zeronoo
Everything posted by zeronoo
  1. Clutch Delay Valve The clutch delay valve is a small valve in the clutch line that restricts clutch fluid flow. It's designed to prevent shock to the transmission if the clutch is dropped. The bad part is that it makes the clutch feel vague and can make it difficult to pull off smooth shifts for experienced manual transmission drivers. Note that installation of a restricted CDV was not made on all manual cars. There are some that do not have one, some that do have one without restriction (same as the delete version) and then a lot of cars that have a restricted CDV. Seems that earlier E46 do not have it and it was phased in sometime in 2001 built dates. There are two choices: Remove the CDV completely (the two ends of the clutch line will screw into each other, requiring no parts) or replace the CDV with a drilled-out version, eliminating the restriction. People use the drilled-out version to avoid dealer hassles in case a transmission warranty issue arises. After replacing or removing the CDV, you do need to bleed the clutch line.
  2. CDV aka "clutch delay valve" sterge tot si scaneaza dupa cateva zile de mers din nou, vezi ce reapare
  3. cel mai probabil crankshaft sensor, asa cum spunea si manole, pe diagnoza nu o sa apara nimic legat de el (99%)
  4. mix de apa + aer comprimat pe returul radiatorului de incalzire
  5. radiatorul de interior infundat, poti sa incerci un backflush sau schimbi radiatorul, e o problema destul de intalnita la e90, cel mai probabil ca nu a schimbat nimeni antigelul odata la 4 ani...
  6. daca dai viteza ventilatorului pe maxim e fierbinte aerul sau aproape rece?
  7. zeronoo replied to top_misu's topic in Seria 5
    irelevant...intre 03.2008 si 09.2008 s-au montat ccc cu controller cic
  8. reprezentanta nu poate sa faca update de soft pe module retrofitate neoficial (second hand)
  9. E46 DSC
  10. Da, la bmw inaltimea are legatura si cu telescoapele
  11. Este valabil, specificatii HiFi-System (option 676): 2 treble loudspeakers, front 26 mm2 mid-range loudspeakers, front 100 mm2 bass loudspeakers, 217 mm2 mid-range loudspeakers, rear, 100 mm2 treble loudspeakers, rear 26 mmMid-range /// 2 x 40 W (2 Ω) Bass /// 4 x 25 W (2 Ω) P.S. Multumesc mgs
  12. ce semnale pe led (la faruri halogen lci)???
  13. asa e, pe de alta parte la km lui nu mai are mult pana sa fie nevoit sa schimbe tot...
  14. schimba toate garniturile de cauciuc(baie, pompa vacum, valve vanos, corp pompa ulei, etc) + cele de supape
  15. foloseste ista si o sa ai valori corecte
  16. lifetime ? ar fi pacat sa traiesti doar cativa ani...toti care vand "lifetime" vand de fapt coduri pentru 2-3 ani max
  17. normal ca nu contine...bucata a fost data in folosinta in vara 2015...bazele de date folosite la 2016.1 sunt q4 2014
  18. se numeste ahl2, dupa ce depasesti 50 km/h o sa se indrepte (si ridice putin) si cel din stanga, poti sa verifici la un perete, in reverse ar trebui sa se indrepte, daca te deranjeaza se poate modifica...
