ISTA 4.09.13 Standalone / SDP 4.09.12 / ISTA-P 3.63.2.001
In Torrent o sa aveti tot pachetul ISTA-D (diagnoza/programare), ISTA-P (programare) si bazele de date aferente.
Pentru a instala doar ISTA-D trebuie sa bifati din Torrent: ISTA-D , SQLiteDBs si Tools (Pentru cine are ICOM si vrea sa faca si programare cu ISTA-D poate sa bifeze si SDP care se dezarhiveaza si se copiaza in folderul PSdZ din ISTA-D)
Pentru a instala ISTA-P aveti ghidul in folderul Tools - FAQ-EN.pdf iar pentru ISTA-D trebuie doar sa urmati ghidul de mai jos.
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft or Tools folder.
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
BMW 4.09.rar
  • Like 9
am instalat tot pascu pas desi am mai instalat veriuni mai vechi , iap pe windows 10 64 da eroarea asta
are cineva idee de ce? deci visual instalate toate mai putin nu imi apare 2015 dar am inteles ca daca instalezi 2017 dispare 2015 e acelasi . reg rulat registry rulat
Ai copiat si OTHER 4.09.13 din SQLiteDBs?
Am cablu ok. Din Germania.
Imi mergea varianta mai veche de ista Rheingold.
Ista p se conecteazĂŁ am reusit sa ajung pana la faza cu update imi zicea 34 min dar nu i-am dat. Si inpa. Doar asta nu stiu ce are.
Ca sa intelegi...am cumparat pachetul din germania si au venit 3 cabluri. Unul pt bmw mai vechi cu mufa rotundĂŁ unul pt bmw din 99 pana in 2005 si asta ce il am cu care incerc din 2005 pana in 2012.
Cele 2 cabluri pt bmw vechi vin conectate la cablu asta cu care sĂŁ ĂŽncerc.
Posibil sa fie si cablu...doar ca ma gandesc ca daca mergea rheingold merge si ista p si inpa pe windows 10...trebuie sa mearga si asta..
Edited by Keanu
Acel cablu merge la E90 cu INPA. Eu cu cablul acela fac scanari in prezent. Nu cred ca merge cu ISTA..
La F-uri e alt cablu..
Dar altii ma pot contrazice.
ISTA 4.09.20 - DOWNLOAD
SQLiteDBs 4.09.21 - DOWNLOAD
Stii cumva ce modele noi sunt in versiunile de mai sus!?
:drinks:
