- Today
Nu stiu cat te ajuta dar uite ce am gasit cu Google dupa ce am scris fix ce ai pus tu cu bold si cu BMW in fata si dupa am raspuns ca e vorba de N47 ca motor. For the BMW N47 diesel engine, fault code 297800 points directly to the electric Variable Nozzle Turbine (VNT) actuator mounted on your turbocharger. Unlike gasoline BMWs that use simple wastegates, the N47 relies on this electronic actuator to constantly manipulate internal turbo vanes to control boost. [1, 2] Specific N47 Failure Points Stuck VNT Vanes (Very Common): Diesel soot and carbon build up inside the exhaust side of the turbocharger. This causes the internal vanes to jam or bind. When the actuator tries to force them to move, its electric motor draws too much current and overheats, triggering the "excess temperature" or mechanical fault. [1, 2, 3] Actuator Internal Gear Strip: The actuator houses delicate plastic gears driven by a small electric motor. Over time, or due to fighting stiff vanes, these gears strip out, resulting in an electrical/mechanical discrepancy error. [1] Exhaust Heat Damage: Because the N47 actuator sits directly next to the hot exhaust manifold, thermal cycling can compromise the actuator’s internal circuit board or warp its connector pins. [1, 2] Step-by-Step N47 Diagnosis Perform the "Free Movement" Test Locate the electronic actuator on the side of the turbocharger. Carefully remove the small retaining spring clip holding the actuator linkage arm to the turbo lever (Be careful, it is prone to flying off and getting lost). Manually move the metal lever on the turbocharger by hand. The Verdict: It must feel completely loose, moving effortlessly from stop to stop with zero tight spots or sticking. If it binds or catches, your VNT vanes are carbon-fouled and the turbo requires cleaning or replacement. [1, 2, 3] Inspect the Wiring Harness Disconnect the multi-pin plug from the actuator. Inspect the harness for oil contamination, brittle plastic, or backed-out pins. [1] Run an Actuator Test via Software Hook up a diagnostic scan tool like ISTA or Bimmerlink. Run the component activation test for the charging pressure actuator. Watch the arm to see if it makes a smooth, full sweep or if it chatters, hesitates, or fails to complete its range. [1, 2, 3, 4] Repair Paths If the turbo lever moves perfectly but the actuator stalls or fails the software sweep, the electronic actuator is dead. You can send it to specialty rebuilders like ECU Testing to repair the internal electronics/gears. Note that blindly swapping it with a random used actuator can cause issues because they are factory-calibrated to the individual turbo. [, 2, 3, 4] If the lever binds or is physically locked up, the turbocharger itself needs to be removed and disassembled to clean the carbon out of the VNT mechanism, or replaced entirely. [1, 2]
- Yesterday
mgi replied to FiveThreeFive's topic in Opinii si editoriale
Nu vor urma, sunt deja acolo. Telefoanele cu cele mai bune camere sunt chinezești în momentul asta. Televizoare de top au (tcl), iar tcl a cumpărat divizia de TV de la Sony . Chinezii tocmai au făcut propria tehnologie DUV. O sa ajungă sa facă și tehnologii mai avansate dacă lucrează la asta. Vad ca n-a zis nimeni nimic de Ai, unde chinezii sunt pe val. Și nu doar ca sunt pe val, au o strategie de țară de dezvoltare. Ceea ce nu mai are nimeni altcineva în momentul asta- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
RedCap replied to FiveThreeFive's topic in Opinii si editoriale
@Viper05 ai inceput sa citesti numai propaganda chinezeasca mai nou? Ori esti speriat rau de orezari ori ai devenit fan PRC mai nou. Intrec pe ma-sa. Ai vazut tu pana acum vreun mare si tare avion chinezesc in vreun asa numit "dog fight" cu vreunul American? Au doar o armata de parada, fix cum au avut si rusii care a 2-a armata a lumii trebuiau sa ia Ucraina in 3 zile si sunt mai bine de 4 ani de atunci si mai nou tot bubuie regiuni si orase din Rusia. Astia sunt la fel ca rusii de o ard numai in parade dar macar sunt mai destepti ca ei si nu arata si teste cu tehnica lor de ultima generatie care fix cand e marele si iubitul lider acolo esueaza. Macar au invatat din prostia rusilor si nu fac si asta. Pai daca Boeing-ul e atat de prost si vai de mama lui de companiile chinezesti tot cumpara asa ceva pentru flotele lor? Daca sunt ei aia mari si tari ar trebui sa aibe propriile lor avioane, nu? Gresit, dupa ce au furat/copiat din stanga si din dreapta tehnologie sau au primit-o pe degeaba ca tanatalaii astia de Americani si Europeni sa aibe acces pe piata lor, s-au trezit si ei sa faca gura mare. Nu mor caii cand vor cainii, Europa da semne ca pare ca incepe sa trezeasca din prostia birocratica si autosuficienta in care s-a lafait atata amar de vreme. Fix, uite acum ma duc si imi caut cursuri de limba chineza ca va fi limba nr 1 in lume.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
- Last week
Alex3245 replied to FiveThreeFive's topic in Opinii si editoriale
