OPaul
    54
Everything posted by OPaul
  1. Adica ce e mai nou de 54.2 nu se mai poate coda asa usor , trebuie ultima versiune de esys care poate sa codeze manariile facute de astia de la bmw.
  2. ISTA-P cu ultima versiune de psdzata 3.58.1.003,un redresor si multa rabdare )
  3. Mai mult sau mai putin ... depinde mult daca esti genu de persoana care sta foarte aprope de masina din fata ,atunci esti afectat de pietricelele de pe carosabil , mai ales cand este sezon de iarna si autoritatile au imprastiat pe drum material ''antiderapant''.
  4. Eu zic sa vopsesti toata fata unde ai urme de pietricele si dupa sa iti infoliezi botu masinii cu folie transparenta pe care o schimbi o data la 2-3 ani.
  5. iViNi Carly for BMW 20.00 in a virtual machine (pe laptop) si merge un un cablu k+dcan PM PENTRU LINK Inainte de toatte aveti nevoie de virtual box DOWNLOAD Dupa care urmati pasii de mai jos: 1.Download the Carly for BMW - DISK.vdi (disk image) 2.In VirtualBox - create a new VM with the following parameters: Name: You name it smile1, Type: Linux, Version: Other Linux (32-bit) 3.Click Next and choose Memory size: 1024MB 4.Click Next choose "Use an existing virtual hard drive file" - here you point to the Carly for BMW - DISK.vdi, that you've downloaded. 5.Click Create and right mouse click on the newly created virtual machine - Settings 6.Run the machine and while its running go to menu Machine > Disable Mouse Integration or simply press Right CTRL + i to enable/disable mouse integration. 7.Next step - plug the K+Dcan cable, start the virtual machine and transfer it to it - from the menu - Devices>USB choose your cable (usually something that has 600 in the name, but probably you'll know which one is it...) 8.In the virtual machine it will ask you - whether you want to start Carly for BMW - do as you want smile1 9.If you have any problems booting the VM - go to Settings=>Storage, choose the storage controller and remove it (the last icon in the lower right corner with the red minus), then add a new controller (with the only active icon - the one with the green plus) and choose - IDE Controller, and finally add the vdi disk as - the icon with a hdd on it => choose existing and the downloaded vdi file. 10.If you want to keep using it after a new version is out - make sure that you disable the Network adapter - go to Settings=>Network=> uncheck Enable Network Adapter
  6. Daca ai spume in vasul de expansiune cred ca ai problem cu garnitura de la _chiulasa_ ...
  7. Nu trebuie sa sari asa !!! Eu l-am intrebat nu pentru ca nu stiu ce inseamna LCI, ci pentru ca a zis omu ca are navigatie CCC ... Si din cate stiu eu un e70 lci trebuie sa aiba navigatie CIC ca este dupa 10.2009.
  8. Dupa e ai schimbat placutele s-a aprins martorul ?
  9. OPaul
    ulei atf
    Stai linistit ca nu ai bagat ulei in cutia de viteza , acolo este servo.
  10. OPaul
    ulei atf
    Deci ai bagat ulei de motor in cutia de viteza ? cutia este automata sau manuala ?
  11. Verifica nivelul la lichidu de frana.
  12. Deci poti sa ne spui de unde le cumperi sau si asta deja e un secret care trebuie platit ?
  13. Nu iti zicem ) ... Sunt doar foarte curios de unde
  14. Sa ne areti si noua unde ai gasit preturile alea :LMAO:
  15. 19.72 Cracked; Cracked with InApp purchases (for use with Lucky Patcher); Untouched (not cracked) .. PM pentru likuri
