Everything posted by -Sarpe-
E46 318d facelift - Mtech2
heheh nice car bro :)
Pot sa pun Jante 19" M6 pe un bmw 318 e46
daca jantele au ET mic vinde-le. pune o poza cu ele va vedem ce scrie pe ele (verso)
BMW E46 318i white alpine
o sa dispara cand pun noile faruri cu lupa. @Myx ti-am zis ca 7 ani o mai tin :)
...am si io un pisic mic...
foarte misto masina, daca esti din Bucuresti ar trebui sa vii cu ea la intalnirea saptamanala de la Academia Militara.
hai bro ma lasi :) le: este al 4 lea rand de jante asta :) mai merg ....
- BMW 320d M-Tech II
- E90 325iA
e46-328 dj-57-bya
pfoa m-ai dat gata cu modificarea adusa la motor 5 stele rating, cat a costat motorul / manopera si rar-ul ?
BMW E46 318i 1999 Engine : I 4 Engine Code : 19 4E 1 Fuel : Petrol Fuel System : MPI - Bosch BMS Engine Alignment : Longitudinal Drive : RWD Displacement : 1895 cm3 Bore x Stroke : 85.0 x 83.5 mm Type : 8 Valves Aspiration : N/A Compression Ratio : 9.7 Output : 118 cv (86 kW) @ 5500 rpm Torque : 180 Nm (132 lb.ft) @ 3900 rpm Gearbox : 5 speed Manual Wheelbase : 272.0 cm Length : 447.0 cm Width : 174.0 cm Height : 142.0 cm Front Brakes : Vented Discs (286 mm) Rear Brakes : Vented Discs (280 mm) Kerb Weight : 1285 kg Weight/Output Ratio : 10.8 kg/cv Front Suspension : Independent. McPherson. coil springs. anti-roll bar Rear Suspension : Multilink. Coil springs. anti-roll bar Top Speed : 206 km/h (128 Mph) 0 to 100 km/h : 10.4 s 0 to 400m (1/4 mile) : - s 0 to 1000m : - s Fuel Consumption* : 6.1L / -L / 11.0L / 7.9L (29 mpg) Range : 797 km Fuel Tank : 63 L Trunk : 440 L CO2 emissions : 190 g/Km UPGRADE 1-faruri 2-bara Mtech 2 3-jante 17+cauciucuri profil V 225x45x17 4-embleme hamman 5-manson schimbator+ frana mana piele 6-schimbator M 7-ornament frana mana ACS 8-angel eyes 10-xenon far + proiectoare. 11-bloc lumini cu suport de proiectoare (masina nu a avut proiectoare) 12-stopuri model facelift 13-trimuri al look 14-inele bord titan look 15-spatiu depozitare cu jaluzea 16-ornament pedale al 17-foot rest ACS 18-pleoape hamman look 19-presuri mocheta 20-jante tabla+ cauciucuri noi iarna 205x55x16 PIESE SCHIMBATE 1-debitmetru 2-kit ambreiaj + semering cutie. 3-garnitura distributie+capac culbutori 4-valva disa 5-valva PCV+furtun 6-radiator 7-vas expansiune+furtun 8-buji 9-sonde lambda (ambele) 10-flansa cardan. 11-cotul din spatele motorului. 12-discuri (toate 4) 13-amortizoare(toate 4) 14-placute frana fata 15-bucse 16-bielete 17-capete de bara 18-filtru benzina 19-lichid frana 20-antigel PLANURI DE VIITOR 1.faruri cu lupa 2-arcuri sport 3.2din (momentan are radio cass + magazie de 6 cd-uri) asa arata in 2007 cand am cumparat-o http://img535.imageshack.us/img535/1772/bmwstock.th.jpg dupa 3 ani de investitii arata asa http://img31.imageshack.us/img31/6011/24032010046ngnnnn.th.jpg va urma....
Xenon aftermarket..pe e36 ,faruri normale..
fiecare face cum il duce capul, eu mi-am spus parerea despre xenon after market, faza cu spalatorul intradevar este importanta, restul e can can.
:) :) :twoup: :( :D baliverne tata, eu am pe masina de 4 ani xenon made in china si nu m-a intrebat niciodata politia, rarul sau itp ul nimic si inca o data: nu primesc flash de la nimeni noaptea, doar cu exceptia cand am si proiectoarele aprinse (tot xenon) :) ps: intradevar farul cu lupa schimba tot aspectul la masina, de aceea vreau sa-mi cumpar, ca in rest no problemo. ps2: parerea mea (no offens) le: @calinbmw2000: vezi ca are sorin sau Mas la vanzare instalatii xenon. @Sorin Enache: 1 bec costa in jur de 100 ron depinde de unde-l cumperi, la fel si ridicatoarele de tensiune.
se ard becurile dupa ~ 1 an sau se strica ridicatorul de tensiune, in rest toate sunt chinezesti.
daca sunt reglate bine nu orbesti pe nimeni, si faza cu suptul energiei la pornit alta baliverna, lumina o aprinzi dupa ce pornesti motorul.
vopsirea gentilor
completeaza la profil locatia ca sa stim incotro te indrumam, daca esti din Bucuresti uite AICI un vopsitor.
vand bara fata bmw e46 nfl + proiectoare
bara fata oem e46 nfl culoare alb alpine 3 completa = 250 ron cine vrea proiectoarele separat (oem hella)+ becuri = 150 ron bara necesita vopsire + chituire, atasez o poza pentru a se vedea crapatura de 3-4 cm insesizabila la prima vedere. ps: sunt disponibile de miercuri incolo (24-03-2010) http://img9.imageshack.us/img9/1452/dsc03705x.th.jpg LE: contact: 0744 706 537 se adauga canale aer NFL e46 cele stoc = 100 ron ambele. bara si proiectoarele sunt deomntate dupa masina deci sunt disponibile. ps: cine vrea doar bandourile = 50 ron toate inclusiv grilele de jos. bara simpla fara nimic = 50 ron (coaja) http://img638.imageshack.us/img638/84/123yj.th.png
Vand Jante Bmw
ai PM.
Scartzait inervant
1: despre ce 3-ar vorbesti? 2. completeaza la profil locatia. 3. nu mai baga in seama toate nimicurile. 4. succes.
vand bara fata / spate , proiectoare , grile capota bmw e46 non-facelift
mie imi trebuie doar bandoul dupa partea dreapta spate, am zis sa iau tot setul complet ca nimeni nu da pe bucati, decat cei de la reprezentanta dar daca iau doar bandoul care imi trebuie o sa se vada diferenta intre cel nou si cele vechi :) ms oricum.
bandourile dupa bara spate le vinzi separat ? thx
- plafon negru
Adobe photoshop - Virtual tuning
m-am jucat si eu un pic in photoshop, cobai fiind cazanul meu de data asta :) http://img521.imageshack.us/img521/3220/3bmwe46tttt.th.jpg si cu bara M tech 2 care sta frumusel si asteapta caldurica pentru a fi montata :) http://img198.imageshack.us/img198/4343/19459729.th.jpg le: npc @Razvan Gavan
BMW 320d M-Tech II
acum am vazut-o si eu LOCO LOCO LOCO ! :)
BMW 320d M-Tech II
busu este de vina :)
- Schimbare culoare E46
[Cumpar] eleron M3 si tunele aer pt bara M
Sunt diferite daca pui bara Mtech 2 pe facelift! la non facefilt iti trebuiesc doar canalele de aer.
