muerte32003
Everything posted by muerte32003
  1. poate te ajuta schema asta
  2. locul lui este in canalul de aer de pe partea stanga deobicei, acela de langa locasul proiectorului. canalul de plastic trebuie sa aibe un orificiu unde se baga partea subtire a senzorului de temperatura
  3. poate te ajuta asta in functie de ce e mai jos poti cauta harti pe google sau torrente, in cazul in care nu iti da cineva copia dupa card link de unde am copiat informatia: https://www.farcebook.com/note.php?note_id=392570370530 What other maps can be used in Eonon, and how to make it? 7 January 2010 at 09:39 Many people who own Eonon GPS are not clear that except our built in map, what other map software can be used in our unit, now we would like to introduce to you. Until now, we know the following maps can be used in Eonon: POLNAV, IGO, Tomtom. G2201G2201 1. POLNAV is the built in Eonon map. We use the latest legal edition of POLNAV map! Different from other no brand GPS, we are using the legal map! It's the latest legal edition from POLNAV. 2. IGO is another map which can also be used in Eonon. Here this link in our Eonon forum shared by our customer Xperiat, he told us how to run iGo8 Navigation Software in our GPS: http://forum.eonon.com/Default.aspx?g=posts&t=1007 Quoted from his experience: "I was able to install the iGo8 Navigation software from Navngo! Also loaded up Caifornia Maps and am using this awesome GPS Navigation software. It's muc better than Smart2Go in my opinion and has tons of options!! PM me if anyone wants it and wants to give it a shot. I was also able to run TomTom 5.2 but Maps were inaccessible as the software expects them to be in the My Documents folder. So, I accessed the WinCe shell by getting to explorer (contact me for exact steps) and now my PNA is aso a PDA! How awesome is that?? So, now I boot into a Windows CE desktop interface and can launch my iGo GPS Navigation software from within (using a shortcut)." "The unit runs WinCE 4.2 and the version of iGo8 that I have is for PDAs, PNAs and WinCe4.2 and up devices. All one has to do is install the application to the root of the 2GB SD card and add the appropriate line i the YFAUTORUN.INI file. I have mine as \SDMMC\iGO8\iGO8.exe this instructs the Navigation Startup Screen to point to iGo8.exe in the iGo8 folder n the SD card. That's it...it loads up, discovers the GPS satellites and off you go! I have the California Maps, POIs and all the 3D Terrains loaded up and working well. Its fast and looks fantastic too. If you need the files (softwae + maps + POIs) then I can upload them somewhere (let me know where)...they're close to 1.8GB in size. Also, if you have the YAUTORUN.ini saved with the text "\explorer.exe" then it loads the WinCE 4.2 shell...the complete Windows CE UI with complete navigation, file explorer, one can run programs off the SD Card etc." E1025E1025 3. Tomtom can be also used in Eonon! Shared by one customer who posted here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=63829 Quoted from his experience: "Here is how I made "Tomtom" work on my eonon GPS unit with "SD card Mapping" that displays on the DVD unit.You can easily do this too! First I assume you own a licenced version of "Tomtom 6" second copy and save the files currently on the SD card to a safe folder on your pc (just incase you cock-up).Now format the sd card and create a folder on it naming it exactly like this ( MobileNavigator ) open this folder and also the folder on you pc that contains your copy of tomtom6. Copy and paste the files from tomtom6 into the folder "MobileNavigator" on the sd card." Are you still with me?" OK. Now locate the tomtom.exe file (Two red hands) and rename it "MobileNavigator.exe" when you have done this close the folder finaly go to the saved original software on your pc and you will find two very small files named 1.YFAUTORUN.INF and 2.autorun.inf copy and paste these two onto the sd card.Power off the gps unit fit SD card and power on. Bingo! it works well for me. Settings you may need in tomtom. The gps receiver now needs to be set,to do this..... Run the software,Tap screen and select " change preferences " find the icon " show GPS status" select this.Tap configure.Scrole forward to choose "Other NMEA GPS receiver" and select Set GPS Baud rate to " 9600" and click done.Select "Com one".Click done! And that's it!" Hope their experience is useful to you! That's so called community spirit! You can get happiness by sharig and helping others! Let's move on!
