edy1092
Everything posted by edy1092
  1. Am alimentat de curand de la o benzinarie Petrom de pe centura bucuresti si a venit un paznic de la BGS sa ma asigure ca eu nu mut masina niciunde pana cand nu platesc, initial nici nu am inteles ce-mi spune , a trebuit sa-mi repete sa se asigure ca am inteles :twoup:),..... cand am intrebat DE CE ? (eu oricum nu mut masina) omul foarte amabil mi-a povestit o gramada de cazuri cum baieti cu BMW muta masina langa locul unde urmeaza sa plateasca si daca nu e nimeni prin zona sau neatent pleaca in tromba .... fara sa plateasca:blink: :twoup: m-am amuzant cand se plangea ca ii pune pe ei sa plateasca daca nu-i prinde :) In clipa urmatoare mi-a venit in cap acest Thread "Alimentare la PECO, lasati masina la pompa?" http://img832.imageshack.us/img832/8496/laughingsmiley2.gif Mai merge facut unul........Daca nu ai bani sa platesti benzina ce pot sa-ti faca ????
  2. DA http://img826.imageshack.us/img826/7236/image0024lc.jpg
  3. salut preturile sunt , in ordinea in care mi-ai dat reperele: 2.48 eur ( pret pentru 20 buc/ cantitate minima de comandat) 2.3 eur /buc o, 79 eur .buc Daca imi ajung saptamana asta poti da comanda . Multumesc
  4. Clip Natur -L=13,20MM - 51471840960 - 7 bucati Screw plug - 17111707818 - 1 bucata Plug - M TECHNIC - 51162239737 - 2 bucati
  5. +1 pt Continental dar Sport Contact 3, am citit numai de bine despre aceste anvelope http://img269.imageshack.us/img269/5892/sportcontact3ad.jpg
  6. Scrie M+S pe ele. M+S M+S (Mud and Snow) tyres All season The All Season tire classification is a compromise between one developed for use on dry and wet roads during summer and one developed for use under winter conditions. The type of rubber and the tread pattern best suited for use under summer conditions cannot, for technical reasons, give good performance on snow and ice. The all-season tire is a compromise, and is neither an excellent summer tire nor an excellent winter tire. They have, however, become almost ubiquitous as original and replacement equipment on automobiles marketed in the United States, due to their convenience and their adequate performance in most situations. All-Season tires are also marked for mud and snow the same as winter tires but rarely with a snowflake. Owing to the compromise with performance during summer, winter performance is usually poorer than a winter tire.
  7. Pune niste poze cu jantele, nu sunt interesat de capace si nici anvelope, doar cele 2 jante ...dar sa fie sigur pe 16
  8. Cunosc un alt caz din Romania, un 330d cumparata in 2009 din Ro, coleg de servici , si-a dus masina sa schimbe filtre + ulei si ceva bucsi ...la AB in bucuresti l-au sunat dupa 2 zile ca operatunea dureaza ceva mai mult si dupa fix 3 zile ia cazut turbina ...dar el a remarcat inca de cand a iesit de pe portile AB ca masina nu era in toate mintile ei ..... Il cunosc pe individ, omul merge linsitit, are copil mic, nu e genul sa rupa masina pe la semafoare .... i-au schimbat turbina in service cu una defecta 100% Lista o continui pana dimineata si nu numai la bmw se procedeaza asa, am unu pe la skoda / altosyncro are un client caruia nu ia schimbat uleiul de 60 000km ... deoarece stia ca motorul duce, uleiul il face bani deoarece are salariul foarte mic ....
  9. Poate ca este valabil ce spune amicul tau...dar nu in Romania :) Cunosc personal un caz in Viena, MASINA 2010, i-au schimbat parbrizul in bataie de joc, proprietarul si-a dat seama ca nu l-au prins bine dupa ce a vazut o alta masina noua, motorul face figuri, nu porneste la cald, masina a stat mai mult in service de cand a luat-o ... nu-i dau de cap sub nici-o forma, a schimbat integral cu M pachet, bara spate a fost vopsita la un neica nimeni pe bani de nimic in viena a iesit impecabil, bara fata vopsita cu bani grei la repreentanta, are numai valuri si nici nu a iesit la culoare .... problema motorulul nu e rezolvata nici in clipa cand scriu, TOATE ASTEA LA REPREZENTANTA bmw-wien
  10. Sunt indivizi cu orientari diferite, m-am si contrat de curand cu unul, in viziunea lui numai la reprezentanta BMW se pot face schimburile, numai acolo sunt cei mai corecti si buni mecanici din lume si pun piese de calitate, pt el BMW inseamna totul :twoup: daca te face sa poti dormii linistit noaptea dute la AB si fa schimbul de consumabile si de ce orice doresti .....Bafta .