Inovația Chinei are limite structurale, E adevărat că China a trecut de la copiat la inovație (mai ales pe mașini electrice și baterii).Totuși, în sectoarele cele mai critice; cum ar fi microprocesoarele avansate și utilajele de litografie, unde ASML din UE deține un monopol, China este încă la ani distanță. Fara tehnologia europeană și americană, producția lor tech de vârf se duce. Producția masivă nu înseamnă dominanță totală, China produce ieftin și mult, dar se confruntă cu o criză demografică și o criză imobiliară. O economie bazată doar pe exporturi depinde direct de pietele bogate care îi cumpără produsele adică exact SUA și Europa. Europa nu este neputincioasă, ci reglementează, Europa nu concurează pe producție ieftină de masă, ci pe înaltă tehnologie, servicii, produse de lux, farmaceutice și standarde. UE este cel mai mare bloc comercial din lume: dacă Europa pune taxe vamale pe mașinile chinezești, China pierde piața sa cea mai profitabilă. Războiul hibrid și politica: Amestecul Rusiei și Chinei în politica europeană prin dezinformare este o amenințare reală. De asta și avem impresia asta falsă ca Europa e praf când nu e așa. Asa este împinsă și narativă ca Europa e în spatele Americii cu mult și lala-uri de genul pentru a dezbina Europa, pentru eu și SUA Pe când Europa este înaintea Americii pe PPP care reflectă mai bine economia, unde China are ~44T dolari, Europa 35T, SUA 32 T. Plus ca Europa este cel mai mare exportator de servicii de înaltă valoare adăugata Toate narativele de genul Europe is dead si astea sunt făcute pentru a încerca să-i reducă puterile Europei și să o dezbine. Plus un video care explică asta mai bine:- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Tipul are service auto, de ingrijit eu sunt destul de încrezător ca a ingrijit o cat de cat corect. Are pneuri de vara noi cumparate anul asta si pneurile de iarna anul trecut. I a schimbat uleiul la grup la 60k, iar reviziile la motor la 10k. Motivul vanzarii este ca sotia lucrează mai nou de acasa si vrea ceva electric pt drumuri scurte in oras, ca si a pus panouri fotovoltaice. Oricum, desi mi place masina, cred ca o sa zic pass deocamdata. Mai trag de e90 ul meu un an, ca si asa merge ok deocamdata si vad dupa ce mai apare.
Viper05 replied to FiveThreeFive's topic in Opinii si editoriale
chinezi nu mai copiaza demult. au copiat au invatat ,. prima data au inceput cu tehnica militara, vezi avioanele de vanatoare copiate de la rusi, vezi j11 j15. j16 au invatat si acum produc avioane de lupta de clasa mondiala, intrecandui pe americani. chiar am citit pe un blog militar cum chinezii radeau la ceva air show chinezesc de su-57 lor cat de prost e facut chinezi avanseaza , americani se duc in jos, vezi de exemplu boeing cu 737 max, 777 asta nou, noul boeing de realimentat si lista continua. in plus au votat in cretin care a stricat in cativa ani tot ce a construit america de la al doilea razboi mondial incoace acuma china dupa ce a proritat tehnica militara, face si alte chestii ex masini, mai bune si mai ieftine decat toti , vor urma telefoane de top, televizoare etc europa e in curul gol , lovita din toate partile, americanii , chinezi si rusii baga bani in extremisti, europa ii voteaza neatiiind ca isi voteaza sfarsitul lumea se schima si china e in fata, new world order,- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
BaXXon replied to FiveThreeFive's topic in Opinii si editoriale
Nici o sansa! Dimpotriva , vor scumpi pt ca " are balta peste "....- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Acu tre vazut daca are schimbate recent una alta, discurile de frana, ulei, anvelope etc.. ca sa dai 18 mii si sa mai bagi 2mii, chiar de are doar 100k km, nu stiu ce sa zic,,,
fedliv started following Manual scheme electrice BMW Seria 1
fedliv replied to TheElfs's topic in Audio/Video/Navigatie/Electronica auto
O rugaminte: ai cumva schema electrica pentru E87 118i (link-ul postat nu mai functioneaza, l-au blocat...)? Multumesc ! -
alex230ro replied to FiveThreeFive's topic in Opinii si editoriale
Daca tin eu bine minte din ce am învățat, cand cererea depășește oferta prețul crește pana cele 2 se "egalizeaza".- 4211 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
Buni si orezarii la ceva. Ii sparg acum pe producatorii europeni cu, concurenta. Atatia ani au jupuit consumatorii cu preturi dand in acelasi timp tehnologia chinezilor gratis ca sa poata sta pe piata chineza. Acum ori se trezesc la viata si ofera ce trebuie pentru banii ce ii cer, ori ies din business.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Oricum masinile chinezesti sunt prea scumpe dupa parerea mea, si nu din cauza de taxe. Atat considera ei ca vrea sa plateasca europeanu'. Eu, sincer sa fiu, sper sa se ieftineasca pe masura ce vand mai multe.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
As zice ca ușor se trezește si industria europeana ma rog Stelantis si Ford par sa încerce sa aducă prețurile mai jos.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Si uite asa vor lua o palma ( binemeritata ) dupa ceafa , toti producatorii de autoturisme , europeni si in final ori vor scadea preturile nesimtite ori vor da faliment. Vw deja e pe punctul de a inchide cateva fabrici din Germania, ne bucuram maxim de concurenta ( not ). Cand autoturismele chinezesti vor invada piata si nu vor mai avea rivali in eu , vor mari preturile si ei pt ca cererea va fi mai mare ca oferta... nu vin vremuri bune clar.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
E greu la banii ăstia,chiar dacă mașina are an bun și km puțini,marea majoritate caută la banii ăstia următoarea generație,chiar dacă au km mult mai mulți.Piața la noi e defectă .
