Seria 5 E60, 2003-2009
Salut!
Apare mesajul flat tyre monitor failure status error
e60 din 2008
stie cineva ce este stricat sau cum se reseteaza?
  • Replies 3k
  • Views 731.7k
  • ia-ti logan.
  • Am mai spus-o de nenumarate ori incat imi este lehamite sa mai repet.PUNCT.   E60 nu e o masina proasta ci extrem de proasta care din pacate doar la intretinere e premium😂 in rest nimic iesit din com
  • Se poate cumpara unul nou, in primu rand. Asta e durata lor de viata . E consumabil. Asa cum filtrele de polen, aer, ulei etc le pui noi, asa si cu asta. Costa cam 2000euro. Dar e masina premium, ne
Da.
Manuel, intri in meniu si resetezi presiunea cu motorul pornit si masina oprita.
Exista manual.
Edited by C_o_s_m_i_n
Arata-ne ce masini ai gasit si te tenteaza . Pretul corect e dat de mai multe aspecte decat o anume dotare .
http://olx.ro/i2/oferta/bmw-535d-e60-ID4kqAv.html?ref%5B0%5D%5Bparams%5D%5Baction%5D=answers&ref%5B0%5D%5Bparams%5D%5Btype%5D=unreaded&ref%5B0%5D%5Bparams%5D%5Bmy_chat%5D=1&ref%5B0%5D%5Bparams%5D%5Butm_source%5D=serviceletterMessage&ref%5B0%5D%5Bparams%5D%5Butm_medium%5D=email&ref%5B0%5D%5Bparams%5D%5Butm_campaign%5D=link&ref%5B0%5D%5Baction%5D=myaccount&ref%5B0%5D%5Bmethod%5D=answers&ref%5B1%5D%5Bpath%5D%5B0%5D=434791880&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Baction%5D=answers&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Btype%5D=unreaded&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Bmy_chat%5D=1&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Butm_source%5D=serviceletterMessage&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Butm_medium%5D=email&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bparams%5D%5Butm_campaign%5D=link&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Baction%5D=myaccount&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bmethod%5D=answers&ref%5B1%5D%5Bajax%5D=1&ref%5B1%5D%5Baction%5D=myaccount&ref%5B1%5D%5Bmethod%5D=answer
http://olx.ro/i2/oferta/bmw-530-diesel-full-option-ID3LqxE.html?ref%5B0%5D%5Bpath%5D%5B0%5D=sent&ref%5B0%5D%5Bajax%5D=1&ref%5B0%5D%5Baction%5D=myaccount&ref%5B0%5D%5Bmethod%5D=answers&ref%5B1%5D%5Bpath%5D%5B0%5D=436375116&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bpath%5D%5B0%5D=sent&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bajax%5D=1&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Baction%5D=myaccount&ref%5B1%5D%5Bparams%5D%5Bref%5D%5B0%5D%5Bmethod%5D=answers&ref%5B1%5D%5Bajax%5D=1&ref%5B1%5D%5Baction%5D=myaccount&ref%5B1%5D%5Bmethod%5D=answer
Tare, al doilea nici nu s-a mai obosit sa minta cu privire la nr de km :))
Dupa cum arata pielea la 535d, are nr de km dublu.
Edited by lowlife
Cred ca nu e mereu sa relevant numarul de km ci cum a fost intretinuta, au mai discutat colegii pe aici si sunt si eu sustinator acestui punct de vedere. Credeti ca e o idee mai buna sa ma uit spre germania? Cred ca reusesc sa gasesc 1—2 prieteni s imi intinda o mana. (Desi am vazut aceleasi variatii de pret si la ei, gasit unul la 20k)
Salut, am vandut e39-le si mi au ramas jante originale pe 16 de la el cu anvelope noi de iarna, se potrivesc la e60 530d 2004????
E39 are 74,1 butucul
E60 are 72,6 butucul
1.In primul rand ai nevoie de inele de centrare.
