Donatii - daca doriti sa ajutati pe cineva,
Multumesc. Atunci astept un raspuns.
Nu le mai vrea... Are modelul cu doua boxe pe usa...
Ce am eu este modelul de dupa 96 cu mufa mica, 3 pini si sistem de prindere prin infiletare pe un capac de plastic nu cele putin mai mari cu prindere prin infiletarea unei tije cu o gheara si cu 2 pini (93)
http://www.realoem.com/bmw/partxref.do?par...&showeur=on
Part 65138362946 (Tweeter) was found on the following vehicles:
E36: Details on E36
E36 318i Convertible, USA
E36 323i Convertible, USA
E36 325i Convertible, USA
E36 328i Convertible, USA
E36 M3 Convertible, USA
E36 318i Sedan, USA
E36 318is Coupe, USA
E36 320i Sedan, USA
E36 323i Coupe, USA
E36 325i Sedan, USA
E36 325is Coupe, USA
E36 328i Coupe, USA
E36 328i Sedan, USA
E36 M3 Coupe, USA
E36 M3 Sedan, USA
E36 318i Convertible, Europe
E36 320i Convertible, Europe
E36 323i Convertible, Europe
E36 325i Convertible, Europe
E36 328i Convertible, Europe
E36 M3 Convertible, Europe
E36 316i Touring, Europe
E36 318i Touring, Europe
E36 318tds Touring, Europe
E36 320i Touring, Europe
E36 323i Touring, Europe
E36 325tds Touring, Europe
E36 328i Touring, Europe
E36 316i Sedan, Europe
E36 316i Coupe, Europe
E36 318i Sedan, Europe
E36 318is Coupe, Europe
E36 318is Sedan, Europe
E36 318tds Sedan, Europe
E36 320i Sedan, Europe
E36 320i Coupe, Europe
E36 323i Sedan, Europe
E36 323i Coupe, Europe
E36 325i Sedan, Europe
E36 325i Coupe, Europe
E36 325td Sedan, Europe
E36 325tds Sedan, Europe
E36 328i Coupe, Europe
E36 328i Sedan, Europe
E36 M3 Sedan, Europe
E36 M3 Coupe, Europe
La mine (E36 coupe 1993 ) nu se potrivesc...
Edited by Rin_Tin_Tin
pt rin tin tin..telescoapele de capota mai sunt valabile?am eu nevoie mare de ele
Am doar unul si nu trimit la constantza... Sorry.
Doar pt bucuresti....
Oricum sa nu-ti para rau ca nu se potriveste pe E34 ( parca asta vad in poza la avatar... )
donez si eu:
un termostat cu corp cu tot si senzorul de pe el pt un e46 din 2000 (316i) 105cp;
un motor de 2200 cmc, 170cp, are blocul spart la pistonul 1 si biela rupta, in rest are tot ce trebe pe acolo inclusiv _chiulasa_;
doua radiatoare de e39, unul are o mica fisura cred (pierde apa pe la furtunul din partea superioara) iar unul ii lovit in lateral, cred ca curge bine.
Donez 4 jante alu bmw oem e36 6j/15 fara anvelope
astea au mai ajuns la cineva ?
sunt inca la mine pentru ca sufar grav de timp liber si nu am ajuns la Fan Courier sa le trimit lui Zoli, fata de care imi cer scuze dar promit ca le trimit!
Nu i problema ,cu totii suferim de timp liber......stai linistit astept rabdator. Respect!
Se vand cu 200 de euro acu jantele astea,dar au si gume.
Pacat,dadeau bine in locul la bbs-urile mele.
Cusuta cu alta alba e fraza : "Imaginea este doar pentru prezentarea modelului. "
Edited by wii
Domnule Sorin , jantele de care ziceti dv. provin de pe un 318is care s-a vandut cu alt set de jante pe 17'' .Jantele sunt impecabile si au gume aproape noi pe ele. Nu este frumos sa aruncati cu noroi in userii de pe forum doar de dragul de a fac numar de posturi si de a cauta "afectiune cu japca'' din partea celorlalti useri.Pur si simplu nu este frumos sa vorbiti fara a fii in cunostinta de cauza.Pentru mai multe detalii despre jante mai bine il sunati pe cel care le vinde in loc sa faceti acuzatii gratuite.
Va pot da mai multe detalii care sustin ceea ce scriu mai sus daca doriti.
Am raspuns eu deoarece cel care le vine se intampla sa fie foarte bun prieten cu mine , nu are legatura cu ce zici tu de jantele de mai sus care erau la donatii iar cand a fos adusa din Germania masina respectiva am fost si eu cu el sa imi iau masina si stiu perfect despre ce este vorba.
Multa bafta va doresc.
Edited by sckhreech
Merci de interventie Sk dar as mai avea ceva de adaugat. Daca te oboseai sa dai un search ai fi vazut ca am jantele dinainte de acel anunt (masina se vindea ori cu cele pe 17' ori cu cele pe 15'). Intamplarea face ca am postat aceeasi poza, asta pentru ca dand un google, este prima poza care iti apare pentru acest model de janta, asa ca nu o sa mai spun ca esti retardat (ai o scuza). Cam atat...
Bafta la rautati in continuare.
Edited by altrixkk
multumesc mult de lamurire
imi cer scuze in cazul asta,nu e necesar sa degeneram in altceva.
iar tu nu ai nici o scuza sa faci atac la persoana ,respectiv sa jignesti. esti cel putin la fel de retard ca si mine in cazul asta,daca apelezi la jigniri.
succes
Edited by Sorin Maxim
donez si eu:
mai adaug o pompa de abs cu dsc, partea electronica este dusa. (pompa in stare de funcitonare, calculatorul-modulul 2 pini arsi)
donez si eu:
donez si eu:
donez si eu:
ai idee merge sa pun pompa de abs cu dsc in locul celei care o am acum cu asc?
Edited by maryuss
