phantom
Everything posted by phantom
  1. Verifica intercooler-ul,sigur ai radiatorul spart.Daca are ulei pe el este spart.
  2. Partea electrica de l-a pompa de injectie+avansul blocat.
  3. Arata bine.Ai schimbat doar acele?Ai pus ceasuri de M pe 530d?
  4. Precizes ca utilizarea meniului secret este responsabilitatea fiecaruia.Functia 19 activeaza meniul secret si 21 sterge totul.Odata ajunsi la funcatia 21 trebuie sa fiti rapizi, caci aceasta anuleaza bc-ul.
  5. 1. Hold Trip Reset while turning ignition key to On position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/2 second and release it 5. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Acticates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in litres since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolent/Engine temperature (2.1C) koelvloeistof-temp. 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+ ? 9.2 074_78+ ? 9.3 0011+ ? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test
  6. Din cate imi aduc aminte e la fel ca la seria 3.
  7. Arata foarte bine masina.Sa o porti sanatos.
  8. Pur si simplu,superba.Felicitari si mult succes la finalizarea proiectului.
  9. phantom
    burn out
    iti explica maestrul http://www.youtube.com/watch?v=yAwJsOECGBU
  10. Ce fel de motor ai?Common rail sau cu injectie directa?Daca e cel cu injectie directa ai "celebra" pompa care se blocheaza avansul.Au fost montate si pe audi A6 2.5 tdi, opel si ford.Dupa 200.000 km pica toate.Este doar o parere.
  11. Am avut un 525tds automat si l-am dat pe la 400000 de km din care vreo 250000 de km i-am facut eu.Nu am avut probleme cu el.Important este sa nu pui motorina de locomotiva,daca ai posibilitatea sa o cumperi mai ieftina.
