G31 530 Fierbe apa
Prima pornire a masinii cu apa la rece este normala,apa urcand pana la 90 de grade dupa oprire si repornire la scurt timp apa nescazand sub 50 de grade ,in cel mult 5 km urca spre 100 de grade ,radiatoarele si grilele fiind deschise si functionale ,este vorba de un 530 touring g31
  • RedCap changed the title to G31 530 Fierbe apa
Eu nu inteleg problema descrisa de tine. Uite ce am gasit pe Goole legat de asta. Iar acum fiind cald afara e normal sa nu mai scada temperatura atat de repede dupa oprirea motorului.
Normal water (coolant) temperature for a BMW G30 5-series typically ranges from 80°C to 110°C (176°F to 230°F). This range can fluctuate based on driving conditions and the car's cooling system's operation. BMW engines are designed to run at higher temperatures for efficiency and emissions control.