2.Et-ul este apropiat, trebuie vazut doar daca nu cumva profilul interior al jantei o sa atinga in etriere.
Un service de roti bun in Bucuresti imi puteti recomanda (in afara de Autosoft)? Vreau sa verific jantele si cauciucurile unui E60, care se cam balangane/trepideaza in mers dupa o anumita viteza. Au fost schimbate discurile, placutele, bielete, etc, problema persista, doar rotile au mai ramas de verificat.
Multumesc.
Incearca autozone aviatiei, daca sunt strambe au si masina de indreptat.
Sau PTC este chiar langa MOL de pe barbu vacarescu.
Multumesc, e la fix zona. Nu-mi dau seama insa de ce ar fi langa Mol, ca la ala mic de langa Petrom parca e o spalatorie si langa fostul Agip doar cladirea Scop.
Cred ca ramane pentru aviatiei, ca pare mai ca lumea. Indreapta si jante de aliaj?
Bdul Barbu Vacarescu 74-76
BUCURESTI, Sector 2
(intre benzinariile Mol si Petrom)
GPS: lat=44.45962 lon=26.106
Exact aici :)))
Pit car scrie pe cladire, parca.
Edited by enders
Salut!
Am si eu o intrebare :
As dori sa cumpar un e60 525d modelul NFL cel cu 177 CP sau un X3 2.0d (cel de 150 CP).
Care e mai scump la intretinere?
Astept parerile voastre. Multumesc.
Salut!
Dpdv al consumabilelor, X3-ul este mai scump. Deci, da, X3-ul este mai scump la intretinere. (presupunand ca ambele sunt in aceasi stare tehnica)
Are cineva idee ce cod are telecomanda/cheia? Ma chinui de aproape o ora pe realoem si n-o gasesc pe nicaieri. S-a dus bateria si vad ca e modelul fara capacel..
http://i21.servimg.com/u/f21/19/29/52/90/imag2111.jpg
Multumesc.
As dorii sa achizitionez un 525D 177 cp din 2005-2006. Majoritatea au cutiile automate...ar trebui sa.mi fac griji? La ce ar trebui sa fiu atent cand cumpar masina si la ce prb uzuale sa ma astept. Multumesc.
Inainte de toate eu zic sa mergi cu ea la Bavaria pe tester,acolo vezi cam toate partile rele. Daca refuza,sa fie sanatos cu masina lui. Ai grija la samsari,eu am cautat un E60 bun si am dat numai de samsari si masini terminate cu ceva sute de mii de km in minus fata de cat trebuia sa arate in bord. Il intreb pe om daca a fost lovita si el imi spune nu si culmea ca,capota si bara fata aveau alta nuanta de gri care se vedea clar de la distanta. Volanul la fel era foarte dubios ceva la el,masina parca nu urca in ture liniar si asa mai departe. Dupa cum am zis ,mergi cu ea pe tester la bavaria,cel mai bine. Eu am preferat sa ard 2 mii de Euro in plus si sa o iau de la nemti si imi pare bine ca nu am cumparat din RO. La 525D,nu prea stiu ce sa zic..As mai strange putin si as merge pe un 520d care e 2.0,mult mai economic,taxe mai mici si tot puterea aia.
Edited by Cloud92
pagina nu a fost gasita...
Senzorul pentru alarma/inchidere centralizata unde se afla? Nu mai merge telecomanda decat de la 1m. Am schimbat bateria si face la fel. Sa nu fie senzorul obturat,sau altceva.
Multumesc.
si eu am aceeasi problema, insa m-am gandit ca bateria "noua" nu era chiar noua. Am vazut ca se vand acumulatori pentru aceasta cheie. Eu am cheia briceag, banuiesc ca si tu ai la fel.
Modelul E60 a fost fabricat si in varianta Euro 5 spre sfarsitul vietii in 2009/2010 cumva ?
Multumesc
Multumesc.
Se afla pe luneta ,pe mijloc,in dreptul stopului de frana.
Edited by kolea