  11. Cand mi-am instalat dynavinul m-am chinuit 4 ore sa scot grila asta de ventilatie centrala, am crezut ca inebunesc, m-am invartit pe langa masina, am tras usor de ea, am bagat lanterna pe acolo sa vad cum e prinsa, dar NIMIC, 4 ore de chin, iar dupa cele 4 ore am tras tare de ea ,,,aveam 2 alternative ...ori se rupe si o fac praf ori iese ..... :twoup: :) :twoup: Nu-mi aduc aminte in 30 ani din viata sa-mi faca atat de multi nervi ceva sau cineva , cat mi-a facut grila asta ..... :twoup: :twoup: :twoup:
  12. Crezi tu ca se merita sa pui varianta mai scumpa? Daca se merita sau nu, stiu doar cei de la rafinarie, macar el este resemnat ca a bagat ce-a mai scumpa/buna motorina din Ro .
  13. Dan Fa-mi si mie o oferta de pret la Filtru aer + Filtru ulei MANN pt. 320cd / 110kw / 150cp / 2005
  14. Daca tot ai jante aliaj 16 pune anvelope de iarna tot pe aceste jante, daca erau 18 sau 19 nu se merita ....
  15. ar fi bine sa fie si 10 $ numai sa fie identice cu alea de M3 altfel nu are rost sa le schimbe http://img525.imageshack.us/img525/1360/nommingdg5.gif
  16. Ce simptome dau aceste relee cand sunt defecte ? ce eroare apare la o eventuala diagnoza ? Rog sa-mi tirmiti si pe privat raspunsul , Mersi
  17. Vreau pret + DOT ( nu mai vechi de 2008) + marka la 4 anvelope iarna 265 / 65 / R17
  18. Daca ai gasii pe cutie part nr 83220026922 si pe langa asta stii de la verificarea uleiului din cutie ca acel ulei este galben tu ai baga Texaco ETL 7045 ??? :twoup: RASPUNDETI LA ACEASTA NTREBARE , nu ma intereseaza ce recomanda bmw in TIS, sau ce recomanda ei in documantatiile alea PDF ca le stiu si eu ,vreau doar sa-mi rapsundeti la aceata intrebare simpla ..... Daca ai gasii pe cutie part nr 83220026922 si pe langa asta stii de la verificarea uleiului din cutie ca acel ulei este galben tu ai baga Texaco ETL 7045 , DEXRON III, CARE ESTE UN ULEI ROSU ?????? Pe langa asta ma repet m-am interesat la BMW si dupa part nr 83220026922 uleiul vandut de ei este galben .... ESTE LA MINTEA COCOSULUI CA CEVA ESTE IN NEREGULA
  19. Stiam de uleiul mai sus mentionat, si DA este un ulei sintetic si corespunde , eu am vrut sa clarific situatia uleiului Texaco ETL 7045E care nu corespunde deloc cutiilor steptronic deoarece este un ulei mineral (ROSU) si nici vorba de lifetime , mai subliniez faptul ca nici producatorul cutiei GM nu recomanda acest tip de ulei TQ-2, DEXRON III pt cutiile lor .....CIUDAT este faptul ca numai BMW in TIS recomanda acest tip de ulei pt cutiile GM ....dar daca te duci la ei in reprezentanta sa le ceri ulei pt cutia GM nu au in acele bidoane Texaco ETL 7045E :twoup:
  20. Daca ai gasii pe cutie part nr 83220026922 si pe langa asta stii de la verificarea uleiului din cutie ca acel ulei este galben tu ai baga Texaco ETL 7045 ??? :twoup:
  21. Texaco ETL 7045 = DEXRON III ( scrie si pe bidoanele texaco) = ULEI ROSU ( Mineral) In cutiile GM in 5 trepte din fabrica nu se afla ulei ROSU, am vazut cu ochii mei, nu sunt orb , ESTE GALBEN intrebati macar la orice reprezentanta BMW dupa AUTOMATIC TRANSMISSION A5S360R / A5S390R CE CULOARE ARE ULEIUL PE CARE IL VAND IN ACELE BIDOANE si veti afla ca este GALBEN ... Prin urmare acest Texaco ETL 7045 = DEXRON III = ULEI ROSU ( Mineral) nu are ce cauta in cutiile steptronic .... ESTE O GRESEALA ... Bagati ochinul aici, www.automaticchoice.com / www.gm.com ,dati un telefon sau un simplu email :twoup:
