Vadim
Everything posted by Vadim
  1. Vadim
    Mufa ciudata
    E na :blink: pai masina merge perfect :) sau daca nu e conectata sonda lambda ce sintome ar trebuii sa aiba ?
  2. Visiniu sau verde inchis
  3. Succes in continuare :blink:
  4. Mufa respectiva se afla pe sub motor :blink:
  5. Ieri dupa ce am schimbat un bec la pozitie(fata) si unu la pozitia(spate) , am observat k nu se mai aprind farurile de ceata (fata) :blink: . Pe urma ma urc in masina , pun contactu iar pe cc imi scria : Trailer Lights( nici nu am carlig de remorcare ) , Low beam(abia schimbasem becul) , F/fog lights( :) ) Oare sa fie pe duca Lkm -ul ?
  6. Imi da in nas exact cand schimb viteza Poate sa fie din cauza ca am spalat motoru ? :blink:
  7. Mie imi mai da in nas cand ii schimb viteza nu tot timpu :blink:
  8. La e34 merge pusa o minune d'asta technoligica ? :blink:
  9. Talentatule :) pana la urma cum le ai facut ? :)
  10. Vadim
    POZE BMW E34
    Este super masina :blink: u ai vopsito de curand ? si daca da cam cat te a costat :)
  11. Vadim
    POZE BMW E34
    OBC --- pin1: violet/green/yellow, alarm system = merge legat la alarma care o am acum ? si daca da ce face chestia asta ? pin10: black/green, starter pin6: + from fuse F17 pin9: + from fuse F20 (red/yellow) pin8: + from fuse F1 pin22: grey/red, light switch pin25: yellow/red, turn signal switch pin3: white/yellow, diagnostics pin16: white/violet, diagnostics pin14: white/grey, instrument cluster pin7: black/white, instrument cluster pin4: ground pin5: blue/red/yellow, temp sensor pin20: black/red/yellow, pre-ventilation = asta vrea sa fie webasto ? pin21: black/white, pre-ventilation pin23: violet/white/yellow, alarm system pin17: red/grey/yellow, alarm system pin26: black/red/yellow, fuel tank level sensor pin12: brown/violet, fuel tank level sensor pin11: white/black, DME pin24: black/violet, DME pin19: white/red, chimes pin18: white/blue, chimes pin15: white/brown, radio = merge legat la radio care il am acum si daca da ce face ? pin2: blue/brown/yellow, radio
  12. Vadim
    POZE BMW E34
    Cred k poti sa ti pui bord cu lcd :blink: dar o sa l folosesti doar pentru obc( daca iti pui) si Km :) P.S. uita te daca de la firele obc ului pleaca urmatoarele fire : pin14: white/grey, instrument cluster pin7: black/white, instrument cluster ; daca da cred k o sa ti afiseze pe lcd , daca nu pleaca le poti trage u
  13. Daca troncane , si cateodata scartaie , este amortizoru :blink: cel putin asa a fost la mine
  14. Vadim
    Viteza ucide
    :blink: Asta trebuie sa le dea un pic de gandit celor care merge cu 200 km/h prin orase sau drumuri nationale
  15. E90 , pt k este o masina cu un design mult mai atragator , si sa nu mai zicem de gadgeturi :blink:
  16. Mi am pus de curand o maneta de stergatoare care are pe ea o sageata spre bord si un S langa (pe maneta se poate apasa k la aia pentru BC) Stie cineva pentru ce este comanda asta ?
  17. :blink: in mai am schimbat o :) :) :)
  18. EU PUN IN FIECARE ZI APROAPE UN LITRU :blink:
  19. Mie nu mi fierbe motoru :) pompa de apa am puso prin mai . Am incercat in urmatorul fel sa vad daca pierde apa : Am lasat motoru pana a ajuns acu la jumate , am deschis capota am turato putin , si nimik , nu pierde pe nicaieri :blink:
