Today
Takata airbag recall question for my E90
I drive a 2009 320i and I saw that Honda is recalling a huge number of cars over Takata airbag inflators. My car has the BMW airbag recall done a while back, but I am not sure if the inflator on my car is the same type. I park outside and the car sits in the sun a lot, which I know can matter with old inflators. Before I book anything, I want to understand if this Honda recall means BMW owners should double check their own recall status even if it was supposedly fixed. Has anyone here had the airbag inflator replaced more than once, or been told their car was not covered?
BMW X4 2024 Start/Stop
Before buying an OBD adapter, check your car’s I-Level. The BimmerCode page quoted above says that on petrol models from I-Level 23-3 onward the start/stop ECU ignores coding changes, so BimmerCode can appear to code successfully without effect. If yours is petrol and on 23-3+, coding is not the permanent fix. In that case look at a dedicated start/stop memory module wired to the button, but confirm X4 G02 compatibility, warranty impact and that it does not alter Comfort mapping.
Achizitie X4 xDrive 30i
Hello! Dupa 3 motoare diesel N47 pe E60, F10 si X5 F15 in ultimii 7 ani de care nu am fost dezamagit niciodata ba chiar foarte multumit a venit momentul sa trec la altceva. Ma incanta foarte tare X4 G02 30i 252cp am gasit unul superb full cu 100 000km. Initial am vrut ceva plug-in hybrid dar desi am panouri si baterii parca pus pe hartie cu diferite scenariu nu renteaza. Sunt nehotarat daca sa iau tot diesel de care am fost multumit mereu sau sa trec la benzinar? Ce diferente de consum si fiabilitate pot fi? Inainte mergeam multi km, in ultimii 2-3 ani decand am copil fac cam 10 000 pe an maxim, drumuri lungi fac foarte putine. Ce ma sfatuiti sa cumpar? Multumesc!
NRC started following Achizitie X4 xDrive 30i
- Mic pârâit și senzație de frecare (?) în volan la virarea la viteze mici
Exista o aplicatie in Store ul lui Robert, posibil sa mearga cu aia
Fara o investigatie vizuala precum si auditiva nu cred ca cineva ar putea sa iti spuna cu precizie de unde vine zgomotul.. Cateva panouri de desfacut sa ajungi tu sau mecanicul pana in zona zgomotului si te vei lamuri. Faca zhomotul vine de la vreun manson de cauciuc dintre coloana si caroserie ...putin dat cu spray de silicon poate ajuta in sesnsul ca daca zgomotul dispare afli si de unde. Ma indoiesc sa fie ceva grav fata de directie. E mai mult un zgomot care v-a/ar putea deveni enervant cu timpul. Crucea cardanica e pozitionata in zona compartimentului motor si in cel mai rau caz scartaie.. dar si acolo se poate da cu vaselina (spray cu extensie/tub atasat) ideal cu PTFE.. sau cu molibden.... meseriasii au.
Nu știam. Mulțumesc de info
Regenerari foarte frecvente
Dupa drumul de ieri la Pitesti, azi am fost in Bucuresti. La intrare pe expres, regenerare. Dupa 230 km. Pe A1, dupa 150 km regenerare. La intoarcere, pe expres, dupa 200 km, regenerare. Am ajuns acasa cu 23g soot mass in 80 km. Nu prea are logica, am mers constant. Consum mediu 5.6% pe o vreme oribila cu vant si ploaie. In fine, sper sa o rezolv saptamana viitoare. Altfel, la primavara zboara de la mine.
Surub rupt in chiuloasă galeria de admisie
@bimmer90f30 Te asigur ca eu nu reproduc AI in postarile mele. Pentru cineva care nu a mai scos suruburi rupte, este recomandat sa utilizeze un burghiu pe stanga. Desi probabilitatea este redusa, ar putea avea norocul ca burghiul sa scoata surubul afara si sa nu mai fie nevoie de extractor.
A mers usor din prima, nu am prins stramb pe filet, pur si simplu a ajuns la capat si am strans eu mai mult ca idiotul si a plesnit :)
Ideea e sa nu fi incalecat filetul ca asta face extragerea cel mai dificil. Nu ai simtit la cheie sau la mana ca nu se strange ok de la inceput sau in decursul strangerii? Asta e cel mai important de clarificat. Altfel daca e pur si simplu rupt in urma strangerii in/pe filetul din capacul culbutorilor.. (surub prost din fabricatie cu material slab, fisurat..) nu ar trebui sa fie dificila extragerea.. Bine niste scule tot trebuie..