  4. pt oscilatii uita-te pe la furtune sa nu traga aer fals consumul marit poate fi si de la sonda/sondele lambda
  5. ti-am trimis un PM. sper sa gasesti acolo ce trebuie... nu stiu daca am voie sa postez link aici asa ca il gasesti in PM daca are airbag dual stage nu va fi functional, asta din cate am citit pe forum spor la citit si sper sa te lamureasca
  6. fara lu[e ai sanse mari sa fi amendat sau sa ramai fara talon, asta daca prinzi un politai nef..ut... iar daca iesi din tara cu masina sigur vei fi amendat (am patit-o in germania, 80e a fost amenda acu 2 ani) pt inceput poti incerca sa schimbi becurile intre ele sa vezi de la ce e (bec sau balast), dar cel mai bine ar fi sa revi la becurile normale sau sa iei faruri cu lupa daca vrei xenon ps: macar 1 bec ar trebuii sa ai cu tine in portbagaj tot timpul
  7. sti cumva daca interfata merge pe e36 (masina e din '93)? tot ce am putut gasi nu are specificat si e36 dar suporta masini din '96-'07 a incercat cineva sa le foloseasca si pe modelele mai vechi de e36 cu succes? imi cer scuze initiatorul topicului pt off-topic
  8. poate daca pui un nume/serie si model sau o poza cu ce scrie pe mufa albastra poate te pot ajuta eu
  9. Din link nu mi sa parut chiar as ade mult de desfacut, sper sa nu ma insel... Oricum astept o vreme ceva mai placuta, ca acuma la -10 -5 cat sunt pe afara e destul de naspa...
  10. Am primit si solutia pt problema mea de la Dan_316 prin pm. Pt cei care au aceeasi problema o pot rezolva exact cum scrie in link-ul urmator: link Multumesc la toata lumea pt sfaturile date.
  11. ms mult. in caz ca nu reusesc nici cum va trebui sa dezactivez pana la primavara. am sa incerc si varianta asta. ms mult
  12. sti cumva unde anume in usa? sa nu ma apuc sa fac usa bucatele )) edit: am mai citit odata toate postarile si am vazut ca zicea MiahiGSM in incuietaore ca e in incuietoare
  13. vin e ja39976 ma gandesc ca asta te intereseaza. ms de raspunsuri, dar pe stalp nu am vazut sa fie nici un contact...
  14. chiar nu a intampinat nimeni problema asta?? sa fiu asa de ghinionist...
  15. Am si eu o problema de ceva vreme care ma terminat si pe mine si pe mesterii la care am dus masina. Masina e un 320i e36 coupe din 93. La coupe cand deschizi usa coboara geamu aproximativ 1 cm si cand o inchizi urca geamul, de intra sub cheder. Problema sta in felu urmator, de cele mai multe ori cand inchid portiera, geamul nu mai urca sa intre sub cheder. Daca dupa ce am inchis usa ma apas mai tare pe ea urca, dar de cele mai multe ori cand vin sa plec cu masina geamul e iara coborat. Am mai patit sa coboare si in timpul mersului la o mica denivelare. Portiera in cauza e cea de la pasager, cu cea de la sofer nu am probleme deloc desi o folosesc zilnic. Sper ca m-am facut iteles.
  16. Dupa un mic incident cu un TIR am inceput sa am probleme la inchiderea centralizata. Adica mai exact incui masina si se deschide imediat ce cheia revine la pozitia normala. Mentionez ca de vreo 2 ani am montat si inchidere din telecomanda. Fie ca inchid din butuc sau din telecomanda imediat ce cheia sau butonul telecomenzi, dupa caz, revine la pozitia initiala masina se deschide. Ca sa se inchida masina, dupa ce se deschide singura trebuie sa deschid masina din cheie sau butonul telecomenzii, fara sa deschid usa, si sa inchid. Dupa ce inchid a 2-a oara masina ramane inchisa. Masina a fost avariata in partea stanga fata, mai exact aripa stanga fata in zona semanlizari, bara fata si grila au fost si ele afectate (m-am gandit ca poate ajuta). Inchiderea centralizata, fie ca inchideam din telecomanda fie din butuc, a mers fara probleme pana la incident. La cateva luni dupa ce am cumparat masina am fost avut ceva probleme cu manunchiul acela de fire care merge la portbagaj, dar a avut grija un electricean de ele. Masina e un e36 (320i) coupe din 93. Daca ma puteti ajuta cu ceva sfaturi v-as fi recunoscator. Multumesc.
