Problema Imobilizator
Hila
Am schimbat duminica trimurile la masina ,la trimul central eu aveam un led rosu care e un tip de buton de la imobilizator este cel dintre butonul de avarii si inchiderea masini,alarma este OEM am si cartea de instructiuni,in fine ieri am vrut sa plec cu masina dupa 2 zile si bateria moarta habar nu aveam cum sa deschid usile ,am reusit sa pornesc masina iar astazi am descoperit buba este piesa cu tepi care ma lasat fara baterie.
Problema este ca acum cand inchid si deschid usile la masina nu se mai aude acel sunet -bip- la inchidere si deschidere,am sa masor bateria ca sigur nu este incarcata la capacitate maxima este posibil sa fie asta,masina porneste la sfert doar ca nu mai bipaie alarma ,ea functioneaza perfect am lasat geamul deschis si dupa activare incepe si urla deci functioneaza .
Sfaturi!
Sfaturi!
Nimeni?
Am gasit si un manual eu il am pe cel al masini BMW asta e putin diferit chiar nu mai are nimeni alarma asta ?
Rares ai dreptate ,scuze dar nu am dormit deloc ,si am 1000 de draci! Este alarma originala!
Edited by gabriel_525
CAR MEMORY OPTIONS
Anti Theft System (DWA)
(available only on vehicles with DWA Alarm System)
Interior sensor =active
not active
Tilt Alarm Sensor =active
not active
Arm/Disarm by
means of:
remote control
=locks and remote control (FZV)
􀁞􀁜􀁚􀁟􀂴, 75
Arm/Disarm
Acknowledgment
Disarm visually Disarming of the DWA system is
confirmed by a brief blinking of turn
signals when active.
􀁞􀁜􀁚􀁟􀂴, 75
Disarm audibly Disarming of the DWA system is
confirmed by a brief siren signal when
active.
􀁞􀁜􀁚􀁟􀂴, 75
Arm visually Arming of the DWA system is confirmed
by a brief blinking of turn signals when
active.
􀁞􀁜􀁚􀁟􀂴, 75
Arm audibly Arming of the DWA system is confirmed
by a brief siren signal when active.
􀁞􀁜􀁚􀁟􀂴, 75
Arm visually,
doors/lids closed
E46, E52 only
by a brief blinking of turn signals as soon
as hood/trunk are closed, when active.
Arm audibly,
doors/lids closed
E46, E52 only
by a brief siren signal as soon as
Acknowledgment
without DWA
(E46 only)
active
=inactive
If “active” is selected, locking/unlocking of
a vehicle is confirmed by a brief blinking
of turn signals.
Note: fault code “07 anti-theft alarm
system” will be set in the GM module.
􀁞􀁜􀁚􀁟􀂴: E38, E39, E46, E52, E53 from ‘99 Model Year; 75: E38, E39 prior to 9/98
Am last-o si tot nu bip-aie,inainte si daca lasam geamul deschis sau o usa nu eraq inchisa bine piuia de 2 ori si a 3 oara facea o alta tonalitate!
Am citit bine manualul si spune ca sunt chestiuni care se pot activa la un service BMW ,cum ar fi volumul sirenei de la off la nivelul 15 ,controlarea circuitului (daca lasi un geam sau usa deschisa)si avertizarea prin semnal sonor,etc,acum ma intreb de la caderea de tensiune avuta sa treaca pe off singure astea?
P.S Multumesc Ciupa pt faza cu usa ,stateam ca boul de 5 minute in fata masini si ma gandeam care geam sa-l fac zob!
Şi eu am alarma originală dar nu scoate nici un sunet la armare sau dezarmare.
Alarme auto...offffffffffffffffffffffffffffffffff....tocmai ce mi-au jacmanit baietii indieni masina acum 2 seri..au fost subtiri...mi-au luat doar proiectoarele (au spart bara) si oglinda de la sofer ...asta s-a intamplat in conditiile in care pe masina am alarma asta vestita de fabrica....s-a dovedit a fi de forma (alarma)....oricum...dupa evenimentul asta m-am hotarat sa-mi pun ceva un pic mai serios dar nu extraordinar de scump...am dat 100 de euro pe un Carvox cx999 cu pornire motor si 2 pagere...poate poate il prind pe tigan cu mana acolo (doamne ajuta!)...acum...ce vreau sa va intreb?...aveti vreo contrarecomandare in privinta instalarii kitului de porire a motorului din pager?...adica ar putea afecta ceva cumva ,prin calculatoarele masinii, kitul ala (defapt bypass-ul ala)...ce parere aveti?...vreau sa instalez si kitul ala pentru a-l folosi in scopul invers scopului sau constructiv (si anume oprirea motorului din pager in situatia furtului - alarma are si optiunea asta)....
uitasem 520i E39 1997
Edited by Cosminas
Nu am mare ĂŽncredere ĂŽn alarma OEM. :)
Am pe cineva bun in constanta care mi-o instaleaza...mi-a spus ca-i trebuie aprox 8 ore ca s-o instaleze asa cum trebuie...sper sa fie bine ...alarma are o sumedenie de setari si presetari de toate felurile + senzorul ala "magic" pe microunde...marti dimineata ma duc la el s-o instaleze ...am sa postez rezultatele...
http://bmwfans.info/parts/catalog/E39/Tour...s/#alarm_system Ai aici alarma oem a masinii,daca seamana cu ceva de aici este daca nu... nu ! Sirene trebuie sa fie in partea dreapta a masinii sub aparatoarea de noroi de la roata din spate
ÂŞi eu am alarma originalĂŁ dar nu scoate nici un sunet la armare sau dezarmare.
Iti recomand sa te folosesti doar de alarma si celelalte functii ale ei,nu folosi pornirea din telecomanda,degeaba mai ai ews-ul ! Daca ai computerul acela in bord poti folosi optinea CODE si nu mai porneste fara sa bagi acel cod .
