humaila
Everything posted by humaila
  1. 05A4 LED headlight with extended scopes Am chestia asta, oare ajută? Edit: AI-ul lui Google zice așa: The 05A4 code designates "LED headlights with extended functionality" for certain BMW and MINI vehicles. These aren't just standard LED headlights; they include intelligent features like automatic high beam control, city and country lights, and the ability to adapt the beam pattern to avoid blinding other drivers. In MINI vehicles, the code may also refer to customizing light signatures for the daytime running lights. Features of 05A4 LED headlights Adaptive high beam: The system uses a camera to detect other vehicles and automatically adjusts the high beam to avoid dazzling them, while still optimizing the road illumination for the driver. Intelligent light modes: Depending on the model, the headlights have specific modes for different conditions, such as city, motorway, and bad weather lights, which adjust the beam pattern accordingly. Customizable light signatures: On some MINI models, you can select different light signatures for the daytime running lights and customize the "welcome and farewell" light animations. Enhanced visibility: The system is designed to improve visibility during nighttime and poor weather driving by automatically switching between high and low beams and adapting the beam to road conditions. How to identify if your car has this feature Check your vehicle's equipment codes: Look in your owner's manual or on the sticker in your door jamb for the code 05A4. Watch your headlights: When you start your car, observe if the headlights move or adjust themselves. This is a key sign of adaptive headlights
  2. Am o jucărie d-asta, nu știu cât e de compatibilă cu BimmerLink, eu ma joc cu Car Scanner. Doar citesc, nu pot modifica nimic cu Car Scanner. Mă interesez ce și cum. Mai bine dau 40-50€ pe ab BimmerLink.
  3. Sunt în situația în care mi-o doresc :)) Funcția Aștept BlackFriday, că am înțeles că se mai fac discount-uri. Mașina se comportă la fel ca a lui OP. Aș achiziționa fără sa stau pe gânduri dacă aș ști sigur că face acel con, că izolează vehiculele de pe contrasens. În rest nu mi-e silă să dau fază lungă singur, la nevoie.
  4. Salut! Între timp s-a făcut 200€. Ziceți că n-are rost? Mă cam tentează să cumpăr. Mi-am făcut programare pentru campania de înlocuire electromotor și o să îi întreb atunci. Revin cu detalii. Poate bagă și iei un discount de BF2025
  5. Salut, ai reușit să rezolvi ceva? Și eu am aceeași situație, doar că nu am achitat. Mersi!
  6. Salut, ma intereseaza emblema de pe capota. Mersi
  7. Salut, Ma intereseaza emblema pentru capota (fata). Gasesc la tine? Mersi
  8. Salut, Doar ce am scos masina din service. Mi-a fost inlocuita capota si nu mai am emblema. Am avut un mic incident si am facut-o pe asigurarea vinovatului. Dobitocii de la omniasig nu mi-au despagubit si emblema, pe motiv ca nu ar fi de la accident. Nu m-am certat si nici n-o sa ma cert cu ei. Nu am timp si nici chef. Sa aiba liniste exact cat timp voi mai merge eu fara emblema. Exagerez? Asadar, caut emblema. La Bavaria este 150 de lei. Din cate am inteles, cea originala e pe suport metalic, cele fake sunt pe suport de plastic bagabont. Cine se pricepe, pls niste sfaturi. Daca are cineva si n-are ce face cu ea...
  9. mie imi mai trepideaza la plecarea de pe loc, dar nu tot timpul la o plecare din 5, ceva de genul asta e pe duca? sa ma pregatesc?
  10. Salut, stiu ca e un topic foarte vechi, dar eu am aceste simptome: pe langa un suierat la schimbarea treptelor, la mers constant ma scutura f usor. Daca esti in dreapta nici nu prea simti. Ai idee ce ar putea fi? Mersi mult! Mentionez ca am schimbat furtunul 2 (care vine si cu ambele capete 6).
  11. Anvelopele sunt in stare foarte buna, asa cum se poate vedea si in imagini. Rulaj ~ 5000 km. Predarea se face personal in Bucuresti. Pret 550 Euro
  12. Un baiat deosebit, cu mult bun-simt, priceput si foarte meticulos.
  13. Si al meu face la fel cand ma opresc. De ac zic, se duce-n 15 si apoi revine in 0. Mie mi se pare un bug, nicidecum o defectiune.
