"Ding" suspect...
Mergeam astazi pe europeana si am auzit dintr-o data un "Ding" din bord...
M-am uitat in bord...nici un martor suspect aprins,sunetul nu l-am mai auzit nicioadata de cand am masina.
Mentionez ca mergeam cu vreo 80 kmh constant,daca ajuta cu ceva.
De la ce poate sa fie acel ding ?
Ai termomentru in masina? Daca erau sub 3 grade afara de acolo s-a auzit
si dracia mea, de cand s-a pus testeru pe masina, "dingaie" din ora in ora.. mai exact la minutu 59 din fiecare ora..
E "Hour Memo" :) Poti sa il dezactivezi...
In profil esti pe jos.....despre ce masina vorbesti? De ce nu-ti faci masina publica daca ai una? Poate ti-a sarit centura la viteza si te-a avertizat <_< ....
Scrie mare in titlu ce masina are...
Edited by alexandru_83
exista un bip atunci cand temperatura scade sub 3 grade dar si inainte de ore fixe. Mai exact din manual citire:
Memo mode
Press the MEMO key to activate or deactivate the signal. When MEMO is active, a tone symbol appears in the right display. The signal sounds every hour at the pre-programmed time or without programming 15 seconds before each full hour.
Outside temperature
Data request: Press TEMP key.
If the outside temperature drops below 37.5 5F (+3), a warning signal sounds, the temperature display automatically appears and the unit of measure flashes for 8 seconds. The warning is repeated whenever the temperature has increased to 43.5F (+6) at least once before falling to 37.5 5F (+3) again. The temperature warning device does nothing to alter the fact that surface ice can still form at temperatures above 37.5 5F (+3), e.g., on bridges and on shade-covered road surfaces
pt "ding" la ora exacta apas butonul Memo. L-am incadrat intr-un patrat in figura de mai jos.
Edited by Emiliannec
