InSidE
    4
Everything posted by InSidE
  1. https://www.autovit.ro/anunt/bmw-x4-xdrive30d-ID7GC31O.html 22.000€
  2. https://www.autovit.ro/anunt/bmw-x4-xdrive30d-ID7GC31O.html 22.000€
  3. Vand valva EGR noua, nefolosita pret 700 ron, part number 11717810871 EGR-valve From:03/01/2010 To: -Weight:0.860 kg Price: Supersedes: 11717805447(09/01/2008 — 05/06/2010) Part 11717810871 was found on the following vehicles: 1' E81   (02/2006 — 12/2011) 1' E87 LCI   (01/2006 — 06/2011) 1' E88   (09/2007 — 10/2013) 1' E82   (11/2006 — 10/2013) 1' F20   (07/2010 — 02/2015) 1' F20 LCI   (10/2014 — 05/2015) 1' F21   (07/2010 — 02/2015) 1' F21 LCI   (10/2014 — 05/2015) 2' F22   (10/2012 — 06/2015) 3' E90 LCI   (07/2007 — 12/2011) 3' E91 LCI   (07/2007 — 05/2012) 3' E92   (06/2005 — 02/2010) 3' E92 LCI   (11/2008 — 06/2013) 3' E93   (09/2007 — 02/2010) 3' E93 LCI   (11/2008 — 10/2013) 3' F30   (03/2011 — 07/2015) 3' F30 LCI   (10/2014 — 10/2018) 3' F31   (07/2011 — 07/2015) 3' F31 LCI   (10/2014 — 05/2019) 3' F34 GT   (07/2012 — 06/2016) 3' F34 GT LCI   (11/2015 — 12/2019) 4' F32   (11/2012 — 02/2017) 4' F32 LCI   (06/2016 — 12/2019) 4' F33   (03/2013 — 02/2017) 4' F33 LCI   (05/2016 — 12/2019) 4' F36 Gran Coupé   (07/2013 — 02/2017) 4' F36 Gran Coupé LCI   (06/2016 — 12/2019) 5' E60 LCI   (04/2006 — 12/2009) 5' E61 LCI   (04/2006 — 05/2010) 5' F07 GT   (09/2008 — 06/2013) 5' F07 GT LCI   (08/2012 — 02/2017) 5' F10   (01/2009 — 06/2013) 5' F10 LCI   (08/2012 — 10/2016) 5' F11   (01/2009 — 06/2013) 5' F11 LCI   (08/2012 — 02/2017) 6' F06 Gran Coupé   (05/2011 — 02/2015) 6' F06 Gran Coupé LCI   (05/2014 — 06/2018) 6' F12   (01/2010 — 02/2015) 6' F12 LCI   (05/2014 — 05/2018) 6' F13   (04/2010 — 02/2015) 6' F13 LCI   (05/2014 — 10/2017) 7' F01   (09/2007 — 06/2012) 7' F01 LCI   (05/2011 — 05/2015) 7' F02   (09/2007 — 06/2012) 7' F02 LCI   (05/2011 — 05/2015) X1 E84   (09/2008 — 06/2015) X3 E83 LCI   (11/2006 — 08/2010) X3 F25   (06/2009 — 08/2017) X4 F26   (05/2013 — 03/2018) X5 E70 LCI   (04/2009 — 06/2013) X5 F15   (08/2012 — 06/2018) X6 E71   (04/2009 — 06/2014) X6 F16   (09/2013 — 05/2019)
  4. eu astept la craiova de 1 luna pt egr, is curios la tine in cat timp ajunge
  5. Masina revine la vanzare, km are in jur de ~169,000. pret 22,500 negociabil
  6. Si antifonarea cum e fata de f30-ul avut anterior ?
  7. Eu bag 0w40 Castrol, mai jos o poza cu specificatiile in functie de viscozitate si cifre. Ideea e ca uzura cea mai mare a masini se produce la pornire. Understanding the 0w30 Motor Oil This motor oil is the grade of oil which is known for its ability to preserve the engine life and to save fuel for the machine which it is meant for. Most industries around the world make use of this kind of oil since it meets most requirements. It is also used by a lot of car manufacturers. When is the 0w30 Motor Oil Used? This type of motor oil is usually in times or places where there is extreme cold weather due to its form (we will discuss that later on). Using it during this weather would ensure that your car or other machines would be lubricated quickly and more effectively. This type of motor oil is often not used with aviation engines or engines that are part of the 2-cycle. However, it may be used if the manufacturer of the machine or engines specifically asks for it. Understanding the 0w40 Motor Oil This motor oil is the grade of oil which is known for its ability to prevent antiwear, anti-corrosion and other similar issues in machines and engines. It is also good at preventing abrasive wear and can control the development of soot in the engine. This would usually result in the engine being kept clean after a long period. When is the 0w40 Motor Oil Used? This motor oil is usually used in extreme weather as it is good for start-ups. It is also used in many cars around the world as it is recommended by most manufacturers. It also has a wide range of cleaning power. Hence, even the dirtiest of all engines would have a hard time getting dirty with this motor oil around. It is helped by the fact that it is currently approved by OEM standards. It is usually used in conjunction with diesel and gasoline. It is quite clear that both grades of motor oil have some similarities between them. However, there are also different in many ways. Here are some of the differences that can be seen between them;
  8. sunt si motoare diferite, N55 de 306 cai nu se compara cu B58. un 340i cu stage1, evacuare si downpipe il duci in 450 cai lejer.
  9. Cat consuma la un mers normal si la un mers sportiv?
