Unde gasesc anvelope 245/40 R17 RFT performance?
CAXAP
A venit timpul sa-mi schimb cauciucurile de vara pe Z4 si se pare ca am o mare problema sa gasesc pentru rotile spate 245/40 R17 runflat performance. Nu reusesc sa gasesc nici tu Michelin Pilot Sport 4(S), nici Goodyear Eagle F1 Asymmetric 5, nici Continental SportContact 5 SSR, nimic. Cel mai bun ce am gasit pana acum este Pirelli PZero, care pare mediocru (desi tot mai bune decat Bridgestone RE-050A, de care scap acum).
Aveti idee unde pot sa gasesc totusi ceva mai bun?
Din ce vad pe realoem, pentru E89, 28i, sunt recomandate alte marimi dar poate nu am toate datele problemei...
Oricum, daca te ajuta, indicatiile producatorului sunt urmatoarele:
Anvelope iarna:
01 Goodyear Eagle Ultra Grip GW-3 ROF 225/45R17 91H 4     85452536509
01 Pirelli W 210 Sottozero r-f 225/45R17 91H 4     85452543735     ENDED
01 Bridgestone Blizzak LM-25 RFT 225/45R17 94V 4     85452543347
01 Continental WinterContact TS 810 S SSR 225/45R17 94V 4     85452542528
01 Bridgestone Blizzak LM-25 RFT 225/45R17 91H 4     85452543348     ENDED
01 Bridgestone Blizzak LM-25 RFT 225/45R17 91H 4     85452593650     ENDED
01 Continental WinterContact TS 810 S SSR 225/45R17 91H 4     85452542527     ENDED
  For vehicles with "Runflat" tires
Warehouse material Philippsburg
The flat running distance of the run-
flat
tire has been reduced to 80 km!
The customer is to be informed of this
fact prior to purchase!
01 Dunlop SP Winter Sport 3D ROF 225/45R17 91H 4     85452548143
Anvelope vara:
01 Bridgestone Potenza RE 050 A I RFT 225/40R18 88W 2     85452536362     ENDED
01 Bridgestone Potenza RE 050 A I RFT 225/40R18 88W 2     85452548239
01 Bridgestone Potenza RE 050 A I RFT 225/40R18 88Y 2     85452548236     ENDED
01 Bridgestone Potenza RE 050 A I RFT 225/40R18 88Y 2     85452536363     ENDED
01 Bridgestone Potenza RE 050 A I RFT 225/45R17 91W 4     85452536372
01 Bridgestone Potenza RE 050 A I RFT 225/45R17 91Y 4     85452536687     ENDED
01 Bridgestone Potenza RE 050 A I RFT 255/35R18 90Y 2     85452536586     ENDED
01 Bridgestone Potenza RE 050 A RFT 225/35R19 88Y 2     85452535082
01 Bridgestone Potenza RE 050 A RFT 255/30R19 91Y 2     85452535081
01 Continental SportContact 3 E SSR 225/45R17 91W 4     85452542485     ENDED
01 Bridgestone Potenza RE 050 A Ecopia RFT 225/45R17 91W 4     85452545733     ENDED
01 Continental SportContact 3 E SSR 225/45R17 91Y 4     85452542494     ENDED
01 Continental SportContact 3 E SSR 225/45R17 91Y 4     85452593888
01 Bridgestone Potenza RE 050 A I RFT 255/40R17 94W 2     85452548238     ENDED
01 Bridgestone Potenza RE 050 A I RFT 255/40R17 94W 2     85452536628     ENDED
01 Bridgestone Potenza RE 050 A I RFT 255/35R18 90W 2     85452548240     ENDED
01 Bridgestone Potenza RE 050 A I RFT 255/35R18 90W 2     85452536580     ENDED
01 Bridgestone Potenza RE 050 A I RFT 255/35R18 90Y 2     85452548241
flat
01 Bridgestone Potenza RE 050 A I RFT 225/45R17 91Y 4     85452729188
01 Bridgestone Potenza RE 050 A I RFT 225/40R18 92Y 2     85452729189
01 Bridgestone Potenza RE 050 A I RFT 255/35R18 94Y 2     85452729190
01 Bridgestone Potenza RE 050 A I RFT 255/40R17 94Y 2     85452729193
[...] am o mare problema sa gasesc pentru rotile spate 245/40 R17 runflat performance.
Sunt cativa ani de cand diametrul jantelor creste, de la o generatie la alta. Iar producatori de anvelope de performanta urmeaza acesta tendinta. Deja nu se mai gasesc pneuri moderne si performante pentru jante de 16". Pe de alta parte, gratie progresului, un pneu modern de 16" de la o marca renumita nu pare a fi inferior unui pneu de 16" de performanta, dar de acum 10 ani.  Era de asteptat ca urmatorul diametrul care intra in suferinta sa fie 17".
In lipsa ofertei, singura varianta este sa decizi care dintre atributele "runflat" sau "performance" este mai important pentru tine. Subiectiv, probabil ca te gandesti la "performance". Totusi, analizeaza cu atentie daca merita sa renunti la "runflat". Doar tu stii daca si cat de frecvent utilizezi, pana la limita, capabilitatile pneurilor.
La Z4M E86/E85 nu se utilizau pneuri runflat. Aveai in portbagaj un kit format dintr-un recipient cu un "smac" si un compresor, cu care sa rezolvi o eventuala pana. Si s-a dovedit a fi suficient de bun.
  • De acord! 1
Da, stiu ca diametrul jantelor creste si nu prea mai are nimeni jante de 17 pe o astfel de masina. Insa, pe langa faptul ca am deja jantele si nu sunt prea incantat de ideea sa mai cumpar un set, le prefer pe acestea de 17 pentru confort. Pentru ca, mai ales la ce drumuri avem prin Romania, nici un cm de cauciuc in diametru nu este in plus.
Ce ma mira este ca aceste cauciucuri exista pe site-urile Michelin sau Continental, dar nu si la distribuitorii lor din Romania. Poate stie cineva de magazine din afara care trimit in Romania la preturi decente?
