Myx
    143
Everything posted by Myx
  1. Mai ai 2 luni de distractie cu ele , f frumoase
  2. Myx
    F10 525d
    [qdecat style 237 mai bine ale tale , arata f rau in mers , par model vechi aduc cumva a E39 . Ai destule optiuni 18 inch la F10 , mai ales gama M , merita sa faci un efort .
  3. curge vasul in sarcina ...asa era si la mine la E46 , nu vedeam nimic la ralanti , dar in sarcina tasnea grav .
  4. Atat timp cat ai civ si contract vc esti acoperit ca proprietate . Mai ales ca ai si varianta sa o iei la fiscal tu imi par zero riscuri pt tine . Ca in timp cei de la Inmatriculari pot inventa vreo regula nebuna si nu mai poti curcula e altceva )
  5. Nimic deosebit , sa le stapanesti sanatos
  6. Myx
    Chip tuning BMW
    pai ce credeai ca vor spune ...totusi e normal sa ai trepidatii ?
  7. poate e o chestie de preferinte , ai incercat diverse setari si zici ca se aude mai prost ca Logic ? La ce te referi mai exact . Si eu am testat multe variante pana am ajuns la varianta actuala in E60 . Incearca si setarile astea I spent considerable time playing with the graphic settings trying to get the best from the F10's Professional audio system (think it's called 'Premium' in the US). The settings below give the best overall sound (to my ears at least). Fader +2 towards rear Treble +4 Bass 0 Surround off!!! 100Hz -2 200Hz -1 500Hz 0 1KHz +2 2KHz -3 5KHz +4 10KHz +6 The surround just seems to add copious amounts of reverb and wrecks the sound IMO. I initially set everything up using my ears, then used some sine wave test files with a large diaphram mic who's responce I'm familiar with and an oscilloscope (yes - I'm into audio!). Assuming my calculations were correct, the results were suprisingly flat. My preferred settings have a slight boost around 3Khz, but I like it that way. Makes you wonder why they can't equalise the default settings better.
  8. frumoasa culoarea , sigur va primi si jante nebune )
  9. si cu pozele astea vrei sa vinzi masina
  10. Spira si buton aprox 1000 ron
  11. Cumpar set tetiere fata pt E60 LCi , piele neagra , pot da la schimb tetierele de nfl ca sa nu descompletati scaunele . Poate are cineva de vanzare .
  12. Bun la masina acolo , te scoate la nevoie si e lung firul .
  13. cel mai probabil ai aer in instalatie , ar trebui sa mergi direct la un schimb de lichid de frana si sa nu mai amani . Am patit si eu la un schimb placute sa nu am frana cum trebuie dupa , am schimbat lichidul de frana si s-au aerisit franele complet . Desigur pot fi si alte cauze ,cand ajungi in service afli mai multe .
  14. Ne arati si noua mesajul de la fabrica zf , pt ca eu am alt raspuns cu schimb ulei la 100k . Tot de la ZF .
  15. cam asta e lumina , ca am mai primit solicitari . Destul de bine dpmdv , fata de stoc e dif enorma ) http://i936.photobucket.com/albums/ad206/tnt221/IMG_7682_zpszy66tnlt.jpg http://i936.photobucket.com/albums/ad206/tnt221/IMG_7683_zpsuinanbvz.jpg
  16. Ia ce am pus si eu , pt mine e suficient ca vizibilitate
  17. preturi exagerate pe forum ))) . Mai exact ce fel de preturi ar trebui sa fie pe forum ? Masini mai bune ca pe autovit dar mai ieftine sau la acelasi pret ?
  18. Cine e din buc veniti si facem o proba, in poze in link vad un e90
  19. Eu iti spun ca vad lumina in spatele masinii cand ma uit in oglinda , raza larga in lateral , nu vedeam absolut nimic inainte . Cred ca becurile stock sunt puse efectiv sa semnalizeze reverse pt ceilalti , nicidecum sa vezi ceva . Dpmdv lumina se masoara in lumeni . Cred ca scrie in link ala cat au . Si daca imi amintesc bine tu ai facut 2 becuri cu aproape 400 ron . Astea costa 10 usd si sunt multe peste orice e in tara aici gata facut .
  20. ))))) prea multa lumina . Arata beton noaptea si chiar nu scot ochii celorlalti .
  21. )) sta bine acolo . Nici nu-ti vine sa o scoti in praful asta ,oricum cu tot ce i-a dat se spala fff usor
  22. Am comandat niste leduri pt marsarier http://www.aliexpress.com/item/2x-T15-W16W-LED-CANBUS-Samsung-3535-Chip-High-Power-Backup-Reverse-Light-for-BMW-E39/32335692095.html 3 sapt au facut pana aici , arata bine , lumineaza f puternic in sfarsit vad si eu ceva in spate seara , ma refer la lumina . Cateva poze ca sa vedeti dif . Prima poza se vede f clar , in stanga e ledul . Nu dau erori . pe aici am gasit numai porcarii si scumpe . 10$ e pretul per set . http://i936.photobucket.com/albums/ad206/tnt221/IMG_76171_zpserxgijba.jpg http://i936.photobucket.com/albums/ad206/tnt221/IMG_7618_zpscdhi3chs.jpg http://i936.photobucket.com/albums/ad206/tnt221/IMG_7619_zpsm2ajot8z.jpg http://i936.photobucket.com/albums/ad206/tnt221/IMG_7615_zpsabflbubx.jpg
  23. Baronu 25 parca e user , sunt pe tel acum il gasesti
  24. E pe forum de vanzare fix ce-ti trebuie , cel de la continental . Il poti tine in masina fara deranj . Am Si eu am si l-am folosit de cateva ori , f util . Recent a cedat o valva si m-a lasat pe janta . Am umflat rapid si am Ajuns la vulcanizare, cam 3 min o janta pe pana deci destul de rapid dpmdv .
