Everything posted by GABIVVX1
ulei diferential e90
Rear axle oil specification ---Hypoid oils for axle gearboxes with laminar self-locking differential. And for axle gearboxes with electro-hydraulic locking differential. BMW Synthetic axle gearbox oil MSP/A 83 22 9 407 870 *** Castrol SAF - XJ Mobil gearbox oil VS 500 Aral gearbox oil BS-LSX BP Energear SHX-ZR Shell gearbox oil ZLS BMW Agip HLZ Fina Pontonic MLX ---Hypoid oils for axle gearboxes without laminar self-locking differential. BMW Synthetic axle gearbox oil SAF- XO / OSP 33 11 7 695 240 *** AGIP HLX Castrol SAF - X0 Mobil Gearlube VS 600 VALVOLINE HL Plus BP Energear SHX Shell gearbox oil OLS-BMW Esso gearbox oil NLS 75W-90 *with LSD (self-blocking differential) 83 22 9 407 870 Original oil *without LSD (self-blocking differential) 83 22 9 407 768 Original oil
Antigel
Luam la intamplare BMW 5 (E60); 525 d; kW 120 *Engine oil with filter 8,25 litres *Engine oil viscosity BMW Longlife 04 SAE 0W-30|SAE 0W-40|SAE 5W-30|SAE 5W-40 *Engine oil specification BMW Longlife-04 *Manual gearbox oil Gearbox GS6-53DZ 1,60 litres *Manual gearbox oil specification -up to 2007/02, Gearbox GS6-53DZ 83 22 0 309 031 Original oil -from 2007/03, Gearbox GS6-53DZ 83 22 7 533 818 Original oil *Automatic gearbox oil Gearbox GA6HP26Z, New filling 9,50 litres *Automatic gearbox oil specification Gearbox GA6HP26Z 83 22 0 142 516 Original oil *Rear axle oil specification 33 11 7 695 240 Original oil *Power steering oil 1,00 litres(4) *Power steering oil specification Cover marking ATF 81 22 9 400 272 Oil colour red Cover marking CHF 83 29 0 429 576 Oil colour green *Cooling fluid specification 83 19 2 211 191 Original anti-freeze agent *Brake fluid when changing 1,00 litres Brake fluid specification 83 13 0 443 026 Original brake fluid *Air-conditioning system refrigerant 690 - 710 Gram The definitive information is given on the type designation plate in the engine space. *Refrigerant specification R134a *Air-conditioning system oil 170 - 190 cm³ The definitive data is given on the type designation plate of the air-conditioning compressor. *Air-conditioning compressor oil specification 81 22 9 407 724 Original oil Compressor oil refilling quantity when replacing the high-pressure line 35 cm³ Compressor oil refilling quantity when replacing the low-pressure line 35 cm³ Compressor oil refilling quantity when replacing the compressor 50 cm³ Compressor oil refilling quantity when replacing the condenser Condenser with integrated dryer 55 cm³ Compressor oil refilling quantity when replacing the dryer Condenser with integrated dryer 55 cm³ Compressor oil refilling quantity when replacing the evaporator 35 cm³ (4)Data are guide values! Finally check filling level on the vehicle! Cooling fluid specification 83 19 2 211 191 este antigel albastru.
Cel mai dezagreabil model BMW
http://bringatrailer.com/2016/08/27/rare-four-door-cabrio-1993-bmw-318i-baur-in-the-us/ Pareri ?
Denumire Piesa [ Help ]
11617801206 pentru E60, 520d, M47N2 sau E83, 2.0d, M47N2 ,furtun partea dreapta intercoler-turbo. http://bmwcentrum.pl/uszczelka-przewodu-powietrza-doladowania-m47n-m47n2-bmw-e46-e60-e61-x3-e83-e87-e90-e91,id4773.html
Apa in filtru de aer ,check Engine aprins
Doar la DIESEL bielele fac soc mecanic si se stramba,la benzina nu am auzit. Totusi nici apa multa in motor nu este binevenita la banzinare.
Segment aripa spate E46
KLOKKERHOLM 0061581 lei 150 maxim KLOKKERHOLM 0061582 lei 150 maxim VAN WEZEL 0646147 VAN WEZEL 0646148 Varianta pt 4 usi. http://parts62.ru/products/KLOKKERHOLM/0061581.html Asa arata piesa,mergeti la un magazin care are contract cu ELIT si in 2 zile va soseste din Cehia.
Ziua si ACCIDENTUL GRAV
Deci e eveniment petrecut la noi in tara....asta e si mai trist.(mi-a trimis doar pozele si am crezut ca in bulgaria sa intamplat accidentul)
Motorina in ulei 525D
13537787236 13532247156 Verifica oringurile de la injectoare si saibele de foc. In primul rand vezi pompa de inalte 13518511826,posibil ea sa fie cauza principala si sa iti bage motorina in ulei.
Turbina fluiera pt ca nu mai are ungere adecvata,uleiul amestecat cu motorina ...a rezultat un fel de ulei lung si subtire ..un pisat. Nu mai merge cu masina ca faci motorul ala de balamuc.
Ambreaj LuK nu se mai vinde?
