ISTA 4.11.22 / SDP 4.11.20
In Torrent o sa aveti tot pachetul ISTA-D (diagnoza/programare), ISTA-P (programare) si bazele de date aferente.
Pentru a instala doar ISTA-D trebuie sa bifati din Torrent: ISTA-D , SQLiteDBs si Tools (Pentru cine are ICOM si vrea sa faca si programare cu ISTA-D poate sa bifeze si SDP care se dezarhiveaza si se copiaza in folderul PSdZ din ISTA-D)
Pentru a instala ISTA-P aveti ghidul in folderul Tools - FAQ-EN.pdf iar pentru ISTA-D trebuie doar sa urmati ghidul de mai jos.
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft or Tools folder.
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
Antentie !!!
ISTA-D 4.11.22 with SDP.rar
  • Replies 71
  • Views 36.1k
  • bimmer90f30
    bimmer90f30
    Avand in vedere limtarile date de Mega pentru downloadari mari, spre exemplu 54GB, cine stie cum se poate face un donwload atat de mare fara sa trebuiasca sa platesti abonament la Mega? Ca altfel e ca
  • bimmer90f30
    bimmer90f30
    Dumnezeule cati hate-ri aiuriti sunt pe aici...   RaYn3, multumesc de replica. Am mai avut noi incrucisari de opinii dar apreciez parerile bune. Sa inteleg ca pana intr-o luna pot anula contractul si
  • Rheingold 4.11.32 Standalone / SDP 4.11.30 / ISTA-P 3.64.2.000 ISTA-D 4.11.32.rar
:suicide:
Nu il gasesti aici pe topic sa il downlodezi sau .....
PS: Vezi jos dupa poza :D
Multumesc! In topicurile anterioare arhiva continea fisiere, nu torrenti...m-am hazardat.
Intrebarea cretina numarul 2:
Ce inseamna pasul asta?:
Thanks!
Edited by Florin_pch
Thanks! So far so good!
Nu gasesc registry entryul pentru SQLite, doar pe cel de insta-d. Cand pornesc aplicatia, primesc o eroare care imi spune ca nu se poate conecta la baza de date.
Am downloadat doar EN si in folderul SQLiteDB am doua fisiere: streamdataprimitive_ENGB.sqlite si xmlvalueprimitive_ENGB.sqlite
Trebuie sa mai fie vreunul, sau e din cauza acelui regedit pe care nu l-am gasit, implicit nu l-am aplicat?
Edit: cred ca imi raspund singur...trebuie sa dldez si Others si sa mut acolo...
Ok, am reusit sa instalez, gasesc masina dupa VIN, deci totul e ok cu baza de date.
Problema pe care o am acum e ca nu imi apare conexiunea in Connection Manager. In device manager pot sa vad cablul, intra pe COM3, dar in aplicatie nu imi apare nimic. Cand ii dau Read Out Vehicle Data apare mesajul ongoing backround process, please wait, dupa care dispare fara niciun mesaj de eroare. In Setting la VCI Config, am incercat atat cu Ediabas default setting, cat si cu OMITEC interface (USB/serial). Se comporta la fel.
Gresesc ceva, sau par simptomele cunoscute?
Multumesc mult pentru ajutor!
Daca am o versiune mai veche, 4.8.13 de ce am nevoie ca sa fac update-ul la ultima versiune ? Trebuie downloadat tot pachetul ?
Multumesc!
sal. am un f30 apare eroarea drivertrain . in ista D are 2 eroari pe dpf.
244800-info DPF Limited remaining distance...
244900-DPF maximum service life of particulate filter exceeded - care apare cand ai trecut de 200.000km.
nu reusesc sa gasesc "replacement particulate filter" ca in imaginea alaturata. sau pentru asta trebuie sa instalez ista p?
Foloseste functia search :D
@baronu25
Vehicle Manangement - Service functions - Power Train - Digital Diesel Electronics - Diesel particulate filter - ai acolo regeneration si replacement.
Thanks!
Trebuie sa rulezi ca administrator.
Click dreapta: Run as Administrator
Salut, daca am ista-d 4.10.xx cum pot adauga versiunea mai noua, sau se reiau pasii de la inceput?
Am instalat ISTA-D 4.11.22 pentru un E90 320 D LCI , se conecteaza identifica masina , pot sa citesc valorile injectoarelor , codurile lor , aici am o problema nu corespunde codul de pe injectoare cu cel din aplicatie decat pentru un injector celelalte nu corespund , insa nu pot gasi in DDE ABL read dde measared values. Daca intru in aplicatie cu vin masina fara sa ma conectez la ea , la service function imi apare doua module de DDE pe unul gasesc ABL de masurare a valorilor iar in celealt modul DDE gasesc ABL pentru injectoare. Daca ma conectez la masina imi apare numai un modul DDE cu ABL pentru injectoare. ABL read dde measared values nu il gasesc.
Eu cred ca ar trebui sa reformulezi ce incerci sa afli.
Am incercat de 5 ori sa inteleg ce spui si nu inteleg, cel putin in prima fraza.. In care subiectul se pierde rapid.
Ai o aplicatie careia nu ii dai nume in care gasesti cod de injectoare dar nu pe toate sau pe toate, dar nu poti afla valorile injectoarelor pentru ca ABL, nu il gasesti..
Nu mai are importanta sa spui ca se conecteaza ISTA-D, din moment ce functioneaza programul (conectandu-se chiar .. partial probabil pe anumite module..), tu acest lucru trebuie sa incerci sa il explici ....... chiar daca (pentru un motiv sau altul) vrei sa descrii o problema prin DOUA programe/aplicatii (whatever) diferite ... asta face gasirea raspunsului si mai dificila!
(dar poate altii inteleg mai bine ce vrei)
(mai lucreaza la plasarea virgulelor, foarte importante intr-o fraza!)
Cand ma conectez la masina nu gasesc in service functions DDE - ABL read dde measared values, iar daca ma conectez offline (doar prin VIN) imi apare aceasta functie DDE - ABL read dde measared values. Incerc sa aflu daca este o problema cu programul la instalare si care ar fi anume ?
Am atasat 2 printscreen-uri . In primul print nu apare ABL read dde measared values varianta cand sunt conectat la masina iar in al doilea nu imi apare varianta offline
Edited by denilson
Te-ai conectat cu "complete identification" ?
Da.Se conecteaza cu masina o identifica , citeste erorile pot sa citesc corectiile de la injectoare , dar nu gasesc ABL read dde measared values.
Du-te in DDE, call up ecu function si ai acolo valorile in timp real.
Edited by anormal
Ok. Incerc si va tin la curent. Multumesc.
Am intrat in call up function si am citit valorile in timpul real. Referitor la codurile injectoarelor ( la mine nu corespund la 3 cilindrii ) dupa introducerea lor pentru fiecare cilindru , se salveaza operatiunea , mai trebuie facut ceva ?
