Everything posted by zixx
Societati de asigurare cu care lucreaza Bavaria
Cand am cumparat masina ,am vrut sa fac casco la Allianz.Nu aveau decontare directa cu AB. Apoi am intrebat la AB:aveti agreement de decontare directa cu vreo firma de asigurari ? Raspuns:nu :blink: In curand imi expira casco,asa ca sunt si eu interesat :)
Ce inseamna ca asiguratorul sa agreeze AB. Daca te referi la decontare directa intre AB si asigurator,nu exista nici o astfel de colaborare.
- Accidente
- Accidente
Oare ce face SET LIMIT 6?
Daca e 20 inseamna ca nu e viteza...mai cautam :blink:
Care este valoarea maxima la care poti seta functia ? La unele modele se poate seta o viteza maxima de rulare a masinii.Peste aceasta limita esti avertizat. Ex.pt E28 "Maximum MPH Function. You can set the OBC to act like your mother-in-law if you want, but if that's what you want why did you buy a BMW? This function causes the OBC to nag you with a bong if you exceed the speed setting stored in the Max MPH function. Press the M MPH button, then enter the speed you want to set as a limit, using the numeric buttons as described earlier. Then press M MPH button a second time to start the mother in law up. The little LED in the face of the button will light to tell you the function is on. Whenever you exceed the speed you entered, the OBC goes "bong" and the LED starts to flash. As noted earlier, if the OBC is operating in metric mode this function operates in kilometers per hour"
BMW 330i
Vrem drive test ca sa ne convingem :blink:
Accidente
Pilotul a scapat masina de sub control,a incercat la un moment dat sa traga un pic dreapta de volan,dar s-a dus sanie. Cel care a fost luat in plin a avut super inspiratia sa sara in momentul impactului :blink: Nasol rau...dar spectatorii nu aveau ce cauta pe acea parte a drumului ! Later edit...am vazut ca spectatorul a avut dubla fractura de brat si picior,ceilalti au scapat ieftin.
BMW 330i
Intreb,nu dati cu parul in nestiutori :blink: ...filtrul de benzina are un sens de montare.Se poate monta invers ? @GuestX Cati litri de ulei ai folosit la schimb ?
BMW 330i
Bine ai venit ! Sa stapanesti sanatos masinuta ! Becul de ulei aprins pe galben inseamna nivel scazut de ulei in motor.In cazul in care nu mai exista o alta problema,se va stinge dupa completarea cu ulei(~0.5 l). Si mie mi s-a intamplat la fel http://www.bmwclub.ro/forums/index.php?showtopic=307&st=20 Pe viitor este bine sa ai 1l de ulei de rezerva la tine,pentru completari. Pentru filtrul de benzina nu stiu sa-ti raspund. Asteapta si alte opinii ! :blink:
Ce probleme pot sa apara la un BMW
km.la bord 19.000 Ceva scartaie ocazional in stalpul din dreapta fata(prin zona airbag-ului :) ).Zgomotul este absolut enervant. Mi se pare ca cedeaza iar coloana de directie(se aud f.f. incet niste zgomote la denivelari)-abia am schimbat-o :blink: Este posibil sa cedeze asa repede ?Nu am luat absolut nici o groapa serioasa de cand am inlocuit-o !Pareri ?? Inchiderea centralizata face figuri.Se aude uneori un pocnet la usa din dreapta spate,cand inchid usile.
Merita schimbul?
Nu ai fi primul :) Si pe acest forum nu se vorbeste doar de bine despre BMW :blink:
Merita schimbul?
@Doru Este a doua oara intr-un interval f.scurt,cand esti rugat de catre unul dintre moderatori,sa fii mai ponderat in exprimare si totusi nu tii cont de lucrul asta. Te rog abtine-te de la atacuri la persoana. :blink:
detalii motor 530D - 525i model 2001
Poti sa postezi informatiile aici. :blink:
Stie cineva sa repare o trapa de ursulet?
Sunteti off-topic :blink:
Las' ca va vad eu la iarna :blink:
Blasfemie :) :blink: ...(cine pana mea?!?) o sa iti bag zahar in rezervor si cuie la roti :) Si on topic:aici as merge pe mana lui 530d
Garantia reprezinta o problema ?
warranty_4_cars,primesti o meritata vacanta de 2 saptamani ! Daca mai faci spam,pleci in concediu de tot :blink: Numai bine, zixx
hai sa sustinem bmw
Bine ai venit ! Data viitoare daca mai postezi acelasi mesaj in trei arii diferite si total aiurea,primesti ban ! :blink: Te rog arunca un ochi si pe la regulament. Numai bine, zixx
Preturi la 3er in RO ?
Detalii despre CASCO http://www.bmwclub.ro/forums/index.php?showtopic=1909
A luat-o masina razna...faza de SF!
Eu sunt convins ca ai avut o intalnire de gradul 3 :blink:
Trepidatii in viraje
Din cate am vazut este vorba de un E36 316i din 1991. Verifica in ordine: -integritate anvelope(galme,uzura neuniforma) -presiune corecta si egala in rotile de pe fata -echilibrarea corecta a rotilor -jocuri in articulatii
In linie dreapta,la aceasta viteza,se simt trepidatii ?
oglinzi incalzite
E aia din fabrica,la fel ca la tine :blink:
oglinzi incalzite
A mea mai este cea din fabrica doar pe stanga :blink:
