Butzy
Everything posted by Butzy
  1. Ce mai topic BMW sau Audi. Intreaba asta pe forum la Audi si vezi care iese invingator.
  2. http://i1006.photobucket.com/albums/af184/butzyovidiu/Dimensiune_Cauciuc_in_Functie_de_J_zps0035b91e.jpg Te incadrezi perfect la minimum
  3. Te referi sa nu mai fie nevoie sa intri din meniul ascuns sau... ?
  4. Pacat, mare pacat R.I.P Cel mai tare ma oftic ca nu o sa mai apara seria de fime NFS . Si chiar daca ar mai aparea nu cred ca ar mai avea acelasi farmec fara Paul Walker - Brian O'Cconner
  5. Urmeaza pasii de aici ti-am dat pentru toate functiile. !!!!! PLEASE BE CAREFULL IFYOU CHANGE ANY SETTINGS !!!!! ========= Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the followingfunction s ========================================== BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Rightsensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used; 11 Not used; 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, keyinserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SIreset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp;5) seat belt lamp; 6) manipulation dot 16 Not used; 17 Not used; 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test Uite si un video http://www.youtube.com/watch?v=ImCUQjmMhfM
  6. Temperatura poate sa o verifice si pe BC in meniul ascuns la 7.0 chiar e mult mai bine ca vede exact la cate grade urca.
  7. Ai schimbat si termostatul EGR, ai facut aerisirea cum trebuie, si vezi ca la cele automate mai exista un termostat http://www.realoem.c...141&hg=17&fg=05 piesa 4.
  8. Butzy
    E46 320d
    De unde le-ai luat ?
  9. Butzy
    E46 320d
    Clar doar ca ti-am dat un exemplu ca nu poti sa defaci orice Si vezi ca la tubulara de 36mm iti mai trebuie si adaptor pentru clicket de la 1/2 la 1/1 Apropo cat ai dat pe inelele MDF si pe cat sunt 16,5 sau 13 ?
  10. Butzy
    E46 320d
    Ai fi umit dar capacul de la filtru de ulei cand faci revizia nu o sa ai cu ce sa il desfaci acolo trebuie tubulara de 36mm si tu in trusa ai maxim de 32mm
  11. Termostatele sunt duse, ca sa fi sigur ca si cel de EGR e dus il dai jos sufli in el si daca aerul trece ca pintr-o teava foarte usor e stricat, daca trece foarte greu e bun. In cazaul in care e stricat si il schimbi si daca ai noroc o sa iti urce apa la 90 de grade indiferent de vreme si de ce viteza ai, dar slabe sanse, oricum o sa mai creasca vreo 20 de grade daca e si cel prinipal stricat. Mai mult ca sigur trebuie sa le schimbi pe amandoua. De preferat pe viitor e sa spui si pentru ce masina, motorizare.
  12. Daca ai dat 400 de lei de atat a tinut 1.200 asta e pretul pentru o fulie originala sau 700 pe Corteco.
  13. Butzy
    E46 320d
    Pe spate atunci ?
  14. Butzy
    E46 320d
    Am crezut ca ai deja 4 difuzoare Focal? Ce difuzoare ai acum pe fata?
  15. Butzy
    E46 320d
    -pe partea de sonorizare: difuzoare fata Focal 165A1 + subwoofer JBL CS1215B + amplificator MAC Audio MP4500 cu amplificatorul asta dai si in difuzoare si in subwoofer ?
  16. Se potrivesc cumva pe spate difuzoare ovale ? Pot sa si decupez dacĂŁ e nevoie
  17. Cat costa doar insonorizarea ?
  18. Daca e vorba de FL M47N intradevar o pompa noua costa 4200 pe original dar daca e vorba de NFL M47 atunci costa 6990 tot pe original.
  19. F30 unde e ?
  20. Imi explica si mie cineva despe ce e vorba ?
  21. I8 asta e un nume de concept pe care poate sa il foloseasca orice producator auto ? Ca nu inteleg BMW i8 si Audi i8 ???
  22. Merita din plin, arata foarte spectaculos.
  23. Normal ar fi sa nu atinga nici cu 225/55/R16 dar iti ating din cauza ET-ului care nu e compatibil cu E46, Jantele astea au ET20 e mult prea mic pentru E46, ET35 e minimum care merge pe E46.
  24. Presupun ca e un motor de 2 litri, bine ar fi sa specifici si pentru ce masina.
  25. Sa stii ca nu era nevoie decat sa stii datele din buletinul mamei tale le aflai prin telefon, atunci cand ai facut contractul de vanzare cumparare. Acum cu noua taxa de mediu sa nu te puna astia sa o platesti daca nu ai platit-o in caz de vrei sa o treci pe numele unuia din parinti, aaa si sa iei in calcul ca daca unul din parinti are deja o masina pe numele lui sa nu o mai pui si pe a II-a ca o sa dai mai mult la Impozit de data asta ca se considera lux.
