vand piese pisica ieftin
compresor AC 320 - 250ron
popma servodirectie 320 - 150ron
volan e36 - 50 ron
usa stanga spate (e36 sedan) - 100 ron
geam u.s.s (e36 sedan) - 50 ron
bandou u.s.s (e36 sedan) - 30 ron
actuator u.s.s (e36 sedan) - 40 ron
macara manuala u.s.s (e36 sedan) - 30 ron
maner deschidere u.s.s (e36 sedan) - 10 ron
usa dreapta spate (e36 sedan) - 100 ron
bandou u.d.s (e36 sedan) - 30 ron
actuator u.d.s (e36 sedan) - 40 ron
macara u.d.s. (e36 sedan) - 20 ron
maner deschidere u.d.s. (e36 sedan) - 10 ron
geam u.d.s (e36 sedan) - 50 ron
gem mic u.d.s. (e36 sedan) - 30 ron
usa fata stanga (e36 sedan) - 100 ron
actuator u.f.s. (e36 sedan) - 40 ron
usa fata dreapta (e36 sedan) - 100 ron
actuator u.f.d (e36 sedan) - 40 ron
oglinda u.f.d (e36 sedan) - 80 ron
coaja bord (e36 sedan) - 50 ron
torpedou (e36 sedan) - 40 ron
luneta (e36 sedan) - 50 ron
cutie viteze - 150 ron
stop spate dreapta (e36 sedan) - 40 ron
alternator 318i - 150 ron
electromotor 318i - 150 ron
amortizor bara fata - 20 ron/buc
ansamblu stergatoare - 50 ron
buton lumini - 30 ron
pompa ABS - 100 ron
calculator ABS - 100 ron
vas lichid frana - 20 ron
motoras relanti - 100 ron
maneta frana mana - 30 ron
maner deschidere capota - 30 ron
clapeta acceleratie - 50 ron
galerie admisie 318 M40 - 50 ron
protectie cardan - 50 ron
ceas analogic - 20 ron
guri aerisire - 10 ron/buc
plafoniera - 15 ron
ornament clapa interior usa - 10 ron
manere plafon - 10 ron/buc
buton reglaj lumina ceasuri - 20 ron
buton reglaj faruri - 20 ron
parasolare - 15 ron/buc
perdele spate - 30 ron
capace boxe interior fata - 30 ron
vas lichid stergatoare - 30 ron
plasti din jurul volanului - 30 ron
maneta stergatoare - 30 ron
maneta semnalizare - 30 ron
contact electric - 30 ron
cablu capota( mic+ mare+iale) 50 ron
servofrana - 50 ron
pompa ambreaj (de pe c.v.) - 70 ron
pompa frana - 80 ron
coloana directie - 40 ron
capac tacheti - 50 ron
ambreaj (placa + disc LUK ) - 100 ron
racord admisie-debitmetru M40 - 50 ron
bobina inductie M40 - 50 ron
capac capota bortbagaj - 10 ron
capac motor - 10 ron
imobilizator - 50 ron
bara stabilizatoare fata - 40 ron
galerie evacuare M40 - 50 ron
buson rezervor - 20 ron
furtune - 10 ron/buc
suport motor dreapta - 20ron
lucas - 10 ron/buc
senzor ABS fata - 50 ron
actuator rezervor - 50 ron
plastic sustinere bara fata dreapta - 20 ron
bandou aripa - 20 ron
cric - 80 ron
buton oprire geamuri electrice - 20 ron
suport motor stanga - 20 roN
diferential 3.45 - 200 ron
Edited by myke5115
salut, ansamblul ala de valve care deschide/inchide caldura pt varianta cu clima dubla manuala?
nu stiu la cete referi...daca ma ajuti cu o poza ceva este posibil sa il am.
Contact( doar miezul )+ butuc usa+ butuc portbagaj si cheie, pret?
salut
ceva fotografii cu torpedoul daca mai este valabil?
multumesc.
salut
multumesc.
salut,este torpedoul,daca mai eti interesat anunta-ma si ii fac poze.
Sal, suportul de la bratul fuzetei dreapta?
Edited by r0n1n
salut, ma intereseaza tampoanele de la motor stanga si dreapta mai sunt disponibile?
O seara buna.
sal, ma intereseaza si pe mine daca ai chederele de la usile fata, cele prin care urca geamul, ale mele pe exterior le-a tot prins geamul si s-au facut praf.
