florincosta
Everything posted by florincosta
  1. La BMW ROAD MAP EUROPE PREMIUM 2017-1 am citit urmatoarele info---Benefits Additional features such as the Falk Travel Guide, Guided Tours, 3D objects, 3D city models and satellite images (for cars from 09/2009) provide much useful information and amenities for your trip planning; Traffic Message Channel (TMC) function is currently available in the following countries: Germany, Austria, Switzerland, France, Great Britain, Italy, Netherlands, Belgium, Denmark, Spain, Norway, Sweden and the Czech Republic; Free TMC service is not available in all countries; For the reception of the encrypted TMC-service BMW offers country-specific to a BMW Connected-Drive contract; List of BMW Service; POI database with 32 categories. hartile cu satellite images ar trebui sa arate ca cele din google maps?
  2. Cu siguranta voi face un DIY.deocamdata doar am adaugat 601 in FA si codare cic pentru functia tv dar mi-a disparut asistenta la faza lunga,am reactivat-o din codari dar curios lucru nu mai functioneaza ca si pana acum,ma refer la actionarea in stanga pe auto a butonului de lumini,acum merge cand dau in dreapta pe a doua pozitie{faza scurta} si se aprinde semnul verde cu auto.cum sa-l fac sa mearga pe auto?
  3. Astept box-ul airplay intre timp am luat aceste mufe {dau link poate ajuta alti colegi} http://www.tme.eu/ro/details/tv-tuner_bmw/adaptoare-aux/4carmedia/ http://www.tme.eu/ro/details/80290/conectori-car-audio-carcase-si-mufe/4carmedia/ http://www.tme.eu/ro/details/800001/conectori-car-audio-carcase-si-mufe/4carmedia/ sper ca sunt cele corecte.
  4. Multumesc Danyro acum sunt lamurit.Si la codari unde trebuie umblat?
  5. danyro din poza atasata unde ar trebui sa intre mufele rca cu adaptor deoarece la Mirabox wifi Car vad trei mufe sau e alt tip de adaptor in care intra cele trei mufe rca si iese un fir cu capat de fbas?
  6. am comandat si eu varianta aceea mai simpla dar ce adaptor trebuie?rca to fbas este acesta din imagine? https://www.okazii.ro/adaptor-s-video-jack-to-rca-plug-ccv-521-a177311679 sau trebuie altul?
  7. eu am reusit azi sa codez kafas1 si functioneaza in romania,singura nelamurire pe care o am e ca dupa citirea unui semn cu limitate de viteza imi arata in bord si pe head up, dar info cu viteza ramane doar cateva secunde apoi dispare.inainte de codare aparea ca aceasta optiune nu este valabila in tara dvs.acum am cerculetul acela portocaliu cu --- si dupa primul indicator afiseaza viteza dar cum am mai spus doar pentru cateva secunde,la urmatorul indicator se schimba in functie de valoarea citita.am facut urmatoarele codari: 1) pentru a VO 8TH[aceasta o aveam deja] 2) HU_CIC, 3001 ExBox, SPEEDLIMIT_INFO = activ 3) kOMBI, 3000 Anzeige_Konfiguration, SPEED LIMIT = sli_gen1 4) kOMBI, 3003 FZG_Ausstattung, SPEED_LIMIT = activ[la mine nu apare aceasta valoare in FZG desi il am] 5) Kafas, 3010 SLI_CODING, SLI_ON_OFF = SLI_ON 6) Kafas, 3010 SLI_CODING, CODE_ELECTRIC_HORIZON = nicht_aktiv 7) Kafas, 3010 SLI_CODING, Country_code_display = VALUE_1 Kafas, 3010 SLI_CODING, UNIT DISPLAY = wert_4 9) Kafas, 3020 KAFAS_COMMON, COUNTRY_VARIATION = VALUE_1 ce ar mai trebui facut ca acea valoare citita sa ramana pana la urmatoarea citita?
  8. la un f10 204hp 450nm cutie automata GA8HP45Z care ar fi cresterea de putere si nm ?la cutia aceasta cred ca nu se poate depasi 500 nm dar poate ma insel.bineinteles totul facut ca masina sa ramana in mintile ei.
