neospazz
Everything posted by neospazz
  1. http://www.bmwclub.ro/forums/topic/135276-cumpar-cumpar-janta-16-style-43/page__pid__2000304#entry2000304
  2. Va multumesc,am gasit pe realoem.scrie 3,5x1,8. Deci 3,5, nu?
  3. Va salut! Stie cineva ce diametru interior au furtunele de vacuum? 4mm? E46 318i nfl,m43. Multumesc!
  4. Salut!ce pret au cele 3 jante?fara cauciucuri
  5. VIN WBACE51090EN59055 Type code CE51 Type 320I (EUR) E series E36 (3) Series 3 Type TOUR Steering LL Doors 5 Engine M52 Displacement 2.00 Power 110 Drive HECK Transmission MECH Colour MONTREALBLAU METALLIC (297) Upholstery STOFF KLEE/ANTHRAZIT (D6AT) Prod.date 1995-06-21 Close Options Code Description (interface) Description (EPC) S240A LEDERLENKRAD Leather steering wheel S243A AIRBAG FUER BEIFAHRER Airbag for front passenger S246A LENKSAEULENVERSTELLUNG MECHANISCH Manually adjust. steering column S320A MODELLSCHRIFTZUG ENTFALL Deleted, model lettering S410A FENSTERHEBER, ELEKTRISCH VORN Window lifts, electric, front S441A RAUCHERPAKET Smoker package S498A KOPFSTUETZEN IM FOND Headrests, rear, mechanically adjustable S510A LEUCHTWEITENREGELUNG ABBLENDLICHT Headlight aim control S520A NEBELSCHEINWERFER Fog lights S534A KLIMAAUTOMATIK Automatic air conditioning S556A AUSSENTEMPERATURANZEIGE Outdoor temperature indicator S570A STAERKERE STROMVERSORGUNG Reinforced power supply S687A RADIOVORBEREITUNG Radio preparation L814A ITALIEN-AUSFUEHRUNG NATIONAL VERSION ITALY S855A SPRACHVERSION ITALIENISCH Language version Italian Code Description (interface) Description (EPC) S928A REIFENSTEUERUNG Tire control
  6. Daca ti-a ajuns wd40 pe evacuare de acolo iese fum,cand se incalzeste.evacuarea e prinsa de motor acolo sub bujii.
  7. Am avut problema cu releele de la modul si pana sa le schimb am crezut ca este broasca de la sofer de vina,ca usa aia avea probleme cu descuiatu.am vrut sa iau o broasca second de la cineva si cand ii conectam mufa,usile si trapa se deschideau automat (era defecta). Deci de la broasca de la sofer este problema.e46 318i nfl
  8. Ai incercat sa stergi apoi eroarea din tester?
  9. Cand ai dat geamul de la trapa jos, erau in regula cele 4 cleme de la partea interioara (panou) si driver-ul? Pozitia corecta a driverului este intre cleme. Pe partea soferului sa te uiti
  10. Imi poate spune cineva despre ce senzor este vorba?influenteaza negativ mersul motorului?va multumesc!
  11. Poti sa-mi spui pe realoem despre ce piesa este vorba? Ar trebui sa apara eroare si la tester?mersi!
  12. Salut! Am si eu o problema cu indicatorul de temperatura al apei. Indicatorul creste si ramane la mijloc. Daca opresc masina si o pornesc apoi, indicatorul este la minim pe albastru si in cateva secunde dupa ce pornesc urca iar pana la jumatate (nu indica corect dupa pornire temperatura apei). Cateodata o pornesc si imi indica corect temperatura,acul fiind la jumatate. e46 318i nfl
  13. Salut,trusa de scule din portbagaj mai este?ma intereseaza toata in afara de cheie roti si carlig remorcare.mersi!
  14. conform http://www.rubmw.ru/vincode/eng/, ai climatronic. Vezi ca pe aerisirea centrala,ai o rotita cu puncte albastre si rosii (unu doua sau trei). Seteaz-o pe 3 puncte rosii (cald) si vezi daca iti baga caldura cu mai putine grade setate
  15. Schimba-le intre ele si vezi daca se deschide cel din stanga,dupa schimb,e butonul defect
  16. Si mie imi face acelasi zgomot. Din aia de mijloc e problema, da usor cu pumnu in ea si vezi ca ea face zgomot. Cel putin la mine asa este. e46 318i nfl
  17. Am incercat se deschid trapa manual,cu acel imbus de la motoras si merge perfect,se trage tot geamul.Am inchis-o din buton si a mers. Daca vreau sa o dschid din buton merge doar 10 cm si se opreste. Cineva vreo idee?multumesc!
  18. Va salut!Am un e46 sedan nfl si am o problema cu trapa.Aveam toate cele 4 cleme rupte de la panoul din interior si trapa se tragea sub plafon doar o palma.Am schimbat toate clemele si este acceasi problema.Se trage doar putin.Pe pozitia in care se ridica geamul,merge perfect.Panoul merge si el acum in urma schimbarii clemelor,il pot impinge pana in spatedar se misca putin cam greu.Am uns cat am putut cu wd40.Toate piesele le-am montat cum trebuie,am urmat un diy.Daca aveti idei,astept orice sfat.multumesc!
