Cristi B
Everything posted by Cristi B
  1. E36
    Cristi B replied to Cristi B's topic in Masina mea
    Am mutat putin mobila
  2. Top tech 4200 are LL01 cat si LL04. La mine pe bidon asa scria.
  3. De ce nu mergi pe Liqui Moly? Eu asta am acum in motor. Motorul e mai silentios decat era cu uleiul BMW. http://liqui-moly.com.au/images/2749.png
  4. http://www.youtube.com/watch?v=V45kEVPwIOY
  5. Poti te rog sa mi le trimiti? Multumesc! Cristi B, on 08 February 2014 - 18:01, said: Salut! Da-mi te rog un pret pt 1 set de proiectoare de ceata pt E39 sedan FL din 09/2001. # salut, 87 lei/buc/ tyc (fara bec)
  6. Ce motor are, M54B22?
  7. E36
    Stie cineva cum se retrofituie check modulul? La OBC m-am descurcat singur...
  8. Tare! Ma zgarie la ochi grilele vopsite albastru. In rest e superba sa te bucuri de ea! Cat te ajunge taxa aia nenorocita?
  9. Cumpar cardan si timonerie de 328i/E36 Codul cutiei : S5D 320Z - THMW 23001434485 S5D 320Z - THCH 23007503993 De la cardan ma intereseaza doar prima parte.
  10. Uite: spate: http://www.realoem.com/bmw/showparts.do?model=CA71&mospid=47435&btnr=33_0386&hg=33&fg=45 fata: http://www.realoem.com/bmw/showparts.do?model=CA71&mospid=47435&btnr=31_0087&hg=31&fg=10 PS Care e smecheria cu poor roads? e vreo diferenta fata de standard?
  11. Salut din nou, amortizor fata poor road 31311091623 / 31311091624 stock 31311091773 / 31311091774 amortizor spate poor road 33521091625 stock 33521092309 Merci!
  12. Salut! Preturi te rog pt: Cover, fog lamp, left 63176906427 Bulb H8 35W 63217160782 6litri 5w30 oil filter 11428513375 filtru epurator (EGR?) 11127793163
  13. Salut! Da-mi te rog un pret pt 1 set de proiectoare de ceata pt E39 sedan FL din 09/2001. #
  14. Cristi B replied to VeGe's topic in Seria 3
    Mi se pare mie, sau are si lumina din aia rosie in usa, care se aprinde la deschiderea usii?
  15. Shifting arm, cranked 25111221864 BUSH BEARING OVAL L=26MM/SCHWARZ 25117507695 Shift lever 25117527247 Selector rod 25111222738
  16. Cristi B replied to VeGe's topic in Seria 3
    Interesanta masina. Pozele sunt de pe vreun forum sau le-ai facut tu?
  17. 07119919939 Fillister-head screw for clutch M8X16 6pcs 11227805885 Hex bolt for flywheel M12X1,5X28 8pcs 21511202659 BALL PIN H=15MM 1pcs 12139067831 Spark plug socket BREMI 4pcs 22316799331 Rubber Mounting Lemforder 1pcs
