ULEIURI - totul despre uleiuri: teste, recomandari, etc.
8 hours ago, Mikaelll said:
intre aceste 2 tipuri de ulei.
Dintre astea doua, niciunul 😉 LLl19fe 0w30. Sau, dacă nu găsesti, ll04 5w30, care e unul dintre cele două. Și în niciun caz ținut 30k km
Edited by mgi
Salutare,va povestesc urmatoarea experienta,cand am cumparat masina(320d g20mild hybrid,model care este biturbo) in ea era bmw 5w30.dupa aprox 9000km era nivelul spre minim.Am facut urmatorul schimb tot cu 5w30 bmw dar a cerut dupa 7k era pe minim nivelul.Am decis sa bag top tec 4200 si deja in 8k am 1.5l ulei consumati.Ce ziceti ca poate fi aici?
22 hours ago, raulnicolae said:
Daca trebuie pun si poza cu el,nu-i problema.Chiar nu inteleg de ce  este asa greu de crezut ca ii biturbo.Sincer nu prea ii dau talpa.
Cred ca e mai simplu asa. Trebuie doar sa stii ce motoare vin echipate cu bi-turbo:
Major BMW engines fitted with bi-turbo technology include:
1. Straight-Six Petrol Engines [1]
N54: BMW's highly celebrated, first mass-produced twin-turbo petrol engine (parallel setup). Found in the E9X 335i, E82 135i, and E60 535i.
S55: The high-performance engine for the M cars. Used in the F80 M3, F82 M4, and F87 M2 Competition.
S58: The modern successor to the S55, featuring twin mono-scroll turbos. Found in the G80 M3, G82 M4, G87 M2, and X3 M / X4 M. [1, 2, 3, 4, 5]
2. V8 Petrol Engines [1]
N63: BMW's first twin-turbo V8. Used widely across 5, 6, 7, and 8 Series, as well as the X5, X6, and X7 50i/M50i models.
S63: The M-division version of the N63 (cross-bank exhaust manifolds). Powered the F10 M5, F90 M5, F12 M6, X5 M, and X6 M.
S68: BMW's newest M-Performance/M twin-turbo V8. Used in the newest generation of M cars (G90 M5, G09 XM, and high-spec X5 M/X6 M).
Motorul tau e acolo?
BMW zice ca e normal sa consum ulei dupa ceva mii de km..
https://www.bmwblog.com/2020/09/02/how-bmw-twin-power-works/
  • twin turbo technology employs two turbochargers that are placed one next to the other (“twin”)
  • biturbo employs 2 turbochargers as well, yet they are located one on each side of the cylinder bank (typical for V8 engines)
  • BMW TwinPower Turbo is relying on a single turbocharger with two scrolls
  • BMW TwinTurbo Power (yes, this one exists too) relies on two turbochargers
  • TwinPower Turbo is not the same as TwinTurbo Power, so don’t mix them up
Iata o recenta comparatie/..analiza de "laborator" a unor aditivi (mai "rasariti" sau cu reputatie pe piata..) pentru ulei de motor:
Si concluzia, deloc surprinzatoare, puneti uleiul cel mai scump care vi-l permiteti si schimbati uleiul mai des si veti avea mai mult de castigat decat daca puneti aditivi "minunea" lui Peste.. mare vanzator de convigeri care/daca v-ar putea convinge..