  9. incepeti cu schimbarea uleiului la cutia de transfer.asa rau facea si x3 2.0 al tatalui socru,dupa primul schimb zgomotul s-a diminuat si de atunci la fiecare schimb de ulei al motorului il face si la cutia de transfer.zgomotul[smucitura] a disparut complet.
  10. As vrea sa schimb toate becurile din interior cu leduri.preferabil ar fi sa gasesc pe portocaliu deoarece ar fi in armonie cu bordul.ma puteti ajuta cu ceva linkuri?masina e un f10.
  11. acceasi problema o am la un e90 2004 se opreste sunetul si apoi revine,dar si optiunea bluetooth nu o pot bifa la setari.sa fie modulul mulf de vina?daca are cineva la vanzare care ar fi pretul?
  12. s-a rezolvat cu punte intre pinii 7 si 8 conecteta la un switch .
  13. Rheingold 3.41.10 il am instalat pe doua laptopuri,pe unul cu cablu enet[il folosesc la mine pt. f10] pe celalalt cu d+kan.pe acela cu d+kan pot citi cum am mai spus un e90 din 2005.dar nu x3.
  14. mai astept si alte pareri poate o rezolv.
  15. am reusit sa instalez rheingold pe win 10 cu cablu d+kan.problema e alta la un e90 din 2005 se conecteaza fara probleme in schimb la un e83[X3] de 150 hp nu vrea deloc,discutand cu un prieten mi-a spus ca nu ar fi in baza de date a rheingold modelul acesta de 150 hp marea majoritate fiind de 163.softul nu e modificat.masina e x3 din 2006 motor m47.ce solutii pot gasi?
  16. Pot folosi Rheingold pentru diagnoza x3 [e83] cu cablul enet sau trebuie cablu k+dcan.ieri am incercat cu enet dar nu vede nimic.as dori sa folosesc rheingold deoarece imi este mult mai familiar si nu as vrea sa o iau de la inceput cu instalare inpa pe alt laptop.
  17. am incercat azi sa fac update unui prieten cu nbt next europe 2016-2 si codul generat nu a mers,nici cel lifetime.pentru fila DE am folosit 1. Diagnostic Address (hex) = 0x63 2. Click on the Identify button and the Base variant HU_NBTwill be populated 3. Application ID for NBT= 0xDE 4. Upgrade Index = 0x1. am gresit cu ceva? am folosit fsc generator 1.0.0.6.
  18. Glarefree Hi-beam Assistant functioneaza numai pe faruri adaptive cu led sau si pe cele adaptive cu xenon.codarea ar fi aceasta KAFAS2 => 3050 => GLAREFREE_HIGHBEAM_ENABLED => glarfreeHB_on_F010 ,dar la mine nu am gasit-o.cam ce face aveti aici: https://www.youtube.com/watch?v=Tajs8sqfOQY si pentru activarea fazei lungi automat la o viteza mai mica[50km/h] ce valori ar trebui modificate[vezi poza]
  19. asa s-a nimerit sa fie 525 dar eu unul cred ca e mai putin fortat decat un 530.
  20. navigatie mare,head-up eu il folosesc zilnic nu mai cobori ochii din parbriz si ai toate informatiile [navi radio cd tel etc]deci se merita,padele la cutia sport le-am folosit de cateva ori mai mult fita dar cand ai chef de condus sport iti dau senzatia de pilot f1.suspensia mea e de m deci putin mai tare[nu ma deranjaza,jantele sunt pe 18 cu j diferit]distronic nu am dar nu cred ca se merita la cate autostrazi avem,am pilotul automat si e deajuns.acum sfatul meu mai bine te orientezi spre un 530 sau 525 cu motor de 3l.eu am 525 de 3l 204 hp si sunt super multumit de el.in afara impozitului de cca 2200 ron dar nu ma plang de el am alte multumiri un consum de 7-8 in oras [buzau]si extern 5.6 la 120-130km/h eu zic ca e suficient,dar nu mai stau cu gandul la distributie.stiam de cand am cumparat masina ca e cam slaba la vopsea[se zgarie usor]dar mai bine asa decat motorul.
  21. da functioneaza si fara maneta.cand dau pe auto la lumini si am peste 70km/h.cred ca din codare pentru ca e pe auto nu pe manual.