Multumesc mult pentru sfaturi, am dat admisia jos pentru ca am vrut sa schimb garnitura de la termoflot, imi pierdea ulei pe acolo, si trebuie sa scot corpul filtrului de ulei. Am montat tot la loc si ultimul pas si cel mai simplu cand sa montez galeria de admisie, strang toate suruburile si ala a fost ultimul strans si mentionez ca nu am strans ca “ghiolbanul”.
O intrebare care are importanta: Cand ai rupt surubul, ai strans cumva acel surub infiletandu-l gresit??? Ca daca DA surubul a fost fortat (practic filet "incalecat" in limbaj de folclor..) atunci uita de toate sfaturile de aici... ca nu il scoti din chiulasa decat daca fie faci alt filet.. (exita fit de refacere intr0un arc practic cu un alt surub de acelasi diametru../ fie... poate, poate cu surub cu filet pe stanga... dar sanse foarte mici ca un surub pe stanga de 3.5 mm sa reziste... Numai asa se rupe un surub la strangere (bine daca realizezi ca la strangerea normala nu trebuie exagerat cu strangerea ci in functie de marimea filetului , dar si material.. se cam strang suruburile).. cand "mecanicul" de ocazie inca crede... ca o data "incalecat" se poate strange la fel de bine ca atunci cand surubul e in canalul lui si nu stramb.. si se astfel alege cu un surub rupt sua cel putin intepenit stramb si nestrans pe care o data atacat de rugina nu il ai scoti deloc daca e strans stramb. Pot sa te intreb, operationea de a da galeria de admisie jos si banuiesc sa o cureti a facut-o tu insuti? Inseamna ca priceput esti cat de cat.. Acum o sa te ajut sa intelegi situatia. In primul rand faptul ca deja a fost desfacut inseamna ca el practic el este rupt DAR NU INTEPENIT (ca atunci cand rupem suruburi deja ruginite.. si nedesfacute de foarte mult timp; atunci se rup cel mai frecvent si e o adevarata durere in c.. sa le scoti/desurubezi intregi). Practic ce trebuie sa incerci este lovesti de cateva ori incetisor surubul rupt cu un dorn ceva si ciocan: vibratiile date vor slabi cat de cat stransoare in care a fost prins filetul surubului cand s-a rupt cu probabil ceva capat de filet in zona rupturii care e intepenit acum tocami datorita rupturii.. (sper ca nu te-am pierdut in explicatia data.. dar utila in a intelege ce s-a intamplat deja). Ass cum am zis faptul ca surubul a fost deja desurubat si acum e rupt e un mare avantaj in usurinta desurubarii.. aici ajuta un degresant (WD40..). Tu practic (in functie de spatiu din jurul surubului rupt) nu trebuie decat sa il scoti 2-3 mm deasupra pentru ca apoi il poti desuruba cu patent sau ce ai la indemana. Practic trebuie sa executi desurubarea. Singurul dezavantaj este ca lucrezi impotriva directiei de insurubare adica surubul rupt ca orice surub se apropie de tine de mana de forta cu, care vrei s ail scoti iar asta nu ajuta si forta trebuie aplicata inainte ca altfel nu ai cum.. Iti explic asta ca sa intelegi procesul. Practic puterea trebui spre inainte dar si spre tine orientata.. lucru nu foarte usor.. In procesul de desurubare chiar si fara scule (dar trebuie mult mai multa grija..) poti sa incerci, daca surubul s-a rupt oblic (in suprafata sa) iar in acea suprafata, in ruptura te poti usor usor agata cu varful unui dorn ascutit (si ciocat) si incepe a incerca sa rotesti surubul spre stanga lovind cu dornul si ciocanul (INCLINAT SPRE STANGA SAU DREAPTA) in jumatatea superioara (spre stanga) sau in jumatatea inferioara (spre dreapta..) important fiinD sa ai in ce sa te agati din suprafat rupta a surubului. Asta poti incerca pana cand surubul iese 2-3 mm in sus dupa care il rotesti cu in cleste ceva.. mult mai usor. De incheiere, a doua postare mi se pare mana de AI acolo. Nu inteleg de ce ar trebui sa gaureasca cu brughiu pe stanga (mul mai greu greu de gasit)?? Cat de mult ajuta extractorul ala de suruburi rupte faptul ca mana ulterior se va roti tot spre stanga exact in directia in care sa zicem zgarieturile din peretele gaurit de surub sunt TOT sprea stanga? As spune ca o gaurire cu burghiu normal ajuta pentru ca atunci acele zgarieturi spre dreapta din peretele gaurit ajuta la "agatarea" de extractorul folosit. Nu vad altcumva decat a doua varianta mai logica. In trecut, am experienta cu suruburi rupte si extrase cu alte suruburi si filetari pe stanga .. si de fiecare data am folosit burghiu normal, nu pe stanga. Nu am avut nici o problema in a face profil filetului.
gazdadan joined the community
Dmitriy joined the community
Exact ce iti zisesem sa verifici. Softul ecu-ului e de vina, trebuie downgrade.
Yesterday
Help!!
Salut, detin un seria 1 din 2012 e88 motor n47, i am schimbat motorul, se invartise cuzinetii, dupa ce l am schimbat totul bine si frumos pana a trebuit sa ii schimb chiulasa, dupa ce i am schimbat-o, dupa ce se încălzește motorul la relanti se aude rotund frumos merge bine gen, cand o accelerez incepe sa se auda o bataie mica ca un fel de țăcănit pot sa zic, se aude din spate la motor gen, ba se aude de la distribuție ba de sub masina dinspre volanta, cutie manuala am uitat sa spun, se poate sa se auda de la volanta? De la vreo patina? Eventual de la tacheti/culbutori? Poate a mai avut cineva aceeasi problema si stie sa imi spuna ce sa verific prima data
Cum ziceam..... Auto Start Stop on Petrol Models from I-Level 23-3As of I-Level 23-3, disabling the Auto Start Stop feature via coding is no longer possible on BMW petrol models – the control unit ignores any such changes, even if transmitted successfully.
Multumesc, sunt departe rau de tine, nu ma apuc singur deoarece nu am tot ce imi trebuie, si cu surubul ramas in admisie m am gandit sa ii tai capul si sa il scot pe dedesubt, dar nu am idee daca va intra cel nou :)))
Salutare tuturor! Am un BMW Seria 2 Active Tourer F45, 218d, an fabricație 2017, și mă confrunt cu o problemă la direcție pentru care aș aprecia părerile și experiențele voastre. La rotirea volanului la viteze mici (manevre în parcări, curbe și viraje pe străzi înguste în oraș) sau chiar la rotirea lui pe loc, simt în volan niște vibrații fine, rapide și ușor neregulate, însoțite de un mic pârâit. Ca să descriu cât mai bine senzația, este ca și cum o componentă ar freca ușor pe alta, ceva asemănător cu frecarea cauciuc pe cauciuc. Nu sunt impulsuri elastice sau lovituri propriu-zise, ci mai degrabă mici vibrații rapide, neregulate, care se transmit în volan pe toată durata rotirii. Am impresia că senzația și zgomotul provin de undeva de la baza coloanei de direcție, în zona pedalelor, sub bord, nu din zona volanului propriu-zis. Este însă posibil ca localizarea să nu fie exactă. Un aspect important: volanul se rotește în continuare perfect lin și cursiv, ca întotdeauna. Nu agață, nu se blochează și nu simt că ar necesita un efort suplimentar. Din exterior nu se aude nimic, nici de sub capotă. Motorul diesel este destul de zgomotos, deci nu exclud ca un eventual zgomot să fie mascat. Problema a apărut treptat. Cu zeci de mii de kilometri în urmă, am început să observ un fenomen diferit: după un drum pe autostradă, când intram într-o zonă de servicii și făceam primele manevre de parcare, se auzea un singur pocnit, oarecum metalic, care se simțea și în volan. Era un pocnit scurt, ca o eliberare bruscă a unei tensiuni acumulate. Se întâmpla o singură dată la fiecare oprire, nu la fiecare rotire a volanului. În oraș sau după deplasări pe drumuri naționale nu apărea. Și acel pocnit părea să provină din zona inferioară a coloanei de direcție, în dreptul pedalelor. În timp, fenomenul a evoluat către senzația actuală de pârâit și vibrații fine la rotirea volanului. Simptomele actuale: Apar atât la rotirea volanului pe loc, cât și la viteze mici. Se manifestă pe toată durata rotirii, în ambele sensuri. Nu sunt localizate într-o anumită zonă a cursei volanului. Impulsurile