mi-am luat seria 3 e46 !
HILL DESCENT CONTROL - HDC
83
The principle
HDC is a system that reduces speed on
steep downhill gradients, making your
BMW even easier to control under
these conditions.
Without any intervention on your part,
the car's speed is kept down to about
twice walking pace.
You can activate HDC at speeds less
than approximately 35 km/h (22 mph).
On a descent, the car automatically
reduces speed from under approx.
35 km/h (22 mph) to about twice walk-
ing pace – approx. 12 km/h (7.5 mph) –
and then maintains this constant speed.
You can press the brake pedal or open
the throttle to vary the car's speed in a
range from approximately 5 km/h
(3 mph) to 25 km/h (15.5 mph).
You also have the option of setting a
speed in this range using the +/– but-
tons of the cruise control system.
HDC is automatically deactivated when
the car accelerates to a speed of
approximately 60 km/h (37 mph).
Activating the system
Press the HDC button: the green telltale
light in the button comes on.
The telltale light flashes when the car is
automatically braked.
Deactivating the system
Press the button a second time; the tell-
tale light goes out.
HDC is deactivated automatically when
the car's speed increases to approx.
60 km/h (37 mph) or when the ignition is
switched off.
Using HDC
Cars with manual shift:
Use HDC in first gear and in reverse,
because the engine's braking effect
diminishes in higher gears.
Cars with automatic transmission: you
can use HDC with the selector lever in
any drive position.
In the event of a fault
The telltale light in the button goes out
while HDC is active or fails to come on
when HDC is activated:
HDC temporarily unavailable on
account of high brake temperatures.
The DSC telltale light comes on
as well:
Failure in the HDC and DSC sys-
tem. Visit BMW Service and have the
system repaired.
Din cate stiu eu ii zice HDC - hill descent control si este tehnologia mostenita de la Land Rover din vremurile bune :)
Am patit o data sa ma prinda zapada la Predeal pe niste stradute inclinare si n-a avut niciun efect la coborare, din pacate. Bine...aveam jante de 17 si gume de vara :frantics:
felicitari, frumoasa si dotata. Mie imi place xi-ul, de fapt la masina asta chiar tot imi place, si nr de km :thumbsup:
multumesc ! aseara am fost la un prieten si l-am dat si pe el o tura cu masina asa cum se cuvine. s-a "chisat" pe el si juma de ora i-au tremurat "chicioarele". apoi i-am dat-o si fratelui meu sa mearga cu ea. i-am zis eu cum sa ii dea asa de pe la 4000 in sus. a ramas traumatizat psihic, mai ales ca el isi doreste un BMW de mic si nu are inca. merge foarte bine motorul, pacat de aia care au condus-o inainte ca nu au stiut sa o exploateze corespunzator si sa o intretina pe interior. era jegoasa rau de tot cand am luat-o si exterior si interior. o tineau pe saraca masinuta singurica intr-un colt intr-un garaj subteran prafuita si plictisita, dar acum s-a trezit la viatza cu mare pofta de cox :yahoo:
Edited by rvaler2010
Printre putinele BMW E46 care imi plac. Superba...chiar nu am nimic sa-i bag de vina. Poate faptul ca e benzinara. Dar admir curajul tau.
multam frumos !
tare rau asta ... acum chiar ca te adaug ca prieten :laugh:
cele bune
cele bune
am fost azi cu ea si i-am schimbat/bagat freon. avea 200g si trebuia sa aiba 745+- 25 acum merge perfect. apoi am fost cu ea la un baietas si i-a facut o diagnoza. senzorul de nivel de ulei este ars si eroare la modulul de lumini care nu poate fi stearsa. in rest e ok masina !
prieten ?! - prieten ! s-a facut ! COX
Mai mai ce masinuta avem!:))
Masina fuge tare misto si este f frumoasa!
Imi venea s`o mai alerg jum de ora!:))
multam ! avem tot timpul din lume s-o alergam. de abia astept iarna. sa vad cum se descurca ! am fost cu ea la vali si mi-a sters unele erori si mi-a mai aratat una alta pe la ea. foarte de treaba baiatul. o sa il recomand daca aud pe cineva ! salutare !
maine merg cu ea la ciolpani pentru o verificare a ambreiajului si a directiei - acici cred ca sunt duse bieletele de directie care am inteles ca nu se pot lua decat cu capetele de bara! o sa mai postez dupa ce ma intorc de la mecanic !
salutare !
am fost la mecanic si trebuie sa schimb cate ceva pe la articulatie da cred ca o sa schimb toate bieletele si toate bratele ca sa stiu o treaba. ambreiajul nu mai suporta amanare mai mult de 0 saptamana, maxim doua. o accelerez si se tureaza dar nu se infige. clar este dus, plus ca pe langa faptul ca nu se infige mai si consuma benzina degeaba in plus. de abia astept sa ii schimb ambreiajul sa vad ce reactie o sa aiaba sotia mea cand o va conduce :yahoo:
Vezi sa...aiba vro reactie!!!!:)))))
Foarte frumoasa! S-o stapanesti sanatos si fara incidente!! (mai ales ca avem ...aproape ACELASI nr de inmatriculare!! :laugh: )
salutare !
Fa o treaba buna si schimba tot ce e nevoie la articulatii. Nu fa rabat la calitate, nu o sa iti para rau..in fond in asta consta placerea de a conduce un Bmw :thumbsup:
