Everything posted by zeronoo
Bmw e90 bluetooth
nu ai combox la anul ala de fabrica
Bmw e90 bluetooth
ce an e masina, cic de fabrica?
Bmw e90 bluetooth
ai nevoie de si de combox nu doar de cic pentru bt audio
Probleme DPF BMW e90
"RegenerationThere are two kinds of regeneration: Continuous regeneration: This form of regeneration takes place during normal driving. At exhaust-gas temperatures of between 280 and 350°C, continuous regeneration takes place in the form of a slow oxidation process. The soot particles cannot be incinerated until the exhaust gases reach the required temperature.Periodic regeneration: Periodic regeneration is performed automatically by the DDE after no later than 1000 km (600 miles). On vehicles with many short-distance drives, periodic regeneration already starts taking place after just 400 to 800 km (250 to 500 miles). For regeneration, the intake air is reduced by the throttle valve. One or two subsequent fuel injections are carried out. This increases the exhaust-gas temperature to about 600 °C. The soot is incinerated with the residual oxygen. The periodic regeneration is performed at all speeds. The most efficient method is regeneration at a constant speed in excess of 60 km/h (38 mph) over a period of 20-30 minutes. The DDE calculates the time for periodic regeneration from the following values: average distance travelledaverage driving speedtemperature in the diesel particle filterValues of the exhaust gas pressure sensorThe last successful regeneration can be read out by the diagnosis system. The following conditions must be fulfilled for a regeneration: The coolant temperatur must be in excess of 75 °CThe exhaust-gas temperature before the diesel particle filter must be greater than 240 °C.There must be enough fuel (fuel reserve indicator light does not light up). Whenever the fuel reserve indicator light lights up, the regeneration process is suspended.No fault codes from the air mass system, exhaust emission system and sensors must be saved in the DDEThe fault codes 480A or 245700 (from F01) and 481A or 245800 (from F01) must display the status "currently not present".Constant driving speed above about 60 km/h (approx. 38 mph). The optimum speed is about 100 km/h (approx. 60 mph)."
Presiune scazuta ulei la motor N20B20B
320 - 328 difera pistoanele si rata de compresie (cel putin)
LĂŁmuriri in legatura cu navigatia(cic)
nu, ai nevoie de un modul bluetooth compatibil cu e39, e46, e53 (IBUS)
Cablu aux usb pentru combox
https://www.bavauto.ro/84109237653 https://www.bavauto.ro/61119249400 ai nevoie de ambele
BMW X5 4.0d iDrive 2011
gresesti, presiunea pe admisie la relanti este egala cu cea atmosferica, daca scoti turbinele si pui o teava in locul lor motorul va functiona la fel (LA RELANTI!) p.s. mor de curios ce defect este, nu inteleg de ce nu face test...si de ce nu verifica filtrul de ulei DUPA ce a patit treaba cu defectiunea...de urmarit
doar daca obturau complet admisia altfel nu au cum, la relanti turbinele nu functioneaza in niciun fel
motorul nu se opreste la relanti de la turbine defecte
linia praf, scoate filtrul de ulei si cauta span
- activare asistenta faza lunga
Senzor unghi vloan E83
se poate coda la oricine are ncs functional, se initializeaza cu ista
BMW X3 F25 retrofit ceasuri 6WA
daca ai avut basic pe masina trebuie trasa si FO p.s. ce HU ai? trebuie sa ai HU cu FO
Speed limit info fara Kafas1/2
stiu...ma gandeam ca are kafas1 si a dat banii pe emulator...
tu ai kafas1 sau 2?
probleme motor N20B20
e defectiune tipica la motorul asta, motivul principal este patina sau mai bine zis materialul din care e facuta, modelul revizuit e ok, daca ai fi schimbat patina inainte sa se rupa era totul ok, e un motor fiabil mai putin problema cu patina... 1.in cele mai multe cazuri la 100k km patina e deja rupta 2. stiu de problema, exista model revizuit care nu se mai rupe (teoretic) 3. uzura cuzinetilor se face in timp, cand apare mesajul cu presiunea, motorul e deja compromis total 4. greu de spus...au fost revizuite mai multe acolo in afara de patina: lant, intinzator mecanic...
Ulei cutie de viteze manualĂŁ
la e46 5 viteze cutie manuala - da
Difuzoare Logic 7 de E60/E65 in F10
chiar daca impedanta va fi la fel la unele difuzoare de la diferite tipuri de sonorizare, se va auzi mai prost in cazul mix-ului amplif / alte dif, unul din motive fiind frecventa de taiere specifica care este diferita de la un sistem la altul
Problema navigate radio bmw e39
nu e legat firul de ibus intre navi / modul radio / monitor si masina
Febi® 83-22-2-339-219 - MTF-LT-2 SAE 75W-80 / 1.1 L
probleme garantie anvelope michelin si nesimtirea reprezentantilor
am inteles problema cu circumferinta, ceva nu e bine acolo clar...nu-mi dau seama ce si de ce..., pe de alta parte la bmw xdrive nu as alege sub nicio forma alte jante/cauciucuri decat cele specificate de ei pentru modelul respectiv, nu cred ca merita riscul P.S. pe etk la masina ta pentru iarna sunt doar 225/50R17 94H, nu am vazut 255
pentru vara da, pentru iarna pe masina asta se folosesc (DOAR) roti egale pe 17 cu cauciucuri 225/50/17 94H, restul e cancan...puteai verifica in etk, realoem in 5 minute
Transmisia cupleazĂŁ cu ambreiajul apasat
daca placa de presiune are fisuri exista posibilitatea sa nu decupleze complet sau sa aiba zone de contact cu discul de ambreiaj chiar daca pedala e apasata complet
17