sunt neregulate, rapide și foarte fine. Nu par să depindă de temperatura mașinii. Direcția funcționează normal, fără agățări sau variații de efort. Ați întâlnit asemenea simptome la BMW F45, în special la 218d? Ar putea fi vorba despre articulația cardanică inferioară a coloanei de direcție (crucea cardanică/arborele intermediar)? Ar putea proveni de la bucșele sau rulmenții de ghidare ai coloanei, de la garnitura de trecere prin peretele habitaclului sau de la caseta de direcție? Ar putea fi implicate flanșele sau rulmenții amortizoarelor? Pocnitul inițial, ca o eliberare de tensiune după un drum pe autostradă, ar putea avea legătură cu pârâitul actual? Ce riscuri există dacă circul în continuare în această stare? Este posibil să fie doar o frecare minoră sau ar putea evolua către o defecțiune care să afecteze siguranța direcției? Mulțumesc anticipat pentru orice sugestie!
https://bimmercode.app/vehicles/g02/#start-stop-function Aici sunt informații de pe pagina aplicației recomandate de @Virin3l
Nu sunt asa sigur ca la masina aia se mai poate dezactiva Start-Stop ul asa usor.....
Salut! Cateva completari fata de cele mentionate de colegul mai sus: Protejeaza componentele din zona si foloseste o suflanta cu aer cald (au coeficient de dilatare diferit) Extractorul sa fie de calitate (asa cum spunea si colegul mai sus)! Se pot intampla doua lucruri: fie dantura extractorului se uzeaza, fie extractorul se rupe (in acest caz problema grava = electroeroziune, freza, etc). Inca o mentiune importanta: inainte de a baga extractorul degreseaza foarte bine gaura pentru ca acesta sa poata gripa cat mai bine pe surub. Referitor la diametrul burghiului eu as merge pe un burghiu de 3,5mm (riscul de a se rupe extractorul este mai mic). Completeaza locatia la profil. Daca esti din zona te pot ajuta. Daca ti se pare complicat si crezi ca te depaseste sau poate nu ai toate sculele necesare, sfatul meu este sa nu te apuci de scos surubul respectiv!
Si cu surubul cum fac? Ca am comandat deja altul nou dar nu am idee cum as putea sa il scot pe cel rupt, si nici nu stiu daca il pot baga pe cel nou
Mersi tare mult, o sa incerc aceasta varianta maine sa vad daca reusesc ceva.
constantin12245 started following Surub rupt in chiuloasă galeria de admisie
Cumpara un burghiu de 3mm, cu sens rotatie stanga. Cumpara un extractor pentru suruburi M6, care poate fi initiat intr-o gaura de 3mm si un dron (punctator) cu arc. Cumpara spray penetrant. Nu te zgarci la calitate. Astupa intrarile in toate canalele de admisie. Nu vrei sa iti cada nimic in motor. Da pe surubul rupt cu spray penetrant din belsug. Pleaca la plimbare 1-2 ore. Cand revii, da din nou cu spray. Marcheaza cu punctatorul cat de in centrul surubului posibil. Masoara (te ajuti de un surub identic dar intreg) cat din surubul rupt a ramas in chiulasa. Seteaza bormasina pe rotatie stanga. Prinde burghiul in mandrina si marcheaza pe burghiu adancimea la care sa te opresti, care este egala cu ceea ai masurat la pct. 5. Gaureste la turatie redusa, cu rabdare si fa tot posibilul sa fii de-a lungul axului surubului rupt (sa nu te duci stramb). Daca esti norocos (de regula norocul nu prea se arata la astfel de probleme), surubul va incepe sa iasa. Daca nu a iesit, atunci foloseste extractorul. Lucreaza cu mare grija si rabdare, daca rupi si extractorul situatia va deveni foarte intunecata. Succes!
