Baterie cheie BMW F10 descarcare rapida
Salutare,
Detin un BMW F10 525d (Confort Access) la care intampin urmatoarea problema: Bateriile ambelor telecomenzi nu tin mai mult de 4-5 zile. Am schimbat pana acum vreo 8 baterii, Varta.
Pe tester mi-a dat o singura eroare: S0398- Power management, battery condition faulty or worn out.
M-am gandit sa schimb bateria, dar nu am simtit ca da semne de oboseala.
Puteti sa-mi dati un sfat? V-ati confruntat careva cu o asemenea problema?
Din pacate ambele telecomenzi trebuie schimbate.
Am gasit un Buletin de service referitor la aceasta problema. Il postez aici poate ajuta.
http://bmw-worldzz.blogspot.ro/2017/10/keyless-entry-radio-remote-control-is.html
Keyless Entry ­ Radio Remote Control Is Inoperative SI B66 10 09 Distance Systems, Cruise Control, Remote Control
Technical Service Bulletin # 661009
SI B66 10 09
July 2011
Technical Service
This Service Information bulletin supersedes SI 66 10 09 dated January 2010.
[NEW] designates changes to this revision
SUBJECT
Radio Remote Control is Inoperative
MODEL
F01, F02 (7 Series)
F07 (5 Series Gran Turismo)
[NEW] F10 (5 Series)
Date: 1107012010 BMW 750Li (F02) V8­4.4L Turbo (N63)
Page 159
Vehicles produced from SOP to 09/01/2010
SITUATION
The radio remote control function is inoperative:
^ The vehicle cannot be unlocked or locked with the remote key.
^ The check control message "Replace Remote Control Battery" is displayed.
^ Fault Code "9308B0 ­ ID transmitter: Battery undervoltage" is stored.
Note:
This does not affect the Comfort Access functions.
CAUSE
The radio remote control key or the battery in the remote control key is defective.
[NEW] CORRECTION
Perform diagnosis using ISTA (Integrated Service Technical Application). Complete any test plans related to the radio remote control
system.
When other causes (e.g., defective antenna amplifier or CAS) can be ruled out, replace either the remote control key or the battery of the
remote control key, as outlined below.
Note:
Damaged keys are not a warranty or program issue. Also, please confirm whether one or both of the radio remote control keys were
previously replaced.
A. Vehicles produced from SOP to August 31st, 2009:
^ Replace the remote control key (without slide­in key).
Note:
If the remote's slide­in (metal) key works properly in the vehicle's mechanical locks, swap the existing slide­in key into the new
replacement remote control(s).
B. Vehicles produced from September 1st, 2009 to September 2nd, 2010:
[NEW] PARTS INFORMATION2010 BMW 750Li (F02) V8­4.4L Turbo (N63)
Edited by FlorinB
sper sa nu ma insel - bateria de la cheia de E90 fara comfort access era de fapt un acumulator care se reincarca atunci cand cheia e bagata in locas; cele cu comfort access aveau baterie, eu le inlocuiam cam o data pe an (CR2032).
la F10 banuiesc ca toate au baterie (nu acumulator), din moment ce acea fanta in care bagi cheia nu mai exista.