Am intrebat scurt ai-ul, ia uite ce sumar frumos: Active and Near-Opening Factories in Europe BYD: Constructing a major passenger EV manufacturing hub in Szeged, Hungary, with initial production targeted to begin. The company also paused its planned $1 billion factory in Manisa, Turkey, to prioritize its EU-based footprint. Chery: Partnered with Spanish EV brand Ebro to utilize a former Nissan assembly plant in Barcelona, Spain. SAIC (MG): Planning its first dedicated European manufacturing plant based in Galicia, Spain. Xpeng: Utilizes contract manufacturing via Magna Steyr in Graz, Austria. SWM (Brilliance Auto Group): Working on a production facility through a joint venture in Turkey's Eskisehir province. Proposed Ventures and Factory Takeover Talks Geely: Expanding manufacturing footprints through agreements tied to existing European facilities, including looking at portions of Spanish plants. Hongqi (FAW Group): In active discussions with Stellantis to manufacture vehicles at underutilized European/Spanish factories. Leapmotor & Dongfeng: Evaluating various underused legacy European sites (including potential capacities in Italy and Spain) via joint ventures.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
sskkaa replied to FiveThreeFive's topic in Opinii si editoriale
Chinezii nu vor veni, ei sunt DEJA aici Mai discutam in 5-8 ani.- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
t3o_jew started following ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
t3o_jew replied to OPaul's topic in Audio/Video/Navigatie/Electronica auto
Salut, se poate un link te rog frumos? Ista/ncs expert daca ai. Multumesc -
Eugen B replied to FiveThreeFive's topic in Opinii si editoriale
Cand merg prin Asia in delegatie, fac in asa fel/am timp sa ma si plimb,si folosesc la greu Grab (ride sharing), apoi am umblat cu tot felul de masini care mai de care chinezesti, unele de buget cu rulaj semnificativ, dar si cu noile game high-end/luxury, eu cred ca noi europenii ar trebui sa lasam deoparte auto suficienta si sa acceptam ca si alte tari, inclusiv China (care in paranteza are tot ce ii trebuie: forta de munca, ingineri, resurse, roboti, tehnologie, energie ieftina, plus o mare dorinta de reusita, poate de multe ori discret potentata de statul lor) pot produce automobile ce se pot bate de la egal la egal cu traditionalii producatori europeni consacrati (care in paranteza, au huzurit ani de zile pentru ca nu aveau concurenta, si au coborat stacheta, si au avut de suferit din motive de geo -politica- vezi pretul la energie). In cativa ani,marii lor producatori(Geely, Cherry) vor avea o retea bine pusa la punct, uzine in Europa, si nu vor fi cu nimic mai prejos ca rivalii europeni.- 4211 replies
- 2
- electric
- electric cars
(and 2 more)
Tagged with:
Zeekr are deja 5 ani in piata si e detinuta de Geely, care are printre altele si Volvo si Polestar. Deci n-a aparut acum, doar n-ai auzit tu de ei. Jaecoo e o firma mai noua, dar parintele (Chery) face masini din '99. Deci, din nou, nu sunt veniti cu pluta..- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Da, asta e interesant , cate " brand-uri " vor supravietui dupa 2-4 ani si nu vor da faliment si garantiile vor disparea ....- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
DariusN replied to FiveThreeFive's topic in Opinii si editoriale
Zeeker, Jaecoo, am impresia ca in fiecare luna apar cate 2 branduri noi de masini electrice/hibride din China..- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Bun,am lăsat mașina, in concluzie pentru aprox 900 950 km am avut cost de 85 eur. Încărcare si la stații rapide si la statii"lente".- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Cautand pe mobile, nu prea gasesti similare la banii astia, deci pretul e CORECT dpmdv. Pe la 18k gasesti ceva masini, dar sunt cu +/- 150k km. Problema e ca deja de pe la 20/22k poti lua G20...
La 2000$ se astepta la Zeeker 8x probabil- 4211 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Topics
