Ce benzina folositi?
Ce benzina folositi? 1407 members have voted
  1. 1. Ce benzina folositi?
    • OMV
      29%
      328
    • Petrom
      29%
      329
    • Rompetrol
      13%
      151
    • Lukoil
      5%
      66
    • Mol
      17%
      200
    • Shell
      0%
      11
    • Agip
      1%
      18
    • Altele
      1%
      14
Please sign in or register to vote in this poll.
Arde mai repede? WHAT DOES A HIGH OCTANE VALUE MEAN, TO ME?
A high octane rating ensures that it takes a REALLY hot ignition source to ignite the fuel
Asta este o chestie foarte interesanta, chiar daca nu are legatura cu cifra octanica. :blink:
  • Replies 1k
  • Views 212.9k
  • Imi pare rau sa iti spun, dar orice motor bun "mananca" putin ulei. Daca is face ungerea bine. Asa ca daca vrei sa te lauzi in continuare, nu mai spune ca motorul tau are "consum 0 de ulei"
  • Stii ca topicul se numeste "Ce benzina folositi", nu ?
  • Ceea ce nu stie lumea este practica petrolistilor de a face schimb de produse, astfel incat sa reduca costurile cu transferul benzinei/motorinei de la rafinarie la benzinarie. De exemplu, Petrom-ul sc
Nu vorbim despre benzina mai slaba calitativ, vorbim despre benzine cu cifre octanice diferite.
Benzina de 99 de ex. se va consuma mai repede decat cea de 95 prin simplu fapt ca arde mai repede.
A high octane rating ensures that it takes a REALLY hot ignition source to ignite the fuel (such as a spark plug or the flame-front itself) and not just the rise in pressure & temperature that's a result of normal combustion. Note that the thermal rises in the cylinder are in direct proportion to the compression ratio of the engine (more below). The higher the compression ratio, the higher the octane of the fuel that's needed.
Again, if the mixture in a gasoline engine ignites before the spark plug fires, we call that "pre-ignition." Pre-ignition can damage an engine before you finish reading this sentence. To reiterate, what we're really concerned with is called "knock" and that's the spontaneous ignition of the fuel-air mixure ahead of the flame-front as a result of the rise in cylinder pressure caused by the onset of ignition (caused by the firing of the spark plug).
de?
Putere calorica mai mare. Deci trebuie o cantitate mai mica de benzina ca pistonul sa faca aceias cursa in aceias sarcina. Un amestec mai mic de carburant in camera de ardere pentru acelasi lucru mecanic
Dupa cate stiu eu benzina are cam aceeasi energie calorica (fie ca e de 95 sau 98) adica aproximativ 45Mj/kg. Cifra octanica in schimb, arata cat de stabila este la detonatie, in functie de turatie si presiunea din cilidrii.
O benzina cu CO de 98 controleaza mult mai bine detonatiile si motorul merge mai bine la turatii inalte si opresiuni mai mari in camera de ardere. De aceea sunt folositi combustibili cu fira octanica peste 100 pt motoarele de inalta performanta.
Benzina cu CO mare permite motoarelor sa functioneze la compresii mai mari prin prevenirea detonatiilor, ducand astfel la o putere marita.
Edited by tiberiuenache
da acelash lucru cred si eu , daca bagi 100 carrera de la omv se duce foarte repede si daca bagi 95-ul parca tine mai mulkt acu nu stiu poate doar mi se pare mie:))
Deci putere marita duce la km in plus cu aceias cantitate de combustibil. Acum intrebarea mea este daca exista o benzinarie anume recomandata de cei de la Bavaria. Si aici ma gindesc si la aditivii pe care ii contine mai benefici pentru motoarele de BMW.
o mai incerc si eu 99 de la petrom sa vad care sunt diferentele. Am folosit pe Audi A4 si nu mi-a placut deloc, mergea mult mai bine cu 98 de la Luk, asa ca am ramas la 98 si pe BMW
pai este normal sa se duca mai repede , pentru ca are arderea mai mare ...
carrera bag si eu de vre-o 2 saptamani si nu am simtit nicio diferenta (doar la buzunar)
Nu-mi vine sa cred in ce eroare sunt unii p'aici... Cum sa arda mai repede benzina cu cifra octanica mai mare? Pe romaneste cifra octanica se refera la randament (cum a mai spus cineva aici).
