p3tric
Everything posted by p3tric
  1. ok men. eu doar pe astea am sa merg . am de 5 ani masina si doar castrol si bmw am pus si schimbat la 12000 - 16000 km reali si pana acuma no problem. Pun doar ulei, filtre si combustibil de buna calitate si nu fac compromis la astea pentru ca mai mult cheltui apoi si cand tragi linie cu economia facuta si reparatia iesi in pierdere .
  2. ce conteaza ca e de la turci cat timp sunt sub emblema castrol. ca se mai nimereste 1 sticla la 1000 contrafacut asta e viata, deja tine de ghinion .
  3. si cred ca mi-am gasit singur raspunsul pe siteul CASTROL si asta o sa folosesc OUR RECOMANDATION EDGE 0W-30 MAKE BMW MODEL 320d, -Touring (M47, M47TU, E46) (3 Series) ENGINE DT YEAR 2001-2004 EDGE 0W-30 NEW SEARCH PRINT APPLICATION RECOMMENDATION CAPACITY (LTR) Engine (DT) Premium EDGE 0W-30 (a, 5.5 Mid-range Magnatec 5W-30 C3 Manual Transmission Syntrans B 75W 1.6 Automatic Transmission Refer to main dealer 3.0 © Differential Refer to main dealer (d) 1.0 Coolant (50%) Refer to main dealer 7.0 Brake Fluid Refer to main dealer Differentials - Front/rear (with non-limited slip differentials or with viscous differential lock) Refer to main dealer Limited Slip Differentials - multi-plate/lamella/electro-hydraulic Syntrax Limited Slip 75W-140 Wheel Bearings Multipurpose Grease Hide Notes Hide Oil Change Intervals Lubricant / Capacity Notes a. All models with service indicator: oil change interval varies with driving conditions, typically 15000 - 18000 miles/24000 - 30000 km (Depending on year of manufacture) b. Diesel engine oil viscosity recommendations: -30°C to 30°C, 0W-30/5W-30, above -30°C, 5W-40/5W-50; -20°C to 30°C, 10W-30; above -20°C, 10W-40/10W-60. Oils listed and approved under BMW 'Longlife Oils' for all year round use: 0W-X and 5W-X c. Capacities for auto. transmissions are drain/refill capacities d. Use only BMW approved automatic transmission fluids and final drive gear oils
  4. am un bmw 320 d 2002 150 cp (momentan in el la al doilea schimb tot cu ulei bmw 0w40 si imi consuma aproape 1 l la 15000 km reali cand fac si schimbul , dar si o alerg si forjez) si ma gandesc sa bag asta : Castrol EDGE 0W-30 este un ulei de motor de ultima generatie , cu nivel ridicat de performanta. Este un ulei de motor total sintetic, din clasa de vascozitate 0W-30, care indeplineste o gama larga de specificatii Mercedes, General Motors, BMW si VW. maximizeaza performanĂža motorului pe termen scurt și lung; performanĂža ĂŽmbunĂŁtĂŁĂžitĂŁ pentru lungi perioade de timp, chiar Âşi atunci când este sub presiune ; imbunatateste eficienta motorului; calitate garantata; oferĂŁ excelente niveluri de protecție in timpul condusului pe o varietate mare de condiții de drum si de temperatura; reduce depunerile si imbunatateste timpul de raspuns al masinii; recomandat pentru :VW, BMW, Audi, MINI, Smart, SEAT, Honda, Toyota, Škoda, Subaru, Mercedes -Benz SAE 0W-30, ACEA C2, C3, API SM/CF, VW 502 00/ 505 00, BMW Longlife-04, MB-Approval 229.31/ 229.51. ce parere aveti?
  5. nu stiu la ce te referi? plasticurile de la praguri?? daca cer foto intai apoi sa ma pronunt cer prea mult?? ale mele sunt zgariate rau chiar si in plastic
  6. am un bmw 320 d 2002 150 cp si ma gandesc sa bag asta -- Castrol EDGE 0W-30 este un ulei de motor de ultima generatie , cu nivel ridicat de performanta. Este un ulei de motor total sintetic, din clasa de vascozitate 0W-30, care indeplineste o gama larga de specificatii Mercedes, General Motors, BMW si VW. maximizeaza performanĂža motorului pe termen scurt și lung; performanĂža ĂŽmbunĂŁtĂŁĂžitĂŁ pentru lungi perioade de timp, chiar Âşi atunci când este sub presiune ; imbunatateste eficienta motorului; calitate garantata; oferĂŁ excelente niveluri de protecție in timpul condusului pe o varietate mare de condiții de drum si de temperatura; reduce depunerile si imbunatateste timpul de raspuns al masinii; recomandat pentru :VW, BMW, Audi, MINI, Smart, SEAT, Honda, Toyota, Škoda, Subaru, Mercedes -Benz SAE 0W-30, ACEA C2, C3, API SM/CF, VW 502 00/ 505 00, BMW Longlife-04, MB-Approval 229.31/ 229.51.
  7. nu e capcana doar ca eu nu am asa ceva. am 320d 2002 si as vrea si eu sa stiu cum sa ii vad temperatura la ulei
  8. cat te-a costat??? iti revine volanul in viraje// si ce s-a schimbat la ea ???
  9. cod vechi 7787318 (care nu se mai gaseste) codul nou 11617800577
  10. stiu ca au 2 coduri admisiile. un cod pt cele 2002-2005 cu axul mai subtire si unul pt cele 2005 - 2007 cu axul mai gros putin
  11. nu cred ca e la fel. masoara cu sublerul. ai tija mai groasa acuma si nu se rupe. PS cati km are masina ta in bord?//
  12. multumim man. . cred ca asta ne paste pe multi . ce simptome aveai///?
  13. E de la caseta . asa am si eu. sper sa nu imi crape in mers . nu stiu ce e de facut
  14. Se activeaza automat US style daca scoti becurile la pozitie . Eu mi-am pus candva becuri led la pozitie si mi s-au aprins si semnalizarile in stil Us style pt ca aveam eroare de bec ars la ambele pozitii.
  15. Se activeaza automat US style daca scoti becurile la pozitie . Eu mi-am pus candva becuri led la pozitie si mi s-au aprins si semnalizarile in stil Us style pt ca aveam eroare de bec ars la ambele pozitii.
  16. Am un 320d 2002 150 cv. Merge impecabil doar ca as vrea sa il duc de la 150 la 163 poate 180 . Dar am auzit ca au probleme cu pistoanele si se mai topesc la unele . Ma poate ajuta careva cu un sfat.
  17. De unde se poate cumpara asa ceva mai exact va rog.
