Everything posted by paul paul
BMW 320d stare exceptionala
Vand Bmw 320d touring stare perfecta de functionare. Km 260800 VIN: WBAAP71010PP22993 Type code: AP71 Model: 320D (EUR) E-F-R series: E46 3FL Series: 3 Type: TOUR Steering: LL Doors: 5 Engine: M47DO1 Displacement: 2.00 Power: 110 (149 hp) Drive: HECK Transmission: MECH Paint code: A08 - SILBERGRAU METALLIC Upholstery code: H9AT - STOFF JACQUARD/A Prod.date: 2004-06-03 S1CA SELECTION COP RELEVANT VEHICLES S8SP Control unit COP S167 EU4 exhaust emissions standard S210 Dynamic stability control S240 Steering wheel, leather S249 Multifunction f steering wheel S279 BMW light-alloy wheel star spokes 45 S302 Alarm system S386 Roof railing S403 Glass roof, electrical S411 Window lifts,electric,front/rear S423 Floor mats, velours S428 Warning triangle and first aid kit S431 Interior rear-view mirror with auto dip S473 Armrest front S493 Storage compartment package S494 Seat heating driver/passenger S502 Headlight cleaning system S508 Park Distance Control (PDC) S520 Fog lights S522 Xenon Light S534 Automatic air conditioning S548 Kilometre speedo S550 On-board computer S650 CD player S661 Radio BMW Business (C43) L801 NATIONAL VERSION GERMANY S832 Battery in luggage compartment S851 Language version German S863 Dealer List Europe S879 Operating instructions German S915 Omission of outer-skin preservation S934 WINTER TYRES ON LT/ALY WHEELS P972 Comfort package PRET 3990 EURO poze https://www.olx.ro/oferta/bmw-320d-touring-150cp-intretinuta-ID8A8B1.html
BMWhat / Carly - diagnoza, testare, verificare, stergere erori, soft-codding
An nou fericit, cand vreau sa codez la e46 2004 cu cablu albastru imi da error 70. Care e problema?
BBO 2.0: 535d
Multumesc pentru raspuns!
BBO 2.0: 535d
Salut, felicitari pentru noua achizitie, referitor la clapeta de acceleratie, am un 320d 150 cai din 2004 E4, are clapeta acest motor? Te intreb deoarece am si eu aceleasi simptome cu ai descris mai sus?
Salut, in primul rand multumim pentru aplicatie este foarte buna, doar cand vreau sa codez imi da code error 70 imi cere sa sterg si sa reinstalez aplicatia, asta dupa ce intru in module si pot sa vizualizez codarile disponibile.
Mulțumesc pentru raspuns probabil este din cauza aplicatiei. Probabil merge la modele mai noi.
Mie la e46 2004 imi vede doua module la codare ma conectez la ele, iar cand dau sa faca backup se opreste undeva la 70 % si zice sa repet procedura iar pe langa asta nu imi apare in dreapta jos butonul de load backup.
Am instalat aplicatia functioneaza perfect cu cablu d-kan dar nu reusesc sa codez. Trebuie facute alte setari? Multumesc anticipat!
Ceasuri e39 2002
Mersi dar imi trebuie pentru manuala daca stii in alta parte.
Ceasuri e39 2002
Salut modelul este cu 3 mufe si cutie manuala? Poti sa-mi poze?
Ceasuri e39 2002
Cumpar ceasuri bord e39 cu trei mufe 525d 2002 sa fie display ok. Tel:0744379983
Trage "dubios"
Salut, aceeasi problema o am si eu daca ai reusit sa rezolvi ceva cu ea?
Interpretare erori INPA
- Interpretare erori INPA
Salut revin cu problema legata de cele doua erori, am schimbat senzorul map iar acum apare doar prima eroare adica 4191, lipsa de putere se mai simte dar mai putin tot asa in perioade scurte ca inainte. Cred ca problema la mine este ca in acest clip: A mai rezolvat cineva ca in clipul de mai sus problema si poate sa ma ajute cu sfaturi? Daca stie un coleg de pe forum, se poate demonta actuatorul fara sa dau jos tubina de pe masina la e46?- Interpretare erori INPA
Turbina cu actuatorul electronic sunt ok furtunele au un an vechime. Mersi oricum!- Interpretare erori INPA
Mersi, se poate da jos fara sa desfac admisia?- Interpretare erori INPA
Un coleg daca ma ajuta si pe mine cu erorile de mai sus?- Interpretare coduri eroare in INPA
Daca senzorul de presiune de pe admisie se defecteazĂŁ are un cod separat sau nu neaparat?- Interpretare coduri eroare in INPA
Acestea ar fi codurile de eroare conform autodata. P1252 Turbocharger (TC) vane position actuator - signal voltage low Wiring, turbocharger (TC) vane position sensor. P1296 Turbocharger (TC) boost pressure sensor - pressure too high Wiring, hoses, TC boost pressure sensor- Interpretare coduri eroare in INPA
Am scos clapetele de admisie am schimbat anu trecut toate furtunele de vacuum, nu stiu ce mai as putea verifica.- Interpretare coduri eroare in INPA
Salut, motorul are momente cand la schimbarea mai brusca a directiei de mers in depasire de obicei, pierde putere se tureaza greu iar acul la consum ramane la 11%. Dupa cateva secunde isi revine si merge normal, am observat ca dupa ce o turez peste 3000 de turatii isi revine. Am dat jos turbo este ok am verificat si actuatorul electronic, este in parametri. Eu nu cred ca am asa ceva la motor din ce am vazut eu, referitor la power box si poti sa-mi arati o poza cum arata si unde a fost amplasat?- Interpretare coduri eroare in INPA
Dca ma ajuta cineva ce sa mai verific la motor, am dat jos turbo verificat fara nici o problema inclusiv testat actuatorul electronic care este in parametri. Este vorba de e46 320d 110kw 2004.- Interpretare erori INPA
Buna ziua, daca ma poate ajuta si pe mine cu interpretarea urmatoarelor erori atasate. Problema e ca motorul are momente cand nu trage mai ales la schimbare brusca de mers in depasire dupa care isi revine, acul de la consum sta undeva la 11%. Este vorba de e46 320d 110kw 2004- Interpretare erori BMW
Buna ziua, daca ma poate ajuta si pe mine cu interpretarea urmatoarelor erori atasate. Problema e ca motorul are momente cand nu trage mai ales la schimbare brusca de mers in depasire dupa care isi revine, acul de la consum sta undeva la 11%. Este vorba de e46 320d 110kw 2004 - Interpretare erori INPA
