Vadim
Everything posted by Vadim
  1. Cati Km are masina ?? al meu are 303 000 si segmentii sunt brici :blink:
  2. deci inseamna ca se dilata ceva si incep sa apara pixeli :blink:
  3. bipaie doar daca este setat sa bipaie :blink:
  4. Discutia se continua aici : http://www.bmwclub.ro/forums/index.php?showtopic=10514 Topic closed
  5. Vadim
    lumina interior
    spune mi si mie cat ai dat pe becuri :blink:
  6. Vadim
    lumina interior
    mie unu imi place la nebunie portocaliul :)
  7. si eu am problema aia la servo :blink:
  8. Ce mi ziceau testele azi cu contactul pus in pozitia a 2 a si temp motorului la jumate : testul 15 : 01.c1 diag 02.c2 diag 03.53 diag 04.1c diag 05.c5 diag 06.c6 diag 07.a7 diag 08.20 diag 09.06 diag Testul 16 : 01.80 port 02.40 port 03.58 port 04.1b port 05.4b port 06.40 port 07.80 port 08.40 port ( variaza ) 09.0f port Testul 17 00.78 prom 01.00 prom 02.00 prom 03.00 prom 04.9c prom 05.78 prom 06.50 prom 07.28 prom 08.14 prom 09.11 prom 0a.5b prom 0b.a4 prom 0c.d6 prom 0d.e5 prom 0e.28 prom 0f.08 prom 10.cb prom 11.21 prom 12.00 prom 13.00 prom
  9. mie imi afiseaza cand este cu mult sub minim :blink:
  10. ai pus u bec sau cum , k astea pt europa nu au asa ceva ... :blink:
  11. stiu , dar la mine nu mere :blink: am tras fir ...... si tot nu mere :)
  12. Astea sunt coduri hexa ?? : The first thing to do when you troubleshoot your Bmw E34 engine is to read your Engine Codes. (not all codes apply to all engines) 1211 DME Control Unit 1215 Air Mass Sensor 1216 Throttle Potentiometer 1218 Output Stage, Group 1 1219 Output Stage, Group 2 1221 Oxygen Sensor 1 1212 Oxygen Sensor 2 1222 Lambda Control 1 1213 Lambda Control 2 1223 Coolant Temperature Sensor 1224 Intake Air Temperature Sensor 1225 Knock Sensor 1 1226 Knock Sensor 2 1227 Knock Sensor 3 1228 Knock Sensor 4 1231 Battery Voltage/DME Main Relay 1232 Throttle Idle Switch 1233 Throttle Wide Open Throttle Switch 1234 Speedometer A Signal 1237 A/C Compressor Cut Off 1242 A/C Compressor 1243 Crankshaft Pulse Sensor 1244 Camshaft Sensor 1245 Intervention AEGS 1247 Ignition Secondary Monitor 1251 Fuel Injector 1 (or group 1) 1252 Fuel Injector 2 (or group 2) 1253 Fuel Injector 3 1254 Fuel Injector 4 1255 Fuel Injector 5 1256 Fuel Injector 6 1257 Fuel Injector 7 1258 Fuel Injector 8 1261 Fuel Pump Relay Control 1262 Idle Speed Actuator 1263 Purge Valve 1264 EGO Heater 1265 Fault Lamp (check engine light) 1266 VANOS 1267 Air Pump Relay Control 1271 Ignition Coil 1 1272 Ignition Coil 2 1273 Ignition Coil 3 1274 Ignition Coil 4 1275 Ignition Coil 5 1276 Ignition Coil 6 1277 Ignition Coil 7 1278 Ignition Coil 8 1281 Control Unit Memory Supply 1282 Fault Code Memory 1283 Fuel Injector Output Stage 1286 Knock Control Test Pulse 1444 No Fault Codes
  13. Inca o chestie referitoare la meniul secret de la obc : http://www.BMW.info/forum/showthread.ph...light=obc+codes
  14. ai si ASC , ca nu vad butonul :blink:
  15. Aici se va discuta pe margine.... upgrad uri etc
  16. Aici se va discuta despre probleme la E30
  17. Vb pe msg ...... sa nu mai fim Of....
  18. ok , am sa verific si am sa ti spun :) P.S. da mi si mie link ul cu datele meniului secret de la obc :)
  19. cc ul nu zice nimic de ABS , deci mecanicu mi a zis k pe com i a iesit senzorul dr fata :) bun....alaltaieri am dat roata jos ca sa l scot si sa l schimb , cand am dat de el , am observat k se misca putin si ca in loc de imbus avea un surub :blink: P.S. la e34 nu trebuie resetate eroarea cand ii schimbi senzorul :)
  20. masina lui este din 89 , deci ..... nu cred ca este de ingrijorat 1l/1000 km faza cu pornitu poate sa fie chiar din debitmetru :blink: cel mai simlu : DIAGNOSTICARE :)
  21. 1 L ulei/1000 km nu trebuie sa te ingrijoreze :) Pt a schimba limba cc ului , pui contactul in pozitia 1 , ti apasat timp de 20 de secunde pe butonul din treapta (de la ceasuri ) si acum o sa ti apara english Us repeti procedura pt alta limbi ( cred k o sa o lasi la engleza :) ) P.S. motorul este m20b25
  22. sau ma rog... faza e ca nu are are gaura de imbus :)