Da , asa este,nu prea mai gasesti codul respectiv de ambreaj si problema este ca nici sachs nu-l mai livreaza(pe codul asta in cutia de sachs gasesti setul de ambreaj luk cu stantele luk mascate si cu coduri sachs aplicate cu vopsea). Deci daca luk nu mai produce nici sachs nu o sa mai gasesti. Posibil toata treaba provine de o greseala a celor din grupul Schaeffler care din greseala au ,,uitat'' sa mai produca codul respectiv sau pur si simplu e o greseala undeva. Trimite un mail aici si cere un raspuns despre codurile:623 3001 00 si 600 0030 00 (setul cu volanta). http://webcat.schaeffler-aftermarket.com/web/schaeffler/ro_US/contact.xhtml
415 0282 10 volanta luk superdisponibila 623 3182 00 set ambreaj luk superdisponibil BMW 3 (E46) 318 d | Saloon Power; 85KW / 116HP Capacity 1.995ccm / 2,0l Engine Type / Fuel Type Diesel Cylinders / Valves; 4 / 4 Motorcodes M47 D20 (204D4)
Cabluri frana de mana e46
https://www.ecstuning.com/b-vaico-parts/parking-brake-cable-right/34411165020~vai/ https://www.ecstuning.com/b-febi-parts/parking-brake-cable-left/34411165021~feb/ Sunt cu catare,st mm 1693 si dr mm 1708 (lungime)
- Ghidaje etrier frana
BMW 2002 1968 - restaurare
furtunul care pleaca din alternator la 2,5 tds
Este doar un tub prin care alternatorul primeste aer sa nu se incalzeasca prea tare. Faptul ca ai ulei pe el sau in el....nu are legatura cu alternatorul,uleiul respectiv are alta provenienta si se scurge din alta parte.
http://www.ebay.com/itm/BMW-E39-525TDS-AIR-CHANNEL-12312246184-2246184-/261977836483 http://3139393.ru/catalog/bmw/5-series-e39/dvigatel/generator/0000270602/ Asa iti arata racordul si alternatorul ?
Piese schimb - originale sau nu
Cristii,tu ti-ai luat piese starline si spui ca iti montezi pe masina numai piese de calitate superioara ? http://www.consumerautomotiveresearch.com/Genuine-OEM-Aftermarket-Parts.htm Piesa OE https://www.ecstuning.com/b-genuine-bmw-parts/front-brake-pad-set/34116761244/ Piesa OEM https://www.ecstuning.com/b-textar-parts/front-brake-pad-set/34116761244~tex/ Confirmare comanda...
Nu exista nicaieri o asemenea diferenta pentru un produs identic. Diferenta poate sa constea in urmatorul lucru,saboti echipati sau saboti simpli. http://www.autosklepbydgoszcz.pl/katalog/a_a_16_304_9859/66/218565/___%28_-___KM%29/Uk%C5%82ad_hamulcowy_%28Hamulce_b%C4%99bnowe%29/Szcz%C4%99ka_hamulcowa_ok%C5%82adzina/BOSCH-0204114628_%28Szcz%C4%99ki_hamulcowe_kpl.%29.html http://www.autosklepbydgoszcz.pl/katalog/a_a_16_304_9859/66/267980/___%28_-___KM%29/Uk%C5%82ad_hamulcowy_%28Hamulce_b%C4%99bnowe%29/Szcz%C4%99ka_hamulcowa_ok%C5%82adzina/BOSCH-0986487327_%28Szcz%C4%99ki_hamulcowe_kpl.%29.html http://www.bmwclub.ro/forums/topic/89205-discuri-si-placute-de-frana/
Pentru ca exista 3 categorii de piese de schimb:OE,OEM,AM si fiecare produs are:calitatea lui,pretul lui,clientela lui. Exista clienti care au X6 si isi cumpara placute fata LPR si exista clienti care au E36 si isi cumpara placute fata Ate. Spre exemplu la saboti frana ai asa: Premium Ate,Trw,Jurid,Textar,Brembo,Hella Pagid,Bosch. Mediu Ferodo,Delphi,Sbs,Valeo. Ieftin Lpr,Starline,Abe,Breck,Trusting,Mintex. OE=piesa de schimb venita pe ralatia original,in ambalaj cu sigla producatorului autoturismului,si cu sigla producatorului autoturismului aplicata pe piesa. OEM=piesa care echimpeaza masinile pe relatia original,dar comercializate in ambalajul producatorului piesei. AM=restul de piese auto comercializate. Niciodata o piesa AM nu o sa aiba calitatea si pretul unei piese OEM sau OE.
@cristianro,Bosch dezvolta si produce sisteme de franare.Sunt masini care au din fabrica ca echipare de original tot sistemul de franare Bosch (Fiat,Renault). Sabotii sunt foarte buni si nu poti spune ca sunt produse proaste.Adevarat,placutele de frana nu pot fi comparate cu:Ate,Trw,Textar,Jurid,Brembo,Hella Pagid...dar fata de alte trompete sunt si ele destul de ok. Racoarde de frana,etrieri,saboti frana,pistonase de frana,cablu frana mana,toate produse de bosch,sunt produse care merita toata atentia.
Doar starline si lpr au ceva in comun,bosch face parte din alta categorie si foloseste alte materiale la fabricarea produselor. Ca sa vezi ca nu iti vorbesc din povesti...
Cate perechi de roti aveti?
Alu pentru vara si tabla pentru iarna ambele incaltate. 1 comod sa schimbi direct rotiile. 2 nu stau cu frica ca imi zgarie boul de la vulcanizare janta de alu. 3 cost redus la manopera la schimbarea rotilor. Singurul dezavantaj,e mai usor sa depozitezi 4 cauciucuri fata de 4 roti echipate.
Lichid de racire
G11 nu merge amestecat decat cu G11 pentru ca spre deosebire de G12/G12+/G12++/G13 contine silicati.
Ajutor in identificare cod piesa
GABIVVX1 replied to Razvan Gavan's topic in Probleme tehnice si rezolvari comune mai multor modele BMWCere seria de caroserie a masinii donatoare si posteaza seria aici sau la o reprezentanta.
