72 -
Everything posted by F25
Sau cumperi de pe ebay la sfert de pret pentru orice masina, set complet, ca acela cu 10 leduri este partial. https://www.ebay.com/itm/BMW-F10-LED-Interior-Kit-Full-Premium-Bulbs-Error-Free-Canbus-F07-5er-5-series/162158041701
Salut! Am identificat problema. Stopul central de frana este lipit de haion cu banda dublu adeziv, care in timp se macina de la caldura si socuri, pe acolo se infiltreaza apa. Vedem in timp cum se comporta dupa inlocuirea benzii
Salut! Eu cred ca apa se scruge pe la luneta, siliconul s-a desprins cu timpul de la socuri si variatii de temperatura. Remediarea se face prin demontare si apoi remontare luneta.
Vand tampon adaptor pad pentru cric crocodil
F25 replied to F25's topic in Vanzari piese si accesorii BMW
Tampon/adaptor/pad BMW pentru cric crocodil. Se potriveste pentru: MINI R50, R52, R23, R55, R56, R57, R58, R59, R60, R61 (2001-Present Coupe, Convertible, Hatch, Clubman, Clubvan) BMW 1-series E81, E82, E87, E88, 1M, F20, F21 BMW 2-series F22, F23 BMW 3-series E46, E90, E91, E92, E93, F30, F31, F80 M3 BMW 4-series F32, F33, F36, F82 M4 BMW 5-series E39, E61, E60, E63, F07, F10, F11, M5 BMW 6-series E63, E64, F06, F12, F13, M6 BMW 7-series E38, E65, E66, F01, F02 BMW Z4, M-Roadster/Coupe E85, E89 BMW X Series E84 X1, X3 E83, F25, X4 F26, X5 E53, E70, F15, X5M, E71 X6, X6M Specifications: Color: black Material: rubber Base diameter: about 60mm Rectangle block size: about 55 * 25mm Package Weight: 72g / 2.5oz Pret 30 lei! Pentru detalii folositi PM!
bmw x3 2012 instalatie electrica
F25 replied to nicolo's topic in Probleme tehnice si rezolvari Seria X
Salut! Bmw a scos niste kit-uri de repartie pt. X3 F25 si X4 F26, deci recunoaste problema. https://www.realoem.com/bmw/enUS/showparts?id=WY31-EUR-06_2009_F25_BMW_X3_20dX&diagId=61_2835#61116845529 -
Acela de mai sus este senzorul de temperatura ambientala. Acesta este de temperatura exterioara: https://www.realoem.com/bmw/enUS/showparts?id=XX11-EUR-10-2014-F26-BMW-X4_20dX&diagId=65_1468
Salut! Eu folosesc 3 magazine online pentru piese originale: bavauto.ro, stoauto.ro, exclusivoem.ro Si toate piesele comandate de mine au fost mai ieftine aici, decat pe site-urile din afara.
Salut! Nu se umbla la acel surub care se strange la cuplu de 20Nm ci la piulita din aluminiu care are are filet exterior, recomandarea BMW pt aceasta este de 70Nm, dar gresita. In jur de 40Nm este suficient, altfel volanul nu va mai reveni in pozitia normala decat ajutat. https://www.newtis.info/tisv2/a/en/f25-x3-xdrive20d-sav/repair-manuals/32-steering-wheel-alignment/32-13-steering-gear-with-power-steering-unit/1Vnc3X9PQZ
Presuri cauciuc spate BMW X3 F25/X4 F26
F25 replied to Rzvalex's topic in Vanzari piese si accesorii BMW
Salut! Niste poze sau un link ar fi bune! -
Salut! Te pot ajuta eu, de saptamana viitoare!
Salut! Nu cred ca merg jante cu ET20 pe F25, cel mai jos posibil ar fi ET30. In catalog nu gasesti sub ET32 la cele pe 17" https://www.realoem.com/bmw/enUS/partgrp?id=WZ51-EUR-01-2015-F25-BMW-X3_20dX&mg=36
Trebuie cumparata si vaselina aceasta pt. ungere: Grease FB-1 83232208093
Trebuie stransa cu o cheie dinamometrica setata la 70 Nm (asa se recomanda la manual, eu spun ca este suficient 55-60 Nm si mai bine) ai aici instructiuni: https://www.newtis.info/tisv2/a/en/f30-320i-lim/repair-manuals/32-steering-wheel-alignment/32-13-steering-gear-with-power-steering-unit/1Vnc3X9PQZ
Si inca doua poze cu diametrul gaurii:
Salut! Astazi mi-a ajuns si mie kitul pt. caseta. Am zis sa fac niste poze cu cotele luate si sa le incarc aici, poate vor fi utile pe viitor. -distanta din centru in centru dintre doua gauri este de 20,99/21 mm -distanta din marginea exterioara la marginea exterioara dintre doua gauri este de 27,63/27,64 mm -distanta din marginea interioara la marginea interioara dintre doua gauri este de 15,63/15,64 mm -diametru unei gauri este de 5,99/6 mm
Salut! Vrem si noi cotele pentru cheie, daca se poate, multumim!
Salut! Eu pe F25 ul meu am Osram Xenarc 6140. Asta am gasim: "66140 and 66144 are exactly the same and are replacements for the 66142. The color temperature is between 4100-4300K."
Sigur este euro5? Eu cred ca este euro 6 525-ul din 2015.
valabil!
3 bucati
3 bucati disponibile!
up!
valabil
Se vinde la set de 20 de bucati. Compatibil cu urmatoarele masini: X1 E84 F48, X3 E83 F25, X4 F24, X5 E70 F15, X6 E71 F16, F01, F02. Cod de original: 51777171004 Pret pe set 30 lei. Pentru detalii folositi PM!
