P.Dan
Everything posted by P.Dan
  1. Ok mersi, o sa incerc maine. Ma poti ajuta cu un part number de pe real oem? Eu am cautat dar nu stiu care este. Am gasit asta http://realoem.com/bmw/showparts.do?model=DD11&mospid=47537&btnr=64_0676&hg=64&fg=18. Seria de sasiu e BN06147. Mersi
  2. Salut, Astazi am observat ca a inceput sa se auda un sunet din zona elicei/vasco. Initial am crezut ca atinge ventilatorul carcasa de plastic de protectie. Zgomotul se aude si la relantiu si cand turez putin motorul. Daca aveti idee despre ce ar putea fi vorba si ce piesa ar trebui schimbata va rog sa raspundeti. Multumesc
  3. Salut, ceva gume de vara 225/55/16 cu profil in V gen goodyear eagle F1 ai?
  4. Sau aici >>> http://www.youtube.com/watch?v=afAcE_DjwSY
  5. Nu cred, trebuie facute ceva modificari(nu stiu exact ce presupune asta), apoi dupa ce ai pus maneta OBC trebuie activata!
  6. Aici e mai detaliat Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following function s nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings
  7. Nici eu nu am computer de bord. Pe semnalizare nu am acel buton de BC. Poti afla consumul si diferite chestii din meniul ascus. Tii apasat pe butonul de resetare kilometraj partial pana apare test> mergi la TEST_19, astepti pana apare OFF si apesi iar butonul de reset, mergi apoi la TEST_05 si iti afiseaza consumul.
  8. Mai multe detalii.... CCFL sau LED, garantie, etc
  9. Exact. Piesa 5 de aici: http://realoem.com/bmw/showparts.do?model=...hg=31&fg=05
  10. Salut m-a costat total cam 800 lei bucse bascula lemforder 130 lei/set bucse bara stabilizatoare 60 lei/set bielete stabilizatoare fata 150 lei/set bielete directie 120 lei/buc burduf 30 lei/buc MANOPERA 150 lei fara unghi de fuga.
  11. Se poate inchide topicul. Problema s-a rezolvat schimband: -bucsele de la bascula -bucse bara stabilizatoare fata -bielete stabilizatoare fata -bielete de directie + burduf Nu se mai simte nicio trepidatie in volan (nici la franare).
  12. Daca ai avut cass + mid (din 2 bucati) atunci poti sa pui fara nici o adaptare. Trebuie numai sa gasesti CD playerul cu tipul de mufa care ai tu (probabil cu pini drepti). Mai este un model, care s-a pus pe prefacelift cu pini rotunzi. Daca ai avut modelul dintr-o singura bucata atunci va mai trebui tras un cablu pentru MID. Am vrut si eu sa fac aceasta modificare dar am abandonat, poate reusesc sa pun un Dynavin. Am cumparat mid-ul dar nu am reusit sa-l montez.
  13. Salut, As dori sa fac urmatoarea comanda: 31129068753 - 130 lei/set/lemforder (1 set) 31351093108 30 lei/buc/topran (2 buc) 31351095662 75 lei/swag (2 buc) Trimite pe PM costul total (piese + transport) si contul in care sa virez banii. As vrea sa stiu aprox cam pe cand ar ajunge piesele. Merci!
  14. Probabil ar trebui sa faci o polishare a farurilor, daca acestea sunt matuite. Ori, cealalta explicatie ar fi ca sunt lupele murdare pe interior.
  15. Asa bat si la mine, cum ai figurat tu cu galben. Cum e cu albastru asa lumineaza becurile fara xenon. In concluzie, regleaza-le la cineva care se pricepe. http://www.dxhid.com/fx_r_Bi_Xenon_Hid_Xen...s_Projector.jpg
  16. Viper 350 responder am eu si nu am avut probleme pana acum. Raza de actiune e destul de mare, iti monteaza o antena undeva pe la oglinda pentru extinderea razei. Te avertizeaza pe telecomanda daca este cumva declansat vre-un senzor. Daca lasi geamurile deschise, in momentul in care armezi, geamurile se ridica automat. E o alarma buna, la un pret bun.
  17. Eu am luat de la userul grozadan. Este noua si OEM. Nu are rost sa te complici cu dezmembrari. Cauta pe realoem.com codul
  18. Salut, imi poti spune si mie BN06147 . Merci fain!
  19. Nu te supara, dar la unele piese ai niste preturi mult prea exagerate. Numai de bine!
