Vadim
Everything posted by Vadim
  1. Am sa incep eu : E34/525i/11.1990/M50 engine
  2. Sa vedem cati posesori de seria 5 sunt pe aici
  3. Ai verificat daca nu e infundat radiatoru ?
  4. Ma refer la sonda care masoara temperetura din motor , k poate e defecta aia si iti zice pe bor k motoru fierbe si el sa nu aiba nimik :blink: P.S. iti pierde apa ?
  5. :blink: totusi daca zici k iti merg toate ai verificat sonda daca e buna ??
  6. Ciudat :blink: , ce inseamna k se incalzeste ? adik unde ajunge acul ?
  7. Ai schimbat motoru ? :blink: Ai verificat daca iti merge ventilatorul auxiliar ???? sau daca iti merge cum trebuie vascocuplaju' ?
  8. SA o stapanesti sanatos si fara incidente :blink:
  9. Vadim
    Obc
    Nu stie nimeni ??? :blink:
  10. Vadim
    Obc
    pin1: violet/green/yellow, alarm system = MERGE MONTAT LA ALARMA PE CARE O AM ACUM ?? SI DACA DA CE FACE? pin10: black/green, starter pin6: + from fuse F17 pin9: + from fuse F20 (red/yellow) pin8: + from fuse F1 pin22: grey/red, light switch pin25: yellow/red, turn signal switch pin3: white/yellow, diagnostics pin16: white/violet, diagnostics pin14: white/grey, instrument cluster pin7: black/white, instrument cluster pin4: ground pin5: blue/red/yellow, temp sensor pin20: black/red/yellow, pre-ventilation = ASTA E WEBASTO pin21: black/white, pre-ventilation = IDEM 20 pin23: violet/white/yellow, alarm system = IDEM 1 pin17: red/grey/yellow, alarm system = IDEM 1 pin26: black/red/yellow, fuel tank level sensor pin12: brown/violet, fuel tank level sensor pin11: white/black, DME pin24: black/violet, DME pin19: white/red, chimes pin18: white/blue, chimes pin15: white/brown, radio = MERGE MONTAT LA RADIOUL PE CARE IL AM ACUM SI DACA DA CE FACE ? pin2: blue/brown/yellow, radio = IDEM 15
  11. Parca i sta mai bine argintiu :blink:
  12. Vadim
    rivalii lui m6
    Mai putin M6 :) :) :) :D :D
  13. m am uitat in cartea tehnica si nu scrie cate kg are fara motor cutie si cardan :blink:
  14. Vadim
    rivalii lui m6
    M6 nu are rivali :blink:
  15. Iese vre o 170 000 eu :)
  16. Nu eu :blink: Iote : Dupa cum ziceam in urma cu cateva zile, am comandat o parghie de semnalizare din Germania, cu buton pt BC, pentru a realiza un retrofit BC. L-am instalat azi, asadar iata prezentarea “lucrarii” Costuri : 50 Euro Parghia de semnalizare 15 Euro Posta pana in Romania 9 Euro comision western Union 600.000 RON Activarea BC la o reprezentanta BMW Costurile realizarii retrofitului la reprezentanta se ridica la 400 Euro.
  17. :blink: si mai zici k atunci cand lasi masina in service o lasi pe maini bune :)
  18. la e34 au fost cateva care nu au fost prewired :blink: ( MuadDib stie )
  19. Poate te ajuta asta , la e34 are un surub langa cilindrul 6 Succes
  20. e la radiator , parca e albastru :)