  17. multumesc de idee Valy. E o idee destul de buna si asta sa schimb doar difuzorul. Ramane sa ma documentez putin despre el
  18. Am avut parte de un mic incident in parcarea clubului sambata seara, autorul parasind locul faptei si lasandu-ma cu paguba pe cap. Cu ocazia asta m-am gandit sa imi fac o mica schimbare la masina. Si acuma ca am temrinat cu toata povestea caut: -bara fata model M cu proiectoare, bandouri si canalele de aer pt frane; -bara spate model M (bara spate nu e lovita, dar daca tot pun M pe fata sa pun si pe spate); -grila cu nari facelift (daca se poate si cu spalatori de faruri cu tot cu instalatie daca nu nu e o problema); -capota fata. Mentionez ca masina e un bmw e36 coupe (320i) din 93. Astept oferte, si eventual poze pe e-mail: andone.ciprian@yahoo.com Mentionez ca piesele nu doresc sa prezinte rugina, de culoare nu e o problema ca oricum vor fi vopsite.
  19. multumesc. imi poti lasa un site, e-mail sau nr de tel de la prietenu tau cu dezmembrarile?? multumesc frumos
  20. am uitat sa specific, si imi cer scuze pt asta, masina e un e36 coupe din '93. la tragar si grila nici nu ma gandesc sa le indrept, pe mine ma cam speriat in vara pretul capotei, atunci a si fost schimbata din cauza ca capota (scuzati cacofonia) originala era mancata rau de rugina. din pacate am foarte putin timp liber din cauza locului de munca si de aceea am pus intrebarea aici, m-am gandit ca poate este un tinichigiu pe forum cat despre bara sigur va fi modelul M, iar grila m-am gandit sa fie facelift. multumesc pt raspuns linniesta, si mai astept raspunsuri cu capota pana ajung cu masina pe la un tinichigiu.
  21. Sa incep cu inceputu... Aseara ma mancat in fund sa ies cu masina in oras. Dupa cateva ore prin club, la plecare acasa am avut "frumoasa" surpriza sa constat masina lovita in partea din fata. Prin parcare nici urma de masini lovite si sa fie totul frumos, in timp ce ma uitam la masini daca sunt sau nu lovite vreuna ma luat si politia la intrebari... Dupa jumatate de ora de dat declaratii la masina lor, si incercari sa ii conving ca nu vreau sa fur nimic, m-au lasat in pace, spunandu-mi "Cu masina ta doar daca ai casco faci ceva daca nu asta e, scoti bani si ti-o repari, noi nu avem ce face." si dusi au fost... Masina la prima vedere nu pare rau avariata, politia zicand ca e doar grila botita, dar la a 2-a vedere am constatat ca si capota e indoita, suportul pe care sunt prinse farurile si radiatorul, si bara fata, adica de la bara fata e ghidajul lateral cred. Intrebarea mea este cu capota mai pot face ceva, adica o pot indrepta sau trebuie din nou alta capota? Atasez si cateva poze cu "norocul" meu de aseara...
  22. iti dau dreptate ca la e36 manunciul de cabluri, de la portbagaj, de cele mai multe ori face probleme. am avut si eu problema aceasta, dar aveam cu totu alte simptome. cum aprindeam faza scurta mi se ardea siguranta care tine de partea dreapta, imi facea figuri si inchiderea centralizata (adica mai bine spus ba mergea ba nu mergea inchiderea) si nu mi se mai lumina bordul. cam astea le mai tin minte, tanand cont ca am patit-o acuma vreo 2 ani imi cer scuze de off-topic sper sa rezovi cat mai repede problema
  23. eu i-am schimbat pe toti 4 sa fiu sigur. parerea mea e ca nu au pret prea astronomic si mai bine ii schimbi pe toti 4
  24. si eu am avut vibrati in volan la e36 coupe intre 100-120 km/h iar daca piscam putin frana si acceleram de cele mai multe ori dispareau. la mine a fost din cauza pivotilor, i=am schimbat si nu am mai avut treaba.
