Livyu18CT
Everything posted by Livyu18CT
  1. bobo ma ajuti si pe mine sa-l montam pe un e39 din 03.2001 ? <_<
  2. Maine voi ajunge prin bucuresti si voi sta vreo doua zile :blink: mi-am cumparat comenzile de la un e46 din 2002, le-am montat pe e39 si am fost la un meserias sa-mi faca legaturile (dupa diagrama) dar dupa o munca de vreo doua ore :blink: am constatat cu stupoare ca imi functioneaza doar luminile la comenzi <_< nici macar volumul sau posturile de radio :) :bashwall: :unsure: asadar, daca ma poate ajuta cineva as fi recunoscator :wub:
  3. mda, daca vrei iti pot trimite eu instructiunile de initializare/reinitializare :) scuze, abia acum am vazut. deci cred ca se poate inchide aici nu? <_<
  4. Engine variants: BMW 535i Gran Turismo: straight-six gasoline engine with TwinPower Turbo, High Precision Injection and VALVETRONIC, Capacity: 2,979 cc, max output: 225 kW/306 hp at 5,800 rpm, max torque: 400 Nm/295 lb-ft from 1,200–5,000 rpm, Acceleration 0–100 km/h: 6.3 seconds, Top speed: 250 km/h (155 mph), Average fuel consumption to the EU standard: 8.9 Liter/100 kilometres, equal to 31.7 mpg imp, CO2 emissions to the EU standard: 209 g/km, emission standard: EU5 BMW 550i Gran Turismo: V8 gasoline engine with TwinPower Turbo and High Precision Injection Capacity: 4, 395 cc, max output: 300 kW/407 hp from 5, 500–6,400 rpm, max torque: 600 Nm/442 lb-ft from 1,750–4,500 rpm Acceleration 0–100 km/h: 5.5 seconds Top speed: 250 km/h (155 mph) Average fuel consumption to the EU standard: 11.2 litres/100 kilometres, equal to 25.2 mpg imp CO2 emissions to the EU standard: 263 g/km, emission standard: EU5 BMW 530d Gran Turismo: straight-six diesel engine with aluminium crankcase and third-generation common-rail direct fuel injection (piezo-injectors), max injection pressure: 1,800 bar Capacity: 2,993 cc, max output: 180 kW/245 hp at 4,000 rpm, max torque: 540 Nm/398 lb-ft from 1,750–3,000 rpm Acceleration 0–100 km/h: 6.9 seconds Top speed: 240 km/h (149 mph) Average fuel consumption to the EU standard: 6.5 litres/100 kilometres, equal to 43.5 mpg imp CO2 emissions to the EU standard: 173 g/km, emission standard: EU5 Totusi... e BMW <_<
  5. Sa ramanem ontopic... "The GT rides on an modified version of the next-generation 5-Series sedan's platform. Measuring 4,998 mm (197-inches) in length, 1,901 mm (74.8-inches) in width and 1,559 mm (61.4-inches) in height with a limo-like 3,070 mm (120.9-inches) wheelbase, the GT is larger than the current 5-Series in every dimension." "Up until now, we only know of three power plants that will be made available on the 5-Series GT. These include two gasoline engines, the 3.0-liter twin-turbocharged straight-six with 306HP for the 535i GT that goes from zero to 100km/h (62mph) in 6.5 seconds and the 4.4-liter twin-turbo V8 with 408HP for the 550i GT that hits the 100km/h mark in 5.5 seconds. There's also a 3.0-liter turbo diesel with 235HP for the 530d GT that sprints from standstill to 100km/h (62mph) in 6.9 seconds." <_<
  6. http://www.bmwclub.ro/forums/index.php?s=&...st&p=727893 De asta ce mai comentati ?!? <_<
  7. Aici citezi din Autovit ?? <_< ti-ai dat seama de la ghilimele, hotule :)
  8. verifica sigurantele vezi ca ai un un tablou de sigurante in portbagaj, in partea din dreapta deasupra la baterie si mai gasesti un altul in torpedo <_< ai gasit ? :)
  9. vezi ca sunt cateva topicuri de dezmembrari, daca nu gasesti incearca pe gugle <_<
  10. frumoasa masina, daca tie iti place si esti multumit de ea, atunci totul e ok. legat de pret... "un pret mic nu inseamna intotdeauna o afacere buna" <_<
  11. de sambata are 163 CP, 320i e36 stie de ce :) . Merci mult frate... acum ma pot baga si eu in depasiri mai riscante :bashwall: Una peste alta e o treaba super cu softu` asta nou, multam il recomand <_<
  12. eu zic sa dai o fuga pana la dedeman si vezi ca la articole auto au leduri pentru pozitie si coata in jur de 8 lei setul. si-a pus un prieten pe un passat b5 si sunt chiar ok. legat de pret... sa sti ca le are pe masina de vreo 3-4 luni si functioneaza <_<
  13. sub bancheta spate, cea din dreapta este cu problema (asta daca are intr-adevar doua). Dar nu ti-as recomanda sa te bagi la tehnica, mai bine cere ajutorul unui cunoscator... <_<
  14. dupa cum am scris si in prezentare are husa. volanul este imbracat in piele si arata foarte bine, doar ca este prea... subtire :blink: am sa tin cont de parerea ta, multumesc frumos :unsure:
  15. verifica sonda de combustibil din rezervor. si eu ma confrunt cu aceeasi problema si se pare ca de acolo se trage...
  16. Multumesc Astazi astept comenzile pe volan si pe sambata il astept pe george aka "320i e36" sa-i mai crestem un pic puterea <_<
  17. mie sincer roadsterul z3 mi se pare cel mai dezagreabil model BMW... <_<
  18. As dori si eu o copie, da-mi un pm cu nr de tel. Multumesc
  19. La ce te referi cand spui ca va ramane uimit? Am si eu un e39 520d si ma batea gandul sa-i mai cresc puterea...