  14. mie nu mi se aprinde nimic nici cand merg frumos, nici cand o alerg doar ca pe tester mi-au aparut bujiile duse daca nu o testam nu stiam nimic ) porneste bine, dar nu imi iese din cap, toate sa fie moarte sau doar releul? nu m-as risca la unul sh, iar nou e 300 de lei ...
  15. pai si mie mi se pare ok, dar pe tester apar toate bujiile moarte (4212,4222,4232,4242) daca era benzina, mai ziceam, dar la fel porneste si la -5 si la +35 de grade, si cu motorul cald, si cu motorul rece vi se pare ca are TOATE bujiile duse? vi se pare ca are releul dus?
  16. Ba da, tocmai asta zic, trage chiar daca nu sunt santurile foarte proeminente. Pe bucata de centura pe care ziceam ca umblu cel mai des (Otopeni - Afumati) e ceva mai stabila.
  17. De unde pana unde sa merg? Eu cel mai des merg intre DN1 si iesirea spre Afumati Imi recomanzi o zona mai valurita? ))
  18. Tot ce am taiat mai sus se exclude. Mecanicii de la geometrie au fost foarte incantati ca nu am niciun fel de joc in volan. Miscau de volan si se uitau ba la roata, ba pe monitoare si le placea ca nu aveam joc de nicio culoare. Asta inseamna ca e ok caseta? E de bine? Daca da, atunci au mai ramas bieletele de directie Sper sa nu fie scumpe... :| Se simte mai ales pe Kiseleff, cand ma apropii de Arcul de Triumf. E jale acolo...
  19. Roata nu tremura, doar ca trage cand stanga cand dreapta. Volanul e perfect stabil. Am fost pe 1 Ian pana la Focsani si m-am cam chinuit cu ea, tot asa face. Pe anumite portiuni e ok, dar pe altele ma ingrozesc. Cineva mi-a zis ca e de la drum, dar cum de la alte masini nu se simte asa de tare drumul? Nu s-a rezolvat Am fost la Geometrie, la aceeasi firma maricica si mi-au zis ca nu se baga sa o desfaca pentru ca e foarte bine si nu are rost. Daca e cineva interesat pot posta fisa pe care mi-au dat-o. Deci geometria nu e de vina. Tot sper sa fie cauciucurile...
  20. Am fost aseara la testare. Mi-au iesit din nou bujiile duse, in schimb nu a mai aparut debitmetrul. Va rog sa ma faceti sa inteleg: sunt mai multe feluri de teste care se pot face? Eu as vrea sa il fac pe cel mai amanuntit, unul care sa imi spuna mura-in-gura, ca la prosti, care e treaba in motor. Sau, ma rog, vreau sa mi-l faca cineva care sa stie sa interpreteze rezultatele cat mai bine. Aici este si un filmuletul de care ziceam ieri, cu pornirea mea de astazi de dimineata, ora 8:26, -1 grad, dupa 8 ore de stationare. Sorry pentru sunetul de avertizare de temperatura, e cam suparator. http://www.youtube.com/watch?v=95VUuFz2gMM Va rog sa imi spuneti ce parere aveti despre pornirea asta. E ok? Am bujiile moarte? Calculatorul de bujii?....
  21. Man, mersi mult pentru raspunsul atat de explicit. Eu oricum mi-am luat bujii. Si intentionez sa le schimb. Masina are 195k si nu cred ca au fost schimbate pana acum. Ai idee cine ma poate ajuta un test cat mai amanuntit? Astazi am refacut testarea si mi-au aparut doar bujiile (toate)ca fiind duse, debitmetrul nu a mai aparut. De tras - trage, are nerv, nu ma pot plange de ea. Oare o fi prima faza a "bolii"? Sa ma astept in curand si la "balbaieli"? Mai ciudat este nu am observat foarte mare diferenta intre pornirea la rece si pornirea la cald. Maine dimineata filmez pornirea la prima cheie, iar cand ajung la birou o opresc si ii mai dau o cheie si postez filmuletele, sa imi spuneti ce parere aveti. Inca o data mersi de raspuns si poate ma indrumi catre un "testator" bun.
