E91 Problema clima, baga aer rece doar la turatie mare
Ok, mergi atunci la cine a montat sa verifice daca e corect montat. Altfel mecanicul cred ca a cautat ca si mine pe google si a primit "If your car's AC blows warm air at idle but cools down when driving, the most likely culprit is a problem with the condenser fan or a low refrigerant level. Other potential causes include a clogged condenser, a faulty compressor, or issues with the expansion valve. "
bonus tot de pe sfantul google , video
Edited by alex230ro
  • RedCap changed the title to E91 Problema clima, baga aer rece doar la turatie mare
