Valori adaptări cutie
Salutare grup !
Mă poate ajuta cineva și pe mine în interpretarea următoarelor valori ale cutiei automate zf 8 hp de pe f10 b47 2.0D? Mulțumesc
CLUTCH FILL PRESSURES
CLUTCH A -126 mbar
CLUTCH B-48 mbar
CLUTCH C- -4 mbar
CLITCH D - 66 mbar
CLUTCH E- 515 mbar
RAPID FILL TIMES
CLUTCH A -48 ms
CLUTCH B-40ms
CLUTCH C-22ms
CLUTCH D-33ms
CLUTCH E-37ms
Asta zice AI, dar cred ca ai vazut deja...
Based on the adaptation values you provided, your ZF 8HP transmission is generally in healthy shape, with one clear outlier: Clutch E.
Here is the professional diagnostic breakdown of your specific mbar and ms readings:
📊 The Diagnostic Breakdown
Clutch Fill Pressure (mbar) Status / Interpretation Rapid Fill Time (ms) Status / Interpretation
Clutch A -126 mbar Healthy. Well within the normal ±400 mbar range. -48 ms Healthy. Normal adaptation.
Clutch B -48 mbar Healthy. Excellent, tight clearance. -40 ms Healthy. Normal adaptation.
Clutch C -4 mbar Perfect. Very close to factory baseline. -22 ms Healthy. Normal adaptation.
Clutch D -66 mbar Healthy. Excellent, stable reading. -33 ms Healthy. Normal adaptation.
Clutch E +515 mbar 🛑 Problematic. Exceeds the standard ±400 mbar threshold. -37 ms Healthy. The time itself is fine.
🔍 Deep Dive into Clutch E (+515 mbar)
A reading of +515 mbar means the Transmission Control Unit (TCU) has to inject a significant amount of extra hydraulic pressure just to get Clutch E to fill and engage properly. Because the Rapid Fill Time (-37 ms) is normal, the TCU is moving the fluid quickly enough, but it requires much higher pressure to actually compress the clutch pack or hold it.
What Clutch E affects in a ZF 8HP:
Clutch E is a non-rotational brake/clutch that is actively engaged in 2nd, 6th, and 8th gears.
Most likely causes for +515 mbar on Clutch E:
• Internal Rubber Seal Leak: The most common culprit on the 8HP. The internal rubber piston seals or the rubber "mechatronic sleeves/seals" between the valve body and the transmission case are degrading and leaking pressure.
• Friction Plate Wear: The clutch friction material for Clutch E is wearing thin, creating a larger physical gap (clearance) that requires more fluid volume/pressure to close.
• Wear in the Valve Body: The specific solenoid or valve bore governing Clutch E is starting to experience internal wear.
🛠️ Recommended Next Steps
1. Do NOT Reset Adaptations Yet: Never reset the adaptation values in the software without physically fixing a mechanical issue first. Doing so can cause the transmission to slip severely and rapidly destroy the remaining friction material.
2. Service the Mechatronic Seals: If you haven't serviced the transmission fluid recently, the best first step is to drop the oil pan/filter, pull down the mechatronic unit (valve body), and replace the rubber adapter seals (bridge seals) and sealing sleeves. A leak here directly causes high positive fill pressures.
3. Monitor Symptoms: Pay close attention to how the vehicle behaves when shifting into or out of 2nd, 6th, and 8th gears. Look for slight shift flares (RPM spikes during shifts), hesitations, or harsh engagement in those specific gears.
To help narrow down the exact issue, let me know:
• What BMW model and year do you drive, and what is its current mileage?
• Are you currently experiencing any flaring, slipping, or harsh shifts, especially in 2nd, 6th, or 8th gear?
• Has the transmission fluid and filter ever been changed?
Mulțumesc mult pentru răspuns ! Am cerut și eu părerea AI , si mi am dat seama ca e ceva ciudat valoarea aia pe ambreiajul E ,dar nu vreau sa cred ca e cutia prăjită și să mă apuc să desfac fără rost , am postat cu gândul ca cineva ar putea fi avut cam aceeași problemă și M ar ajuta enorm modul de rezolvare 👌
