E bine sa pornim clima/AC imediat cand urcam in masina ?!
eu nu m-am dumirit complet inca, insa in pozele/comentariile de mai jos unii se chinuie foarte mult sa ne convinga ca exista gaze deosebit de nocive in momentul pornirii compresorului de clima odata cu motorul...
foto1 - ACa
"Please open the windows after you enter your car and do not turn ON the air-conditioning immediately. According to a research done, the car dashboard, sofa, air freshener emits Benzene, a Cancer causing toxin (carcinogen- take note of the heated plastic smell in your car). In addition to causing cancer, it poisons your bones, causes anemia, and reduces white blood cells. Prolonged exposure will cause Leukemia, increasing the risk of cancer may also cause miscarriage."
foto2 + 3 - ACb +ACb1
"Acceptable Benzene level indoors is 50 mg per sq. ft. A car parked indoors with the windows closed will contain 400-800 mg of Benzene. If parked outdoors under the sun at a temperature above 60 degrees F, the Benzene level goes up to 2000-4000 mg, 40 times the acceptable level... & the people inside the car will inevitably inhale an excess amount of the toxins."
foto 4 - ACc
"It is recommended that you open the windows and door to give time for the interior to air out before you enter. Benzene is a toxin that affects your kidney and liver, and is very difficult for your body to expel this toxic stuff. "
ca o parere pur personala, la alte marci de autoturisme, cum ar fi Renault Laguna si Skoda Octavia, se indica in mod clar pornirea climei/AC-ului numai dupa scaderea turatiei motorului la normal...
totodata, e imperativa oprirea climei/AC-ului inainte de oprirea efectiva a motorului...
sa vedem opiniile specialistilor in domeniu... oricum, dupa textele dintre "ghilimele", te imbolnavesti de toate bolile posibile... inclusiv de paranoia <_>
scopul topicului este de a face distinctie intre adevar si fictiune, in ceea ce scrie mai sus...
1. Nu vad legatura. Compresorul de clma porneste in momentul cand apesi butonul, deci gaze toxice tot baga chiar daca apesi butonul mai tarziu.
2. Nu cred ca cei de la BMW erau asa idioti (la unele masini este setata clima sa porneasca exact in acelasi moment cu contactul)
Benzenul se regaseste prin plasticul folosit in masini. Daca masina sta in soare sau e foarte cald inauntru, plasticul ar putea emana benzen in habitacul (mirosul de plastic incins pe care-l cunoastem). Acelasi lucru se intampla si cu sticlele de suc/apa laste in soare (i.e. prind gustul ala de plastic). Si cum traseele de climatizare sunt din plastic ei zic ca nu faci decat sa bagi tot benzenul ala in masina, si implicit sa te umpli de cancer din cap pana-n picioare.
Plauzibil, dar nu cred sa mai existe ceva care sa nu fie considerat cancerigen in ziua de azi.
Edited by _eof
Foarte interesant explicatia ta.
Insa, daca ai porni AC-ul dupa sa zicem 15 mintue de mers cu masina, conductele de la AC nu ar mai fi asa de calde, nu ar mai emana benzen d'ala ? Eu cred ca da, doar daca nu le raceste ceva...
Cica sa lasi putin usile deschise sa iasa afara chestiile alea toxice.
Recomandarea unor fabricanti privind pornitul aerului conditionat cu intarziere nu are legatura cu toxinele, ci cu intratul motorului intr-un regim normal de functionare.
Nu stiu. Mie mi se pare o tampenie treaba asta (pe motiv ca oricum o sa mor de cancer asa ca de ce sa mor de cald in masina), dar presupun ca ei s-or fi gandit ca daca mergi cu geamurile lasate putin timp se aeriste habitaclul si se duce benzenul.
Oricum cred ca "pericolul" e mai mare la ei, in Abu Dhabi, unde vara e mult mai cald ca la noi, si deci masinile se incing mult mai mult.
Stiam ca "nu e bine" sa pornesti AC-ul imediat ce ai pornit motorul. Ci intai ventilezi normal cu geamurile deschise si apoi pornesti AC-ul.
Insa asta are legatura cu fortarea AC-ului, nicidecum cu gazele.
Asta este parerea mea, nu sunt specialist.
Sunt curios cine este specialist in AC-uri (si aici ma refer la ingineri nu la ciumpalaci care schimba freonul si se dau cunoscatori).
Daca la masinile noi cu Ac manual sa zicem ca depinde de noi, la cele care au clima se poate programa sa nu porneasca imediat compresorul. Si totusi la toate masinile care au clima porneste furnizarea de aer conditionat odata cu pornirea motorului . De ce nu o fac producatorii din fabrica? De ce trebuie sa-mi pierd eu timpul aiurea la fiecare pornire sa opresc AC-ul, sa las geamurile jos si asa pline de praf sa le mai zgarii putin, sau sa opresc AC-ul la fiecare oprire a motorului? In plus de asta, trebuie sa mai murim si noi de ceva! Edited by rmg
Eu cand a stat masina la soare o perioada indelungata,intru in ea ,o pornesc,dau drumu la aer,ies din masina si stau cam un minut apoi intru si plec.Asta se intampla evident daca nu ma grabesc.Nu suport aerul ala fierbinte cu miros greu care se formeaza cand sta masina la soare.Vad de altfel ca e si daunator
nu cred ca AC-ul in sine e o problema. adica nu cred ca problema e daca sa pornesti sau nu aerul imediat ce urci in masina, dar important e sa deschizi usile/geamurile sa aerisesti. daca in timpul asta dai drumu si la clima, e treaba ta, dar e o risipa...
cu sau fara benzenul ala, e mai eficient sa racesti masina (spre temperatura exteriorului) deschizand geamurile decat pornind clima. dupa cateva minute, cand temperatura in masina se apropie de cea de afara, abia atunci inchid geamurile si pornesc clima (ca sa scad temperatura mai jos decat cea de afara)
Si atunci, cu Auxiliary Ventilation cum e?
La mine clima e pornita constant pe 21 de grade. Nu o opresc inainte de a opri motorul si nu o pornesc dupa ce merge motorul un pic.
De ex., acuma mi-e setat Timer 1 la ora 16:35, stiind ca azi plec de la birou pe la ora 17.
Deci, daca geamurile sunt inchise si va porni ventilatia, cu clima "activata", ca sa zic asa... dau in cancer pe racoare?
interesant topic ...Si daca tot vb de sanatate presupun ca nu multi stiu ca incalzirea mancarii la microunde in recipiente de plastic degaja Dioxina si provoaca doar cancer <_< Ca urmare ar trebui incalzit doar in sticla !.Aviz biberoanelor :) Deci zi de zi facem lucruri mult mai nocive pt organism decat pornirea climei odata cu motorul !
la fel de oprit cu 2-3 minute ĂŽnainte de oprirea motorului.
asta e pt uscarea condensului si pt evitarea formarii bacteriilor !.Se lasa aeroterma cateva minute pt a usca traseul , cu ...compresorul decuplat
Eu nu am facut asta niciodata .nu am rabdare , Plus ca daca opresti AC te coci in masina
Edited by myxage
