.
  24. aha ... ms , am sa incerc si asa.
  25. se poate face asa ceva? , eu am fost la bmw si i-am rugat sa verifice masina in baza lor de data dar mi-au bagat doar cheia intr-o prostie acolo si mi-au zis ca e in regula, si cand mi-am facut dosarul pentru garantie mi-au cerut cartea de servis, talonul si certificatul de conformitate. am programare marti la 8 si am sa ii rog. ms mult, dar eu nu pot verifica pe net undeva pe un site chestia asta?
