swimmer
477 -
Everything posted by swimmer
probleme reglej casetofon E39
swimmer replied to predecosmin's topic in Audio/Video/Navigatie/Electronica auto
Despre ce masina e vorba ca am eu casetofon in stare perfecta de functionare. L-am inlocuit pe cel original cu un Sony CD,MP3 CARE MERGE IMPECABIL. Gtata am gasit casetofonu original pt E46. Merge bine. Dadea parca 4x15w. Eu am acum 1000w asa ca nu mai am nevoie de el. -
Despre ce masina e vorba ca am eu casetofon in stare perfecta de functionare. L-am inlocuit pe cel original cu un Sony CD,MP3 CARE MERGE IMPECABIL. -
Mi se pare mie sau farurile fac condens ceea ce nu e bine. Presurile de plus nu rezista in Romania.
Inchide casetofonul inainte de a opri motorul si de a scoate cheia din contact. -
Test roti service. Bascule, caseta, bucsi fata. Se poate stringe dar nu mai revine volanul pe directia de mers.
Sau la alt service specializat. Are o functie:Software Reset; reset OBC settings. Mai caut pt 320D Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test 28. Put your turn signal either on the left or right position, with no key in the ignition, close the door and walk away. What you will see is the front blinker, and rear turn signal stay lit. From what I read, it's supposed to be a feature to for people to see your car when it's parked at night in those really tight streets in Europe. This way no one accidentally drives into your car. 29. If you look on your roof, there will be two flaps on each side that are plastic and body colors. You can remove them and there is a little hole in each one that accepts the BMW Roof Rack. 30. Hold down the PTY button (this works, to my knowledge, on cars w/nav) and you will turn on AUTOPTY--it'll display the type of music station if the data is present. I think this works for RDS too.... that way, you don't have to keep pressing it when you switch to radio or change stations etc. 31. Change the Speed Sensitive Volume Ratio - E46 Business CD Head Unit: Turn the radio off then on again. Don’t touch any button except the 'm' button - the button you use to tune the radio frequency manually. Press and hold the 'm' button for TEN seconds or until the display changes. It will then show the serial number of the unit. Normally when you press 'm', the display will reflect that by replacing 'ST' (stereo tuning) with 'm'. When holding the 'm' button for this procedure, the display should not do this - you will continue to see 'ST' for the ten seconds. Now if the display has changed, you are in a configure mode on the radio. If you press the '>' or '<' button you change modes. The mode you want will display as "GAL (1-6)". This mode allows you to adjust the speed-sensitive volume control. Use the radio preset buttons 1-6 to set the amount of volume change you want at speed. Setting 1 is the smallest change, 6 is the highest. I use 1 with the windows closed, and 5 when it's a nice enough day to drive with the windows open, which makes for a lot of ambient noise at speed. The car is so quiet with the windows closed that setting 1 is fine. Then turn the radio OFF to save the settings. Turn it back on; go for a drive to test it. The other semi-useful test mode will tell you the signal strength of any given station from 0 to 15 (highest). Use the preset buttons to change stations in the mode. This capability is probably used in the automatic tuning function in the radio. 32. The multiple 'auto heater/AC combinations at start-up' memory options are nifty. 33. If you want to leave your windows down but have the alarm set, but not have to worry about the motion detector go off, you can arm you alarm by hitting the lock button, and then wait a second and hit the button again. You'll see the clown nose light up for a second, which means the motion detector is deactivated 34. If you flicker your high beams when the car is off, your xenons go on for 30 seconds to give u a lighted path to walk 35. If you have auto wipers, the headlights go on when the wipers activate, if on auto. 36. Where the spare tire is, next to the portable jack there is a wheel chock!! 37. In Euro delivery cars, there is a warning triangle in a blue plastic case that bolts to the left rear of the trunk and a first aid kit under the passenger seat. 38. Apparently "there's a cheat code in the software running the BMW M3's sequential manual gearbox (SMG). Press the right buttons in the right order and the car will launch you from a stop after revving the engine to 5,000 rpm". "But there is a catch. In Europe, where the feature isn't so hush-hush, doing more than 15 launches voids the car's warranty. Federal laws prohibit such stipulations here, so BMW has turned down the which. US-spec cars are programmed to wind to only 2,500 rpm. That's why you have to ask your dealer to install the European software. Most will happily oblige" "For lucky drivers of this hot car, here's how: Switch of the stability system and select shift program six. Switch the engine to sport mode. With the hand shifter in drive, hold it in the downshift position and press the has pedal. The engine will rev to the preprogrammed rpm and hold. Now release the shifter. The car will launch forward violently and the engine's revs will climb quickly, so be prepared to up shift" 39. When you have your wipers on fast and medium (don’t know what you call it) Anyways if you come to a stop it'll go to intermittent 40. Want to know your odometer reading but no key... no problem. Just press the computer toggle button at the end of the turn signal lever. The computer read-out lights up with the odometer reading. 41. Everyone knows that the screwdriver in the tool kit is reversible. 42. When windshield wipers are going, and the a/c is on, regardless of the temp, warm air is coming out of the windshield defrost vent. 43. Holding down the DSC button to completely turn it off.
