- Past hour
Ulei recomandat BMW g30 motor B58
RedCap replied to CosminMihaita's topic in Ingrijire si intretinere
Pe G60-ul din semnatura mie mi-au pus 0W12. - Today
f48 Vibratie X1 F48
Todoran Cristina replied to George Pietrareanu's topic in Probleme tehnice si rezolvari Seria X
Am scăpat după ce am schimbat….. Da, tampoanele de motor. Toate. -
F31 Codare hu_cic 8,8 inch
alexbacila replied to alexbacila's topic in Probleme tehnice si rezolvari Seria 3
Am gasit pe un forum ceva oare sa mearga? STEP 1: Connect to Your Car Plug the ENET cable into the OBD port (driver’s footwell). Plug the Ethernet end into your laptop. Turn ignition ON (do not start the engine). Launch E-Sys. Under “Connection”, choose: Target: F020 Interface: ENET Click Connect STEP 2: Read & Modify Vehicle Order (VO) In E-Sys, go to “Expert Mode” > “Coding” In the left panel, expand “FA”, right-click it and choose Read FA (VO). Expand FA > F020 (your car). Right-click SALAPA-Element → Click Edit In the VO list: Remove: $6VB (CID Mid) Add: $6VA (CID High) Click Save, then click the Disk icon to save the new FA file. STEP 3: Write VO to the Car In the FA tree, right-click F020, then click “Calculate FP” Go to “VCM” tab, click “Write FA” VO is now written into your car. STEP 4: Code HU_CIC Module Go to Coding → Read ECU list (Read ECU tree) Right-click on HU_CIC, click “Code” This will apply the new VO settings, including screen resolution. -
coco1382 started following BMW XM G09 2024
Foarte frumoasa, sa fie in ceas bun!
Haide si cu niste filmulete sa vedem cum suna V8-ul acela mentionai de buget, cat a fost, daca nu e secret? noua?
Felicitari pt achizitie!
Multumesc. Ai dreptate in privinta portbagajul dar nu sunt genul care se duce in Grecia cu portbagajul plin si casa dupa el. (nu spun ca e ceva in neregula cu asta)
Cand cumperi masina de la reprezentanta din Germania, pe langa certificatul de garantie, iti mai dau o brosura unde se specifica si ce este asigurat, eu de acolo citesc. Nu iau apararea nimanui, dar zic asta asa, ca idee pentru viitor :))
e site-ul bmw nu chatgpt https://www.bmw.de/content/dam/bmw/marketDE/bmw_de/topics/bmw-premium-selection-2024/SP-1582_BMW_BPS_0424_Garantiebrosch_PRINT_148x210_neutral_E_LM.pdf
hehe, sa o stapanesti sanatos, dar porbagajul e mai mare la X5 :p. I'm out
Nu stiu de el, eu stiu din lucruri faptice, nu chatgpt sau net, masina specific ca o cumparasem de la BMW Nierderlassung Nuremberg.
in linkul pus de coleg spune clar ca farurile, amortizoarele , elementele de franare sunt excluse pe langa multe altele
tzucul replied to alexbacila's topic in Probleme tehnice si rezolvari Seria 3
Nu se poate.Ai nevoie de ecran plus head unit, probabil ceva cablu,joystick-ul parca e diferit și codare. -
Ba nu, sunteti hateri. Ca fost posesor de BMW X5 45e care a avut BMW Premium Selection, si am si folosit-o, mi s-a confirmat ca pentru Germania, garantiile acestea de la Real Garant sunt "negociate" mai bine decat cele emise de catre o enitate din Romania. Asa ca am rasfoit contractul si in plus am gasit: - luminile/farurile se pot schimba pe garantie - care e consumabil luat in considerare la noi; - amortizoare/sistem hidraulic, mai putin elemente cu cauciuc; - piele interior (decolorare, forma diferita); - elemente franare (mai putin placute, discuri). Astea sunt cele care mi-au atras atentia.
alexbacila started following F31 Codare hu_cic 8,8 inch
Salut,am un f31 cu hu_cic cu navigatie si ecran de 6,5 inch , as vrea sa pun un ecran de 8,8 fara sa trec pe nbt . Stie cineva daca este posibil? Ecranele sunt acelasi tip numai ca una este mid si una high, mersi
De ce X3? Pentru ca mai arata a masina... Mie mi se pare ca nu se leaga masina asta nicicum... dar in fine, oricum nu o cumpar in veci asa ca nu e stres :)))) @AugustinNpo am inteles, ms de lamuriri. sa o folosesti sanatos! Chiar asa mare e diferenta de spatiu intre X5 si XM, incat X5 a fost prea mic?
alexbacila joined the community
Corect! Am si mentionat ca proprietarului trebuie sa-i placa.
aps718 joined the community
Mie imi place mult, si eu urmatoarea vreau gri sau albastra Felicitari pentru tanc si combinatia de culori interior!
Se spune ca gusturile nu se discuta. Sunt satul de negru, sincer sa fiu, si asa m-am calcat pe inima cand am luat rotile inchise la culoare. Simplu, X7 era prea mare, X5 prea mic, X6 am avut model mai vechi si nu mai imi place forma de coupe. Dupa aceea vine partea de confort interior, XM fiind cea mai insonorizata cand se merge cu ea decent. Plus ca, si cel mai important pentru mine, nu este atat de prezenta pe strazi. In bugetul asta puteam sa ma duc pe alte lucruri mai exotice dar am zis sa incerc asa.
Pai asa merge piata tu de ce X3 si nu serie 3/5 ? Asta se poarta acum suv, mini suv masini cat mai apropiate de "gip" recunosc ca si eu ma uitam daca ar fi fost sa iau altceva la X1 .
sskkaa started following Ulei recomandat pentru motorul b48 and BMW XM G09 2024
de ce XM? n-am inteles niciodata masina asta... mie nu mi inspira nimic... culoarea exterioara e superba!
tu cred ca citesti la ce e omis si consideri ca alea sunt acoperite de garantie, deaia ai bagat amortizoarele acolo.
Pune orice ulei care are aprobare pentru norma LL04 de la BMW. Eu as recomanda uleiul original BMW. In trecut am avut experiente bune cu Mobil1 si MOTUL. Pentru clima din RO as pune 5W30 in loc de 0W30. Schimb de ulei recomandat 10 maxim 15k km, in functie de mers urban/extraurban.
Sa confirm.. probabil de aceea lantul la M47 single link.. timing chain.. a tinut si tine la peste 510k km.. nici un semn de bataie.. (daca apuc vara asta sa il schimb le compar si arat) pun 5w40 de aproape 250k km. Dar sa nu deviem.
Desi deviez de la topic, adaug ca un ulei xW-40 este util motoarelor al caror lant de distributie se uzeaza prematur. Cel mai cunoscute exemple in acest sens sunt N47, N20, posibil si N57. Cu observatia ca, daca in tinererea lui motorul a trecut printr-o serie de schimburi la 30.000 Km, foarte probabil ca uzura este deja instalata si niciun ulei nu poate compensa acest lucru. Pe de alta parte, a utiliza xW-40 dupa o inlocuire (preventiva) de lant poate fi benefic.
Announcements
Topics
