zeronoo
    39
Everything posted by zeronoo
  1. si sus-jos nu doar stanga-dreapta (face modulul ala)
  2. clapeta aia functioneaza doar la motor rece, in rest...vvt
  3. deconecteaza modulul de bluetooth(mufa alba sau cea cu fibra optica...oricare) pentru cateva zile si vezi, daca persista problema...nasol
  4. banuiesc ca nu ai xenon acum deci da, trebuie
  5. se schimba garniturile, nu se pune niciun silicon...nu mai dati sfaturi din ce cititi pe alte forumuri...
  6. la aplicatiile multimedia si telefon poate...
  7. nu, e pe ibus...gen e39, e46, etc, pt tine cea mai ieftina si serioasa solutie este MULF2 HIGH si ai bluetooth, player usb si aux...toate oem, ce navigatie ai / ce an e masina?
  8. harta pentru cic premium nu incape pe "un DVD"...daca nici macar atat nu stie...te las sa tragi singur concluziile
  9. zeronoo
    Valva PCV?
    injector, vezi ca pe motorul ala trebuie scrise injectoarele in dme, altfel merge ca dracu, exista test de injectoare in ista...e o procedura mai lunga care la final iti spune pe ce injector e problema
  10. nu e de schimbat nicio siguranta, se rezolva altfel
  11. Clutch Delay Valve The clutch delay valve is a small valve in the clutch line that restricts clutch fluid flow. It's designed to prevent shock to the transmission if the clutch is dropped. The bad part is that it makes the clutch feel vague and can make it difficult to pull off smooth shifts for experienced manual transmission drivers. Note that installation of a restricted CDV was not made on all manual cars. There are some that do not have one, some that do have one without restriction (same as the delete version) and then a lot of cars that have a restricted CDV. Seems that earlier E46 do not have it and it was phased in sometime in 2001 built dates. There are two choices: Remove the CDV completely (the two ends of the clutch line will screw into each other, requiring no parts) or replace the CDV with a drilled-out version, eliminating the restriction. People use the drilled-out version to avoid dealer hassles in case a transmission warranty issue arises. After replacing or removing the CDV, you do need to bleed the clutch line.
  12. CDV aka "clutch delay valve" sterge tot si scaneaza dupa cateva zile de mers din nou, vezi ce reapare
  13. cel mai probabil crankshaft sensor, asa cum spunea si manole, pe diagnoza nu o sa apara nimic legat de el (99%)
  14. mix de apa + aer comprimat pe returul radiatorului de incalzire
  15. radiatorul de interior infundat, poti sa incerci un backflush sau schimbi radiatorul, e o problema destul de intalnita la e90, cel mai probabil ca nu a schimbat nimeni antigelul odata la 4 ani...
  16. daca dai viteza ventilatorului pe maxim e fierbinte aerul sau aproape rece?