ceva probleme la computerul de bord. Te referi la computerul care arata temperatura de afara, ceasul, data...? :D Ala este computerul de bord OBC nu are mai multe functii? ceva probleme la computerul de bord. Te referi la computerul care arata temperatura de afara, ceasul, data...? :D Ala este computerul de bord OBC nu are mai multe functii?
Eu la astea ma refeream Eu la astea ma refeream Acelas profil l-am avut si la cele vechi dar erau Firestone si deci cauciuc net inferior.
Nu spun drift pentru ca nu am facut si nu fac. Dar aderenta e fantastica pe uscat. Puteti vedea profilul pe cauciucuridirect.ro. Eu nu le-am luat de pe net ca erau mai scumpe si trebuia sa astept 2 saptamani
Consumul in oras este de 20%. Exista destule momente cand ma pot bucura de masina. Folosesti exact aceles metode de revenire in axul longitudinal al drumului ca si pe uscat dar cu mai multa finete. Consumul mediu la el te referi nu? Si mergi cu multa grija
206km/h cum scrie si in talon si cam 5400 rot/min. Se poate duce mai mult dar e limitata electronic. Am intrebat pt k am un prieten tot cu un 318 si mi-a zis k i-a dat 220 si i-a intrat in limitare (limitare de turatie... ) si deasta am intrebat... credeam k are ceva... 206 e viteza stabilita de neamt si asta e nu te apuci sa modifici ceva la motor, soft sau cutie. Omu care a luat masina asa a luat-o el nu i-a facut absolut nimik... a luat-o din germania asa cum e... deasta eram putin derutat k m-am uitat si eu in talon si scrie... 208 la mine si eu am zis ok... atat merge... si mi-a zis el cand a adus-o k a luat 220 si am mers si eu cu el... si atat ia ce iti arata tie pe bord nu este viteza reala. s-a mai discutat asta . fa un search Kilometrajul poate avea eroare de + sau - 5 km/h nu mai mult si asta la peste suta de km/h
206km/h cum scrie si in talon si cam 5400 rot/min. Se poate duce mai mult dar e limitata electronic. Am intrebat pt k am un prieten tot cu un 318 si mi-a zis k i-a dat 220 si i-a intrat in limitare (limitare de turatie... ) si deasta am intrebat... credeam k are ceva... 206 e viteza stabilita de neamt si asta e nu te apuci sa modifici ceva la motor, soft sau cutie. Omu care a luat masina asa a luat-o el nu i-a facut absolut nimik... a luat-o din germania asa cum e... deasta eram putin derutat k m-am uitat si eu in talon si scrie... 208 la mine si eu am zis ok... atat merge... si mi-a zis el cand a adus-o k a luat 220 si am mers si eu cu el... si atat ia Ori e deja modificata ceea ce nu e recomandat ori nu indica bine kilometrajul.
Daca e carosabilul umed nu faci drift cu un 316? Daca e carosabilul umed nu faci drift cu un 316? Si acum sincer vorbind un V8 in Romania? La ce-ti foloseste? Doar daca ai pompa de benzina in curte... Altfel nu dai in ea ca-ti afiseaza consumul instantaneu pe la 34 l/100km nu?
Demareaza ceva mai greu. Si da poti face drifting si cu un 316 Poti face drifting cu orice masina care trece de 80km/h
Pe cine intereseaza pentru un seria 3, de ex. 318i. I-am luat cauciucuri de vara Michelin Energy Saver 195/65 R15 91H NEU Made in Italy. Le am de 2 saptamani si sunt foarte multumit. Le-am luat de la AZ(cauciucuri dela a la z Constanta) 270RON/Buc. Am impresia ca fura ceva din puterea motorului si la mine cu cei 118 CP se simte. Aderenta e dusa la extrem. Nu le recomand celor care vor sa faca drifting.
Ce mai spirit civic. :) Sau uite cam asa poti sa-ti ajuti aproapele :)
Gata m-am hotarit-maine merg sa-mi iau cabrio. :blink:
raspuns pedala de frana la e39 automat
swimmer replied to Similea's topic in Probleme tehnice si rezolvari Seria 5
Se pare ca nu ai lichid de frina in instalatie.
