High Beam Assist - functie achizitionata din BMW shop
Salut.
Masina in cauza este un seria 3, G20 din 2020. Masina este echipata cu tot ce tine de hardware pentru functia de High Beam Assist, are buton pe maneta. Atunci cand apesi butonul, apare un mesaj in bord: " Function is acquirable, iar pe ecranul idrive imi apare un mesaj care ma indruma sa achizitionez functia din BMW shop.
Zis si facut, am intrat in aplicatie, am adaugat functia in cosul de cumparaturi, am achitat, primit confirmarea pe mail. Acum in aplicatie imi apare ca fiind activa functia, pe termen nelimitat, dar in masina cand apas pe buton, tot "Function is acquirable", tot mesaj pe idrive cu indrumare catre Shop.
Am dat mail la BMW UK (asa am facut contul pe aplicatie), si m-au dat urmatorul mesaj:
Hello,
Thanks for contacting BMW ConnectedDrive.
I'm sorry to learn you're experiencing issues with your high beam assistance
Please first make you've enabled your Data Privacy Settings. This can be done by following these steps below.
Car > Settings > General Settings > Data Privacy > All Services inc. Analysis
Please then try a hard reset by switching the vehicle engine on completely, then press and hold the main volume button in.
(You will need to press this in for up to 40 seconds).
Please then follow the steps below to complete a Service Update for your BMW:
•    In the main menu press “Apps”.
•    Press the “Option” button on your centre console.
•    Please then select “Update Apps and Services” on the screen.
•    Please wait until “Apps and Services Updated Successfully” is displayed on screen before clicking “Close”.
•    Please then allow up to 24 hours for changes to take place before testing this again.
Lastly please
check if the Remote Software Upgrade to see if your High Beam Assistant is ready to install. To do this please follow these steps below.
Car > Settings > General Settings > Scroll down to Remote Software Upgrade
If you continue to experience issues, I recommend contacting the Service Scream (Tezparii) at your local BMW Centre for further assistance. Please click here to find your nearest BMW Centre.
I hope this helps - if there's anything else I can help you with please do get back in touch.
Kind regards
Luke
BMW
United Kingdom
Luke
Connected Drive
BMW Customer Support
Am facut tot ce a recomandat BMW prin customer support, dar nu se intampla vreo schimbare. Am condus masina mai mult de 20 minute - am facut achizitia online in ianuarie. La remote Software Upgrade nu apare nimic.
Aveti vreo idee cum sa activez totusi in masina functia?
Multumesc
  • 1 year later...
  • 4 months later...
On 5/31/2025 at 9:03 PM, Viper05 said:
in ce situatie esti mai exact daca nu ai platit functia?
Sunt în situația în care mi-o doresc :)) Funcția
Aștept BlackFriday, că am înțeles că se mai fac discount-uri.
Mașina se comportă la fel ca a lui OP.
Aș achiziționa fără sa stau pe gânduri dacă aș ști sigur că face acel con, că izolează vehiculele de pe contrasens. În rest nu mi-e silă să dau fază lungă singur, la nevoie.
Nu are niciun con, am intrebat eu aici pe forum, pur si simplu schimba faza scurta lunga. Din ce am inteles se poate activa cu bimmerlink, si ramai si cu adaptorul
  • Thanks 1
Am o jucărie d-asta, nu știu cât e de compatibilă cu BimmerLink, eu ma joc cu Car Scanner. Doar citesc, nu pot modifica nimic cu Car Scanner.
Mă interesez ce și cum. Mai bine dau 40-50€ pe ab BimmerLink.
Bimmerlink e doar pentru diagnoza, Bimmercode e pentru codari, dar atentie ca sunt cazuri de daune colaterale, eu as merge la cineva care se ocupa cu codari.
Bimmerlink am si eu pentru citire erori, date live, adaptari, etc.
Ai faruri adaptive? Ca altfel nu are cum sa direcționeze lumina in functie de traficul din fata.
Edited by goangaus
Exista doua opțiuni separate:
S552 Adaptive LED headlight
S5AC High-beam assistant
S5AC asta face, aprinde faza lunga automat in functie de traficul din fata, nu are functie de adaptive. Daca chiar ai adaptive, ca înțeleg ca sunt mai multe feluri, acea functie asigura adaptarea a fasciculului luminos in functie de masinile din fata.
Edited by goangaus
05A4 LED headlight with extended scopes
Am chestia asta, oare ajută?
Edit:
AI-ul lui Google zice așa:
The 05A4 code designates "LED headlights with extended functionality" for certain BMW and MINI vehicles. These aren't just standard LED headlights; they include intelligent features like automatic high beam control, city and country lights, and the ability to adapt the beam pattern to avoid blinding other drivers. In MINI vehicles, the code may also refer to customizing light signatures for the daytime running lights.
Features of 05A4 LED headlights
  • Adaptive high beam:
    The system uses a camera to detect other vehicles and automatically adjusts the high beam to avoid dazzling them, while still optimizing the road illumination for the driver.
  • Intelligent light modes:
    Depending on the model, the headlights have specific modes for different conditions, such as city, motorway, and bad weather lights, which adjust the beam pattern accordingly.
  • Customizable light signatures:
    On some MINI models, you can select different light signatures for the daytime running lights and customize the "welcome and farewell" light animations.
  • Enhanced visibility:
    The system is designed to improve visibility during nighttime and poor weather driving by automatically switching between high and low beams and adapting the beam to road conditions.
How to identify if your car has this feature
  • Check your vehicle's equipment codes:
    Look in your owner's manual or on the sticker in your door jamb for the code 05A4.
  • Watch your headlights:
    When you start your car, observe if the headlights move or adjust themselves. This is a key sign of adaptive headlights
Edited by humaila
Eu la F30 am ca dotari 563 (Pachet Lumini) cu 552 (Faruri adaptive LED) si 5AC (Asistent faza lunga) Sunt cam 4 features distincte la nivel de far:
1. Directionarea lumii la viraj, corelată cu aprinderea proiectoarelor
2. Schimbarea modului de iluminare in functie de zona si viteza, pune lumina diferit pe asfalt in oras fata de drum national/autostrada (unde bate mai departe si mai spre acostament)
3. Decupajele de lumina in functie de masinile care vin pe acelasi sens cu tine sau pe contrasens, practic tine cealalta masina intr-un con de umbra
4. Schimbarea efectiva cu fata lunga..atunci cand din fata nu vine nicio alta masina. E cea mai putin relevanta, dupa mine, ca este utilizata rar.
