bmwdreamer
Everything posted by bmwdreamer
  1. Daca acel cablu va merge direct din hu in amplificator nu vad vre.o problema.explicatia data este cam ambigua.poate e vre.un coleg care s.a izbit de aceeasi situatie
  2. am aplificatorul original al masinii.nu am modificat sau adaugat ceva.daca acel cablu va ocoli amplificatorul,banuiesc ca nu se va mai auzui decat foarte prost
  3. Salut.intentionez sa achizitionez urmatoarea unitate http://m.ebay.co.uk/...648&_mwBanner=1 Dar vanzarorul zice ca mai trebuie un cablu adaptor de 6 m. thanks for your inquiry, sorry for this delayed reply due to the weekend. for this unit, it has the English user manual, which is built-in the unit inside, so you can find the instruction icon on the main menu. but sorry to tell you that our autoradios don't support Harmann Kardon System, you will need to buy the 6m extension cable to output the sound directly from your car speaker, the 6M extension radio cable will bypasses the built in amplifier, see if this is still ok for you? Sa inteleg ca se va face bypass la amplificatorul sistemului si se va auzi direct din unititatea android?am.vre.o sansa sa il conectez sa se se auda ok? A mai.montat vineva asa ceva?se aude bine comparativ cu hu original business al masinii?
  4. Salut.intentionez sa achizitionez urmatoarea unitate http://m.ebay.co.uk/itm/111378342763?_trksid=p2060353.m1438.l2648&_mwBanner=1 Dar vanzarorul zice ca mai trebuie un cablu adaptor de 6 m. thanks for your inquiry, sorry for this delayed reply due to the weekend. for this unit, it has the English user manual, which is built-in the unit inside, so you can find the instruction icon on the main menu. but sorry to tell you that our autoradios don't support Harmann Kardon System, you will need to buy the 6m extension cable to output the sound directly from your car speaker, the 6M extension radio cable will bypasses the built in amplifier, see if this is still ok for you? Sa inteleg ca se va face bypass la amplificatorul sistemului si se va auzi direct din unititatea android?am.vre.o sansa sa il conectez sa se se auda ok? A mai.montat vineva asa ceva?se aude bine comparativ cu hu original business al masinii?
  5. sunt deja la.2 automate e46 320d fl.la amandoua intampin aceleasi probleme.sunt curios de ce gasesti in neregula
  6. cumpar navigatie e46 android. erisin sau avin. pentru oferte aici sau la 0745 829 949
  7. salut.sunt interesat de masina.unde se poate vedea? adauga.ma pe whattsapp 0745829949.discutam.acolo,eventual cateva poze
  8. folosesc mereu versiunile postate de patruxalex in cazul in care cere versiunea mai noua.nu este rootat telefonul.
  9. pai daca regenerarea s.a facut,de ce mai persista acea eroare? printre altele,cum sunt valorile acestea?
  10. apreciez ajutorul dar il vreau cat se poste de complet si din cauza grilelor fata de la tweetere.
  11. salut.doresc sa cumpar sistemul audio complet pentru e90 hi.fi. boxe tewetere amp cabluri.daca se poate asigura si montaj cu atat mai bine.0745 829 949
  12. din cate stiu minim 75 grade.schimba.l si pe cel motor cat mai repede.
  13. de la.centura,la fel si la.mine
  14. eu l.am.inlocuit cu totul.nu ar fi trebuit dar asta e,puteam.incepe doar cu cel egr.deh...mecanicii astia.il am.pe cel motor original...daca te intereseaza
  15. asta cu 3000 ture e din popor...total eronat.2000 ture la 90km/h e sufucient pt o regenerare din carly
  16. poti incepe cu cel egr,la.mine a fist acela defect.la ash ce valoare arata?
  17. dupa ce isi va face regenerare ar trebui sa fie ok.
