E60 525d 2008 Coduri de eroare, sa cumpar masina?
neflictus
Salutari
Vreau sa cumpar un E60 din 2008, 525D, 320.000km.
La DPF scria ca mai are vreo 232.000km viața, 240 km de la ultima regenerare, 20 litri combustibil folosiți de la ultima regenerare.
Ambele țevi de evacuare erau negre.
Am pus testerul pe el și a găsit următoarele erori:
Sunt costisitor de reparat ? Sunt grave ?
12 Digital Diesel Electronics
7 errors
4212: 4212 glow plug cylinder 1, control
4222: 4222 Gluehkerze cylinder 2, control
4232: 4232 glow plug cylinder 3, control
4242: 4242 Gluehkerze cylinder 4, control
4252: 4252 Gluehkerze cylinder 5, control
4262: 4262 Gluehkerze cylinder 6, control
480A: 480A particulate filter system
36 Interface box
1 error
D691: Long and / or frequent unlocks (Error_
Unlock
_Long)
5E Gear selector switch
3 errors
E087: Bus communication error CAN
E095: Message Display Transmission data LIN
A830: Reset system incorrect
160 Instrument cluster
1 error
A559: Klemme30g_
f
_Abschaltung
70 Lights Module
11 errors
A8B1: Direction indicator right front 1 defective
A8AB: Dipped beam right defective
A8A9: High beam or right cornering light defect
A8B2: Direction indicator left rear defective
A8C2: E63 / E64 to 09/07, E65: Direction indicator left front 2 defective; E60 / E61 from
03/07: brake light left inside defective; RR US: Turn signal left rear 2 defective
A8C0: Rear running light left defective
A8B5: Brake light left defective
A8AA: Dipped beam left defective
A8BE: Not US, CDN: Rear fog light, left defect; US, CDN: Break Force display on the left
is defective
A8C5: Daytime running lights on the right are defective; RR02: Right side marker
light defective
9CC5: RLS: NoResponse
78 automatic heating and air conditioning
1 error
9C55: fogging sensor
Pai atunci...probabil te atragea pretul, dar asa se fac achizitiile nefericite...
Masina veche ,km multi, intretinere precara, combinatia asta nu e buna.
Eu personal as lua o masina la km astia doar de la cineva pe care l cunosc si care a avut grija de masina la un pret decent.
Altfel nici nu are rost sa ti treaca prin cap sa cumperi.
Edited by Lospaa
Pt inceput, dai jos admisia, cureti ce e de curatat, pui oringuri noi,vezi si egr ul, cumperi releu si bujii.
Apoi vezi cutia, daca a fost schimbat uleiul, nu ma pricep la interpretat erori, dar la km astia daca nu a avut mentenanta, te astepti la probleme.
Vezi discuri, placute, anvelope...astea s 1mie de euro si nici n ai mers cu masina.
Daca are istoric etc si ai ceva bani de bagat,,,dar totusi, masina veche, km destui..tu stii ce buget ai.
  • RedCap changed the title to E60 525d 2008 Coduri de eroare, sa cumpar masina?
Ar trebui definit ok asta, sunt masini SH cu sute de mii de km, nu vor fi noi si ai sanse sa pice ceva. Am avut un amic care a luat acum multi ani  un E46 320i cu vreo 200k km masina era ca noua, dupa 1 luna de Bucuresti a schimbat toata suspensia ( evident era cea originala) dupa inca 1 luna avea ceva erori in final s-a dovedit ca era furtunul de la debitmetru fisurat (imbatranit) altfel masina mergea foarte bine, so masina sh= loterie .Revenind legat de ce ai pus tu poate fi orice acolo, daca ti-a placut sterge erorile vezi ce reapare , DPF in nici un caz nu mai este activ , cum a zis colegul din cauza erorilor nu mai face regenerare .
Edited by alex230ro