"Octane rating has no direct impact on the deflagration (burn) of the air/fuel mixture in the combustion chamber. Other properties of gasoline and engine design account for the manner at which deflagration takes place. In other words, the flame speed of a normally ignited mixture is not directly connected to octane rating. Deflagration is the type of combustion that constitutes the normal burn. Detonation is a different type of combustion and this is to be avoided in spark ignited gasoline engines. Octane rating is a measure of detonation resistance, not deflagration characteristics."
sursa www.wikipedia.org
Edit: cu o benzina cu cifra octanica mai mare in general se obtine un consum mai redus (la aceeasi maniera de condus).Daca vi se pare ca
"se duce" mai repede benzina OMV Carrera 100 este ori pt ca atunci cand alimentati cu asa ceva conduceti mai sportiv ori pentru ca este mult mai scumpa si una e sa bagi de 1 mil carrera 100(pret 4.4RON/l)-vreo 22l alta e sa bagi benzina normal (sub 4 RON/l parca)- peste 25l.
Eu nu prea mai bag Carrera 100 cand merg prin oras pt ca am constat ca daca bag TopPremium 99 merg cel putin inca o zi cu masina la o alimentare de 100RON.
Edited by ryso
Subscriu, asta uitasem sa zic, cu 95 masina consuma MAI MULT decat cu 98
Nu sustin ca Petrom 99+ este cea mai buna. Fiecare alimenteaza cum crede ca e mai bine. Depinde si de masina. Unele nu se impaca cu 99+ nu dau randament. Eu zic depinde de la masina la masina.
vad ca se discuta de carrera 100,petrom 99+ vin si eu cu o intrebare idioata...
la un motor pe carburatie ,ce benzina merge mai bine?sa pun carera 100,dar aia e pt motoare fara pb pe injectie...astept pareri...
Probabil EcoPremium de la Petrom.
Este clar ca o benzina cu cifra octanica mai mare este mai buna.
Plus ca 99+ si Carrera 100 au mult mai putin sulf decat celalalte tipuri de benzina cu cifra octanica mai mica.
Cel putin teoretic..
TopPremium 99 + pun de la petrom. Am pus si carrera 100 si se duce mai repede rezervorul si nu pare ca ar fi mai nervoasa masina. Se comporta la fel cu cele 2 tipuri de benzina, numai ca e mare diferenta de pret la litru
Exact, la mine Audi se impaca mai bine cu 98 decat cu 99+, la BMW s-ar putea sa fie alta poveste, si mecanicul meu care are aceiasi masina mi-a zis ca merge mai bine cu 99+
OMV 100 si Petrom +99 e "aceeasi Marie cu alta palarie" luate tot de la Rafinariile Petrom si nu cred ca difera mai deloc de cea de 98.
Oricum am da-o tot porcarii cumparam!
Carrera 100 e facuta in Austria.
Nu cred.
Mie mi-a zis un angajat de la OMV ca este produsa in Romania.
Ar fi destul de neprofitabil sa aduca benzina din Austria pana in Romania.
Plus ca @tiberiuenache este inginer petrolist. :twoup:
Cred ca stie ce zice :twoup:
Edited by Ciupanezu
Viitorul socru e la OMV si mi-a spus ca toata benzina e made in Romania.
Personal alimentez cu MOL -95, imi consuma cu 1,2 litri mai putin in oras fata de Carera aia prea scumpa pentru calitatea ei, foarte buna benzina. Ideal ar fi sa deschida ARAL benzinarii si pe la noi, Doamne cum mai merge motorul cu benzina aia ... din pacate ultima statie de alimentare ARAL e la Nadlac :twoup:
:twoup: am vazut cum imi merge masina cu benzina de 95...ca o besina, parca e infundata. Nimic nu se compara c 99+ sau carrera 100.
Ba da. :twoup:
Benzina din Germania, de 100 de ori mai buna.
Da si cum o aduc ? :twoup: Nu cred ca ma lasa cu canistre in portbagaj :twoup:
Stai linistit!
In 15-20 de ani o sa avem si noi. :twoup:
Edited by Ciupanezu
Inseamna k acum n-o mai importa.. Dar in cazul asta pretul de 4.5-4.6ron/l nu se poate justifica
